Location
Layton, Utah
1510 profile views
Fierokid87's Achievements
Can Spell Comanche (2/11)
Its the China front end. Thought it'd be fun to be different. I can always go back if I get tired of it. Or if I come across a Waggy front clip.
Hopefully this winter I'll be able to get it done.
Yes I'm sorta still active. I mainly just lurk around, not much of a poster.. my jeep has been sitting for ~5 years now. Still waiting for me to finish installing a lift kit and doors.
Utah shut down grade schools for the next 2 weeks along with any public gathering and a bunch of companies switched to work from home if double. Spent the last 2 days in the hospital having a baby (okay my wife had a baby) and the hospital was on high alert. Everyone got questioned and sanitized at 1 of 3 entrances/exits and the rest were shut down. Had to re-stock on some things after and had a hard time finding formula, and diapers. Water and toilet paper are also hot items. I'm more worried about mass panic/chaos as apposed to the virus but taking no chances especially with little ones.
It's a good show of skill and a fun way of adding 3rd row seating? Maybe they wanted extra stability when towing their off road trailer? Either way it's interesting. But they should have figured out a way to drive the extra axle also..
where to buy the jeep 2500 front end convertion
Fierokid87 replied to GuzzAuto's topic in MJ Tech: Modification and Repairs
That's where I bought mine was ebay.. I can't even remember what exact term I searched, I was looking for nice new glass headlights.. but this was 2013 or 14? It was like $500.. came with headlights, header panel, and grill insert.. had to modify front fenders around the headlights.. it does require some cutting of inner metals though.. next time I'm at my parents I'll try and take some pictures of it for you if you'd like -
Cummins B3.3 Powered Mj Build!
Fierokid87 replied to krustyballer16's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I think my dad just reused the 2doors when he did the strikers on mine but I can't remember.. jeeps been sitting since I got married 4 years ago.. I'll have to take a peak inside there and see how he did it..- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
IF you can find a 2door, they have extra bracing behind the striker area.. I pulled the striker area sheet metal off a 2 door for mine and found it.. maybe try that or something similar? It goes at like a 45* angle back towards the rear wheels on an xj.. I'm sure something similar with some heavy guage metal would prevent that striker from moving at all..- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Np242 shift fork removal
Fierokid87 replied to Wiggilez's topic in MJ Tech: Modification and Repairs
About 1:40 you can see the sweet spot for prying it out.. that's how I did my dad's ZJ 242 swap/rebuild a few weeks ago.. i used a few of these guys videos and then this write up - https://kevinsoffroad.com/blogs/kevinsoffroad-com-death-wobble-experts-upgraded-factory-parts-20-years-of-experience-info-and-knowledge/249-to-242-swap-by-wes-solitude and it got me through just fine. -
Beat 86 in Utah $250
Fierokid87 posted a topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
1986 Jeep Comanche http://www.ksl.com/auto/listing/4469903 Not sure how much is salvageable on it.. if I had the space/time/money I'd grab it to part out.. -
I'm guessing then It's fuel pressure, either the pump can't supply enough any more, or there's a clog in the lines somewhere..
Is it getting correct fuel pressure? And is it getting spark? I'd Make sure it's getting spark first sense is easy. Then check fuel pressure. Maybe use some either (starter fluid) if it kicks over on that, it's still fuel.
Well, it's still being worked on, just been busy with getting married and buying a house. Front axle is ready to go under, just have to do doors, weld my cross member, and plumb brakes. It still feels so far.
- 17 replies
- BejingLong arm
- paint
(and 1 more)
Tagged with:
Get Bushwackers for the Chevy pickup then? They make some that just go out, not cut up the rest of the Fender I believe. I'm looking into doing the Notch customs flares for my truck. Same as Iceland off road, notch customs got their molds when they went under.
