Cre8tive
Everything posted by Cre8tive
  1. Hey so I figured out what was wrong, thought I’d let you guy know what it was I guess my computer was burnt out and sending power threw my fuel pump ground and burning them out but at last with only 4 fuel pump gone I have her running and in 5 year she’s tasted her first chunck of gravel road it was pretty nice for only 2.5l little 2wd (for now)
  2. Thanks for the helps guys 👍 so this I we’re I'm at now, I’ve checked my back ground behind my tail light again to be safe and it looks good also I just tried running strait power to my pump and nothing happened no prime sounds or whispers of any sort?? Does this mean my pumps gone bad again?
  3. anyone possibly no were I can start with this I’m completely lost and have done all the basic checks I could find online?? here's my situation i replaced my fuel pump about 2 months ago, It started just fine at the time, i ran for about 40 mins then left alone (trucks been sitting since in the garage) Threw out the 2 months, I’ve been turning on my truck and letting it idle for a while and one day out of nowhere the pump decide it would only sometimes turn on and prime and after a couple day of that going on it decided to go further and just stop working and now thats basically we’re I'm at with it and also when the pump started acting up I stopped running it to not cause any damage Ive checked the fuses/relay also swap them around, Ive ran a wire from top port to bottom port on the relay and check to see if power is reaching it.. there was at (12v+) all my grounds are original but I’ve sanded my truck down to bare bone and painted it so there all pretty clean, and I’ve checked and ran a hard line to that clay thing for the pump and to the pump itself threw the harness and that did nothing?? Also tested the foward plug to my tank that’s part of the main harness and when I turn my key on it jumps to 12v+ then to 0v I'm kinda lost wouldn’t mind your tips, links or anything ideas u guys might have?? Did I put my pump in wrong? Is it shorting out somewhere or are my grounds needing upgrading, do I need a new sending unit??? Anything at this point is considered help
  4. Ahh yes thanks for the reminder 👍
  5. I’ve just gone threw this lift and here’s what Ive ended up with on 33s 15x8 3.75bs/ no cutting with fox adventures 2.0 upgrade, here’s my before and after
  6. I have one for my 91 and looked around couldn’t find any comanche or Jeep stamped in it
  7. The thicker ones go on the cross
  8. Bleeping Jeep guys got a really good video on brake calliper rebuild I just did mine because they wouldn’t move and bleeder nips were rust welded together. They turned out a lot better than before and move finally
  9. Ok sounds good thanks for the help guys!
  10. Sorry I should have been more clear I’m taking about the rubber boot being all mangled and slight fluid seems to be in the foam Just wondering if this could be or is a problem.... thx in advance
  11. So I have a 2001 wj limited 4.7l v8 took the brake booster out of it for the mj cause the things going to scrap anyways and ran into this.... can I get away rigging something up to fix it or just scrap and buy a new one?
  12. I Had this exact problem... dummy me!! turns out it was one of the connections on the drivers side under the dash was pluged in a bit crooked and not all the way in, only making contact with a few wires, also when I pushed my brake pedal in my rear lights acted up instead of the fronts while this happened.
  13. I used raptor liner but same thing... my one tip cover things really good has quite the over spray!!!
  14. https://nickintimedesign.wordpress.com/
  15. It's a Short bed but same amount and size spacers
  16. I'm doing the same thing ATM and I've done it this way I'm not 100% on this would be nice if some else could confirm! Front driver Front passenger blue #4 blue #4 blue #4 blue #4 black #2 black #2 black #4 black #4 blue #4 blue #4 Rear driver Rear passenger
  17. Still learning :)
  18. Added on vancouver island
  19. First post ever hope this helps! Added few more pictures was fully painted with raptor liner at 130$ a kit and simple to use, used 3 kits but went thick with the stuff 2 would have been more than enough.
