cruiser54
    14
  1. Remove the air cleaner box and use extensions.
  2. Pretty sure most all are the same. AMC is same as GM for sure.
  3. You can do valve seals without moving the head. I've done it.
  4. There are other ways to skin this cat. A block off plate would be good for other areas. We need to find one to buy. As for Cali Crap, there are other ways to work around....
  5. IIRC, that setup was used on vehicles with dealer installed air conditioning.
  6. Don't buy me Bud Light please. On a "lighter" note, there has to be an off the shelf EGR block off plate for those without the ability to make one.
  7. Are you gonna pull the head? It likely needs valve seals.
  8. The hose from the intake manifold to MAP sensor? Any vacuum leak there will tell the fuel injection system to add more fuel.
  9. Or, it could be leaking injectors. Not holding pressure after the Jeep is shut off and requiring the fuel pump priming you've been performing.
  10. sure. Actually the lower bolts hold both intake and exhaust manifolds.
  11. I didn't even listen to or watch the video. They're never worth a $#!& anyway.
  12. Get this one and mount it under the coolant bottle. https://www.amazon.com/Dorman-HELP-47076-Vacuum-Tank/dp/B000COB8FA
  13. check this out. I cut a big one in half. It's basically 2 small cannisters in one. And, the "good" half of the can still works.
  14. Billabob, do you have cruise? If not, here's a real easy way to upgrade and eliminate a bunch of troublesome plumbing.
  15. HOrnbrod Moderators 20.2k Location: Sweet Home Alabama Posted November 21, 2016 New members to the forum, and some longtime members too, post technical questions in this forum but do not provide specifics of the MJ they are referring to. Like: Year of Manufacture Engine Drivetrain Body Style Etc., Etc. These details are necessary for responders to accurately answer your questions without guessing or having to ask what are the specifics of the MJ you are referring to. You can add these details easily and permanently by creating a signature or adding your truck details to your existing signature. Here's how to do it: 1. Click on the upper RH icon to open the drop-down menu 2. Click on Account, then Account Settings 3. In the Settings menu click on Signature 4. Compose your signature, or add to your existing signature 5. When complete, click Save
  16. Have you ever visited my website and completed Tips 1 through 5?
  17. Take the belt off and turn the pulleys. Inspect the harmonic balancer and see if it is separating.
