NickInTimeFilms
4 Followers
    New Jersey
1552 profile views
NickInTimeFilms's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. This makes me wonder if your engine would have tried to start if you unplugged the distributor sync sensor before the re-index. Maybe if the ECU can't match the cam to crank then it won't attempt to fire. I may suggest this in the future for troubleshooting.
  2. To dive a little deeper, the ECU reports the time gap between spark commands, which through some math we can find the engine RPM from. If there is an RPM reading to show, that means the ECU is sending spark. No RPM, No spark commands. So if you are getting an RPM reading but no spark, then I would look into the ICM, coil, or distributor and plugs. The thing to take away is that RPM isn't a direct reading from the CPS, but rather the aftermath of the ECU processing the CPS and giving the ok to send spark. I wish the ECU atleast sent an OK flag when CPS signal is sufficient, but they really dropped the ball in that area of reporting.
  3. For all the info available from the ECU, it's rather lacking when it comes to anything directly involved with the CPS. The REM is starting from the end, rather then the beginning of the chain so it's still difficult to pinpoint the CPS for sure. All that code really tells you is that the ECU is not sending a spark command to the ICM, but this could be caused from multiple reasons, not just dead CPS. Knowing exactly why the ECU isn't deciding to send spark has still been a mystery to me beyond a weak CPS signal so it's just written like that for now.
  4. Figure i'd chime in. First thing I'm noticing is your vacuum at idle which is really low, but maybe that has a bit to do with the low idle. Check your map vac line is clean and tight in the lower TB port. The IAC reading showing 1 is odd though as that should be indicating that the ECU is continually trying to lower the idle even though it's already low. TPS is a little low but not the end of the world. adjusting it and resetting the ecu may help a little, or at least feel like it till the ecu relearns the fuel trims. Speaking of, LT fuel trim is a tad low which sounds like it's running richer than usual, and showing by the o2 sensor i'd say that i'd agree. It's not holding closed loop so it may be too rich to even correct for. Do you have aftermarket injectors?
  5. Best spot is one of the firewall grommets by the steering column, then up and over the map sensor.
  6. Sorry about the lag, parenthood has been dragging me through the ringer this last month. The website link earlier explains the readings that aren't on the booklet, but I didn't think to add the more spelled out ones from the Readings menu. Finally got to watch the video, and I see the confusion. The clock panel definitely isn't the "easy" model to use by the odd button layout as you can tell. But as requested, I've attached a picture of how the buttons are mapped to the screen. The positions never change so you can trust what's top or bottom. Sounds like you got the Gauge screen figured out, but each of the 4 corners have their own loop of the same data cycle. So you can use any corner to click through the entire set of data. As far as the data I saw, nothing major stuck out to me. The only problem child I saw was your IAC Turns reading showed < 0 which means the ECU was continuously trying to lower the idle but was unsuccessful with the IAC. The odd thing about this is your idle RPM was under 700 so I'm not sure why it wanted to go lower. Usually that kind of reading means your IAC is stuck, leaking, or you have other vacuum leaks that the IAC can't adjust out. You o2 sensor was swinging nicely, and your ST Short Term Fuel Trims looks great, nearly right on target. Good news for healthy closed loop. TPS reading was a little low at 12% when 17% is the norm, but it's almost not worth adjusting for such a little offset. If you do decided to dig into this, pull the battery cables once you're done to reset the ECU so it doesn't try to idle funny on you. Not sure if you were holding the brake for that entire video, but if you weren't then the TCU brake switch needs to be adjusted as it's not making contact with the pedal lever anymore. All this affects is torque converter lockup on the highway though. I know that doesn't answer your hard start or lumpy idle, but what I can say is that it's probably not sensor related as everything seems to be reading nicely. That means it might be more mechanical which requires the hands on kind of diagnosing. If you want, open up the No-Start Test and record it when you're having a hard time starting. That can help us narrow down what's missing sensor wise at least.
  7. I'm definitely trying to fit way more onto a 16x2 screen then I should be which leads to complex and incomplete menus like the No-Start. The video you posted is mirrored which will make for some tough watching, but regardless I am absolutely excited to watch you try and figure out the menus. That kind of stuff tremendously helps me make better and easier to use software. I will however have to watch it possibly in the next few days as my flight is tomorrow and I still need to pack. UPDATE: I was able to rip it from Youtube and flip it on my computer at least.
  8. Home > Diagnose > Tests > Engine No-Start. The 2nd line of gibberish is the first letter of each test. They will disappear one by one as they pass so whatever is left is a possible issue. Scroll down to see full text of each remaining issue. I think I have a V0.9 software walkthrough, but I need to get full documentation together. If we ask enough questions here then we can just make this the wiki .
  9. I know you're fighting a no-start, but all I can say is be careful with the readings you get when the engine is off. The Renix data definitely has a few quarks to learn so you aren't chasing your tail on data that doesn't update or display right. One example is the o2 sensor, it does not correctly report unless running. Another is that ECU Voltage will show 0v unless running. I try to make notes of anything odd on my updated readouts summary page here: https://nickintimedesign.com/rem-gauge-readouts/ Maybe while I'm away I can push myself to make some fuller documentation about the more hidden features of the REM. On the Diagnose Screen there are a few different views you can access. - Top Left is the Info option. Clicking this will cycle through a few little notes about each sensor. - Bottom Left is the Mode option. Clicking through this will cycle a few tracking options, such as detailed info, sensor Min/Max, and sensor graphing. Note: While the Min/Max view is up, the i button will change to r for Reset, incase you want to reset the min/max reading for that sensor. As for the dummy lights, nothing useful there since o2 is inaccurate when engine is off. The datastream looks a little goofed since the ST fuel trim isn't 128 even though it's in Open loop. Try clicking over to Sensor Tests > No-Start Tester and see what still remains after a crank. I'm betting it'll probably say CPS, but that doesn't exactly mean the CPS is dead, just that the ECU is not sending a spark signal to ICM yet.
  10. Let us know what data you find! As for the sanding, best of luck. These 3D printers are a constant chore to keep dialed in and pretty. Some tips I can give are that Acetone vapor can help smooth the ABS plastic, and Super Glue works wonders if anything ever snaps. The glued joint will be even stronger than before.
  11. I mean, you can definitely use it handheld fine, it just won't be easy to soft mount anywhere else.
  12. ^ All of this. I've got REM Clock panels in stock hopefully until the end of the year which are diagnostically the same as the Square REM. I actually was able to secure a large batch of chips for the square REMs recently so I should be able to bring them back into production around summer '24. I'll be away for Winter '24 so get any orders in before then. I repair REMs as well so don't be shy, haven't met one I wasn't able to fix yet.
  13. PM me, I'd love to get that going! A little idea bouncing should get that knocked out in no time.
  14. Someone needs to give me a good kick so I can get a functions manual finally written out. I've had a lot of undocumented features for a little too long now. The Fill-up menu is a still a little half baked and needs a refresh, but it is a basic fuel tracker and helps calibrate the accuracy of the MPG gauge. 1. Each time you add fuel, input the gallons added. 2. Next, set the fill mode to how you refueled. I believe the options are Fill, Partial, and Missed if I recall. - Fill for a full tank. (This option is used to calibrate the MPG reading with 2 consecutive fills, the % shows the difference from base level) - Partial for when you added fuel but didn't top it off. - Missed if the previous fueling was not recorded on the REM. (This resets any old numbers because they will be wrong) 3. When everything is good, hit the Save option (Sv), then hit Yes to save. It may cut off but it's the bottom right option. All the tank info can be found in the Diagnose > Pages view near the bottom. The M mode button will cycle through different numbers, but don't rely on them too heavily. The remaining tank gave me an idea of my range last highway trip, but I still had a little extra in the tank that wasn't accounted for. Fun fact, this can also estimate the flow rate of your injectors once it's calibrated, but thats only hiding in the vehicle menu for now. Again... gotta get to finishing the last 10%.
  15. Great Write-up! If you don't mind, I'll link this thread on my site to help folks out in the future. Would also like to report that as of Renduinix V9.16 there is a bug with the AEM Wideband profile that was preventing the REM from correctly detecting when the sensor was in "Heat" mode. The REM should output a lean signal if it detects Heat mode so that when the ECU tries to correct, it adds fuel instead of pulls fuel to keep a stable idle, but with the bug it was only defaulting rich. Never caught it since my Jeep hasn't driven since V9.15! This issue should be fixed in V9.31 now so thanks for the heads up!
