daltonmcgill7
Everything posted by daltonmcgill7
  1. i think its the injectors because that was the same thing mine was doing after it sat for 5 years try tapping the injectors with a screw driver while its running to try and free them up but don't do it to hard or u mite break them also unplug them then plug them back up that also freed mine up 2
  2. i no this has been asked a hundred times but i tried searching but i didnt find anything i want to find out the cheapest way 2 get 3 inches of lift so i can fit 31's :popcorn:
  3. o :dunce: thanks
  4. do they make snorkel for comanches i can't even find 1 or does anyone know how to make 1
  5. lol it was the only thing i could think of :rotfl2:
  6. have u tried slamming the door as hard as u can :dunno: i has worked four me before
  7. beacause it already has dents in it and the clearcoat is pellin and cuz i will also be huntin out of it so if i do paint it it will get scrached up so i thoughtr of rhinoliner
  8. also do u think rhinolining my whole truck would look good 8)
  9. i got all thebrakes loose :banana: but the clutch is bad :grrrr: where cn i get a new 1 my dad is gonna put iton 4 me
  10. I usually use a 2 or 3-pound sledge hammer applied to the sidewall of the tire from the back side (i.e. from under the vehicle). The wheel should be jacked up, and since you'll be lying on the ground under the chassis, you need to be sure the truck is well supported. If you care about the wheel, be careful not to hit it. I had one MJ a year or so ago where that worked for three out of four, but it wouldn't "pop" the right front. Fortunately, that truck had stock steel rims and I have plenty of those, so I gave up hitting the tire and used a full-size (long handle rather than one-hand) sledge hammer applied directly to the flange of the rim. I destroyed the rim pretty thoroughly before it came loose. i got the back brakes loose now i only got 2 get the right front thanks for the help
  11. nvm i go it off but the back brake is on antidisestablishmentarianism should i do to break it free :dunno:
  12. i got 1 tire offbut 1 of the is like rusted to the drum any ideas on how tobreak it loose??
  13. thnaks ill go try that
  14. my 1989 5spd is goin into gear but won't mov antidisestablishmentarianism do u think it is its been sitting for 5 years with the ebarke on but i released it and it still won't move keep in mind I'm only 14 i turn 15 n januay so I'm tyin to fix it by then antidisestablishmentarianism should i try :fs1:
