garrett6410
garrett6410's Achievements
  1. Hear lately I've noticed my jeep has been getting extremely bad gas mileage such as about 8-11 mpg. Used to before I went up to 31s I was on 30s before it was getting about 17 18. It's got a new 02 NTK new sparks and newish spark plug wires replaced within 2 years any tips to help my gas mileage would be well appreciated and it also seems to have a miss I'm not sure on what cylinder or if it does at all it just seems to idle a little funny
  2. I gotcha this one is weird to me i gotta ask my mechanic what kind of gas tank he installed (got it installed as a gift) because it looks the same as my other jeeps gas tank but not to sure. Ive seen it hold 16 gallons before and it put it all the way at full. the fuel pump is brand new i got the whole sending unit not just the pump and its a delphi but now its hard to make it hold that extra quarter of a tank and when it does start to fill up when it gets to about that 1/2 it struggles to hold anymore past that point its like air is trapped in the tank and won't escape because i can rock the jeep a little and it'll hold more
  3. I gotcha if it is a 20 what would i check maybe a bad charcoal canister?
  4. I'm pretty sure i got the 20 because ive seen it fill up when i had a vent valve leak other than that idk
  5. Ive had issues since ive gotten this new gas tank is there something I'm over looking it only holds 3/4 of a tank but if i force it by force it i mesn dtsnd there for hourd it will show s full tank is it a evap problem its got new vent valves and grommets pluse a new pump and tank
  6. Aah ive never looked at that plug might have to here soon @cruiser54 ill get one here soon hhhh
  7. My headlights are pretty bright but they are leds though. And as far as the plug it looked fairly nice the last time i checked it but no doubt will do the upgrade just to be sure the same plug we are talking about is the one the headlight harness plugs into right
  8. Been thinking about getting one of those here soon at the same time I ain’t seen any need to at the moment I will soon though
  9. Been maybe 3 weeks without ac I couldn’t figure it nor did I have the time. Id it common for the ac decks to go bad?
  10. Yall hape finally helped me figure out my Issue today I’m glad it’s working again. Unfortunately I gotta Buy a new ac deck sadly got to looking at the plug for the ac deck it looked fine then I looked at the prongs where it plugs in at one was severly burnt in color I cleaned it off and it works like a charm now so I’m gonna go pull one at the junkyard. First thing I checked was I'm fine it wad getting power at the blower switch then I unplugged it and noticed that immediatlt plugged it in checked for power it had power then I went to the resistlr it had power then I checked the blower plug itself she ʻlit up brighter than ever So I plugged in the motor bam it turned on on all 4 settings aswell. Yall are awesome
  11. all of that works like a charm its odd for sure thats why i wasnt leaning towards a new ignition switch but anything possible with this thing
  12. i tried following a 92 wiring diagram and i replaced everything on the circuit only thing i did not replace was the climate control headunit the part with the switchs. i think the only shared part on it would be the ignition switch on top of the column and i replaced that recently like maybe a month or 2 ago so surely it aint went bad that quick i bought a standard brand switch
  13. ok if no power to that switch then what do i do check behind fuse block?
