daltonmcgill7
Everything posted by daltonmcgill7
  1. seen the same ones the other day they had them on craigslist for a while they were asking way to much for both
  2. just figured out that oim now getting 0 fuel pressure but i hear my fuel pump working could it be a cloged fuel filter
  3. I'm trying to find the cheapest way to lift my comance soa I'm going to get control arm drop brackets will these work for a 5'-6' lift? also ive heard of people using trackbar drop brackets but i can't seem to find them. dot they make them?where can i find them? do i have to have a drop pitman arm? :huh???: also will i need swaybar disco's? :help: :help: :help: is there anything else I'm missing would it be cheaper just to get the kit from rockyroad? also antidisestablishmentarianism size tries can i fit on this lift i was thinking either 33's with no cutting and 35's with some triming
  4. my comanche won't start it has fuel pressure has spark do you think it could be bad gas? its been siting without the neck on so I'm thinking it could have gotten water in it also my gas gauge says its full whn i no its not it probly only has a gallon iin it.what could that be? :dunno:
  5. i say go 31 because u can run 31's with no lift
  6. it looks way better with it off
  7. viewtopic.php?f=7&t=18814&p=191887&hilit=grizzlygrip#p191887
  8. k thanks ill go look if i can't tell ill take a pic
  9. i have a 1989 jeep comanche base model i need to no what transmission i have to get a clutch its a 5spd. Also what size is my clutch :bowdown:
  10. daltonmcgill7
    New MJ
    my dad bought mine new he had another 1 he bought new but traded it in to get the other 1
  11. flatbed comanches ive seen the camo one but can't find anyother 1's. :help:
  12. Yeah, it works. Only problem is it doesn't last for more than 4 hours.. :rotfl2: :rotfl2: :rotfl2: :rotfl2: :rotfl2:
  13. :dunce: :dunce: :dunce: :dunce: :nuts:
  14. my friend keeps telling me if i flip my rear axle and bolt it back up it will give me soa without any welding is that true :dunno:
  15. :agree: i just got 1 for christmas and i love it the keeboard is really close to normal u get used to it pretty quick
  16. same here itsonly got below 32 like twice this year i love florida
  17. drop the gas tank, disconnect the e-brake bracket from the bottom of the bed. if you have a roll bar you will have to unbolt the lower bolts as well. thank you :bowdown:
  18. How many bolts did you remove? There are 8 on my short bed...not sure about LWB. There is a post on here somewhere that shows all the bolt hole locations. A quick search and you should be able to find it. itook 8 off
  19. I took the bed bolts off also the spare tire carier but what else do i need to do? do i need to drop the gas tank? sorry i seacrched but i counldnt find anything.
  20. You got that rite Eagle!! Yesterday @ 5AM when I was getting ready to leave work it was 3 degrees!!! MERRY CHRISTMAS everyone!!! CW 3 degrees its 72 here
  21. here's mine
  22. could be a short have u checked the fuses
