Everything posted by partsmj
How many 242 Comanches are out there? Why not? That could be the ABS pump.
Some people have too much free time.
smoked, http://www.virtualweberbullet.com/rib1.html or grilled? http://barbeque.allrecipes.com/az/ScttH ... Grilld.asp
I have a front driveshaft from a 92 auto 242. That 86, is it a stick or auto?
Isn't hacking a crime? http://www.cert.org/tech_tips/FBI_inves ... crime.html
If you know someone at a dealer that still has a DRBII with the Jeep adapter, you can check the sensor and make sure it is adjusted properly. The setting is 13% at idle.
I would check the throttle position sensor.
How to tell if Comanche has Limited Slip / Posi?
partsmj replied to Swanny's topic in MJ Tech: Modification and Repairs
Or just dump the clutch and find out the fun way? Yes. -
Question on switches and gauge thingy
partsmj replied to feerocknok's topic in MJ Tech: Modification and Repairs
IIRC the 1986 model (maybe 84-85 also) had the system sentry. It monitered many things. Coolant level, w/w fluid level, brakes (wear sensor), and maybe diff fluid. I do not remember too many Jeeps having this option. -
Or ... a previous owner changed the gearing. Or washed the engine down. The TPS is very sensitive to water. 33004650 $37.00 Electrical - Powertrain control - Throttle position sensor THROTTLE POSITION SENSOR, 4.0L, Auto Trans 1986 - 1990
...she was in Harlem on her way to a shooting range when.. If I lived there, I would always be on my way to the shooting range too.
hard starting either cold or warm
partsmj replied to mike's topic in MJ Tech: Modification and Repairs
The fuel pump could be a problem. It has a check valve to keep the rail under pressure. If the fuel drains back to the tank, it takes a while to build up pressure. Turn the key on, listen for the fuel pump. When it stops, turn the key off. Repeat. When my Cherokee sits around for a while, I'll do this four or five times, and it starts right up. Hope this helps. -
i thought i had it all figured out! (2wd to 4wd)
partsmj replied to Weezel's topic in MJ Tech: Modification and Repairs
I put a 92 axle into an 89 complete. The line threaded into the 92 hose with no problem. -
The factory TPS for the automatics, PN 33004650 87-90 is now $37 retail. They have around 3800 left in Milwaukee. I will be buying a few for stock. The manual trans TPS PN 33003194 is $129 and about 250 left.
I have never had to change them. I have seen it done. Looked like a lot of work.
Here is some info. http://www.wou.edu/~avorder/Refrigeration.htm
Why not replace the ball joints? http://www.amazon.com/gp/product/B0002S ... e&n=228013 http://replacement.autopartswarehouse.c ... nt&dp=true
I have always had Jeeps from 90 and older and always used the factory setup. As long as the fan comes on, before your Jeep has a Chernobyl meltdown, http://www.chernobyl.com/info.htm you should be ok. If the radiator is in doubt, replace it with the most rows you can find. Two is good, three is better. http://www.radiator.com/conversation.ph ... go%21.y=14 Good luck.
Jeep pic http://www.delawareja.com/gallery/showp ... =8&cat=859 Wharton State Forest aka The Pine Barrens, NJ.
How about this? http://www.rocky-road.com/comanche.html Bolton Rear SOA setup. Rocky Road is the king of bolton SOA systems for any Jeep or other offroad vehicle. We bring this engineering expertise to the Comanche with our unique and bombproof bolton system. Our spring pads 'key' into your existing spring pads under the axle so you cannot mess up your driveline angles. Our SOA springpads are also extra long in design to help combat spring wrap. New Ubolt system and spring plates. No need to worry about salvaging those rusted old Ubolts. Our kit comes with a complete new axle bolt system for the rear SOA setup. I am thinking about this setup. Does anyone know anthing about this?
Thanks. You have saved me a lot of time and money. I will repair the 88 and make that the new commuter Jeep.
Better to wheel than an 89 Cherokee? I have both of these. The Comanche is a 2.5, AX5, LWB, 2WD. The Cherokee is a 4.0, AW4, 4.10's. The plan is Swap in the axles from the Cherokee with a bolt on SOA. Then swap in the 4.0 with an AX-15 conversion with the external slave cylinder, circa 1994+. Use the transfer case with the 94+ trans. Bolt on some 33X10.50's. Go wheelin'. Possible? Yes. I also have a 1989 Cherokee with a 4.0 and a BA10. I am sure it would be much easier to swap in this powertrain. Leave in the 4.10 factory 35 in the Comanche and swap in the front axle 4.10. If it breaks, I'll fix it. Got to start somewhere.
1990 2.5L - VERY tight steering help...
partsmj replied to cmcolfax's topic in MJ Tech: Modification and Repairs
I would check the u joints on the lower shaft, should be easy to take off. or not. -
would you put leaf springs on the front, or weld on brackets and use the factory suspension? with this. http://www.rubiconexpress.com/dynamic/m ... lderid=346
