daltonmcgill7
Everything posted by daltonmcgill7
1984 jeep cherokee leaks coolant
daltonmcgill7 replied to daltonmcgill7's topic in MJ Tech: Modification and Repairs
its weird becaus eass soon as i put water in it it leaks right out it won't hold any water so i can't drive it -
how hard would it be to replace a freeze plug. Also what do you mean is it leaking from the inside or outside of the bellhousing -
2.8l automatic leaks coolant from where the motor and transmission meet on the passenger side. :doh: :fs1:
how totow a 1996 4x4 zj with a tow dolly
yeah i know but flat tow and using a tow dolly are2 diffrent things.it also says to not used a tow dolly. -
alright soundgs good thanks. -
well my front driveshaft is disconected anyway because i got diffrent size gears.but i thought you could just put the transfer case in neutral to but i read somewhere that you couldnt. idk but if i disconected my rear driveshaft would i loose fluid? -
does anyone have a picture of how to iinstall the clips that hold on the brake pads.I put my brakes on without them and i can hear my brake pads wobbiing
1989 mj front end in a 1996 zj
the mj is a 5 speed 4.0 and the zj is an automatic 4. not sure on the transfer cases -
will it work? can i take everything off the mj and put it on the zj because the zjs bushing are wore out
so should i not worry about the noise
also when i turn theres a clunking noise what could that be?
i tighted the control arm frame mount and one bolt was hand tight and the other one barley to any pressure for it toiloosen so i tightend them up and went and hit a speed bump at about 60. And had no death wobble so do you think its fixed? i wanna take it on the highway ,But i havent gotten it registerd yet and i don't wanna pay the money yet if its not fixed.
so the xj axle will work?
i just bought a jeep zj today for $200 but the guy told me it has a jeep xj axle in it and that when he drive and hits a bumb it will start shaking where he has to stop what do you think is wrong?
sorry http://compare.ebay.com/like/3004033073 ... 602_304662
this is the cheapest clutch kit ive found will it work for my 1989 4.0 5spd I'm pretty sure its a puegoat
Thayer03's Comache Build
daltonmcgill7 replied to thayer03's topic in Member Projects: Your Comanches
are you still using stock control arms and stock tracbar -
he says he has spark so CPS is probly good. no fuel pressure could either mean the truck is OUT OF GAS... (silly mistake, don't let a failed gauge let you down) probably not a blocked fuel filter if this just started happening out of the blue but you can replace it cheap and know thats good. check and be sure the pump has a full 12v and then pull the line before the filter and see how much (if any) it pumps. thanks ill try this
well i finally got fuel pressure but still no start I'm thinking its got bad gas is there a way to drain the tank without taking it completly out or do u think i should pour some seafoam in it
:agree:
but wouldnt that make the fuel pump not work at all i hear it running but get no fuel :huh???:
track bar drop bracket
i was wondering if i did go soa in the back could i put some kind of lowering shackle on and maybe take a leaf out to drop it to about 3-4 inches of lift insted of 5-6 and just get some 3 inch coils for the front and new shocks. the reason i wanna go soa is because I'm sick of hitting my springs on the ground i want more ground clearence.
