rylee144
    3
Everything posted by rylee144
  1. I may have to shorten it up. If that bolt rotates somehow it would rub again and if that happened at speed that could do some damage.
  2. id like to say they are 16s. i had to leave for work and the truck was blocking the garage door so i resorted to the grinder for now so that it could be moved.
  3. That idea crossed my mind. The doner jeep did have aftermarket wheels
  4. Could I run the bolt up instead of down?
  5. They we drilled out when I got it from the donor jeep that also had this steering. I'll go pull the wheel and add pics
  6. It seems I have messed something up. The inside of the wheel on the passenger side is rubbing on the bolt head. What can I do to fix this?
  7. The truck is back on her feet again. My wife will be helping me bleed the brakes this afternoon then it's off to get the alignment done tomorrow. I messed up and should have changed the gear oil in the dana 30 before I swapped it in now I'll have to do it in place. Got a new gasket coming for it and the 8.8 Progress is slow but happening. Next up will be pulling the rear axle.
  8. $500 for the silver MJ and the blue one is free. Lake Stevens WA. https://www.facebook.com/marketplace/item/3760652080697992/?ref=search&referral_code=undefined
  9. prolly cheapest to go on market place and find a Cherokee part out prolly get a set for $20-$30
  10. try car part. here is a link to the page that allows you to add what type of mirrow you want. https://www.car-part.com/cgi-bin/search.cgi
  11. Mine just needed a needed a new fuse in the fuse block under the dash.
  12. Could a guy get a shorter trans mount to make an auto cross member work
  13. I thought that too but the dude insisted. Lol
  14. https://deadjeep.com/products/84-96-cherokee-xj-driver-left-rear-door-window-regulator-comanche-55075929
  15. rylee144
    1J7FJ26L1LL137503
    Sweet truck! Welcome
  16. Guy told me a Peugeot 5 speed cross member will support an ax15 transmission if you flip it around. Is that true?
  17. Mt Rainier this morning
  18. Ad says metric ton https://www.facebook.com/marketplace/item/231405921776986/?ref=facebook_story_share
  19. Note,thanks! I'll start by pulling the old axle
  20. Checked two yards, couldnt find it
  21. Is there room for error here? I don't wanna weld it on then have to cut it back off. I don't have the new tranny or t case in yet so I can't measure the angle they will be sitting at. I guess I assumed it would be the same.
