ggcnash
Everything posted by ggcnash
  1. Looks like I'm gonna have to do some research on the wiring and get something aftermarket or from another vehicle. Sent from my iPhone using Tapatalk
  2. Is there an after market I can run in the coils? Sent from my SAMSUNG-SM-G890A using Tapatalk
  3. K guys got the dash out in a 100 pieces , I ordered new ac evaporator for truck (91 4.0) got ready to put in and there is no temp sensor? Looked on rockauto this is the only one offered? Do I need the sensor I'm assuming I do what to do? The old sensor will not come out it is not removable? Help pls and thanks! Sent from my SAMSUNG-SM-G890A using Tapatalk
  4. Sent PM Sent from my SAMSUNG-SM-G890A using Tapatalk
  5. Bump Sent from my SAMSUNG-SM-G890A using Tapatalk
  6. Did you happen to get a picture of the inside of the housings? I have a pile of 18 gauge sheet and I'm going to attempt to make my own housings. I was wondering how they braced them or added gussets...I did not but I will when I remove them and get them welded[emoji106] Sent from my SAMSUNG-SM-G890A using Tapatalk
  7. Trust me the Comanche would never reach the width to require marker/clearance going by the lines drawn on the floor of the inspection shop in LA not without one tons and clearly it's not gonna be a daily. Also as far as state laws trumping fed law who knows? (But they are selling weed in several states now how's that for trumping fed law!!) Sent from my SAMSUNG-SM-G890A using Tapatalk
  8. Stopped by the inspection place just to ask if I was legal, and it's perfectly legal here in LA someone stated it earlier, it's not wide enough to require side markers. I will also post pics when the body work is done. Sent from my SAMSUNG-SM-G890A using Tapatalk
  9. Bump Sent from my SAMSUNG-SM-G890A using Tapatalk
  10. No resistors needed just new flasher relay under 10$ also I payed 70$ to the door for my multifunctional lights with reverse lights and grommets. Also side markers would be simple and cheap I just choose the smooth side look and as I said louisiana is not tough on inspection.I know 270$ sounds expensive but I sold 3 pairs of stock lights for 200$ and traded the $ off for a pair that are pretty much the last pair you will buy (hence the price) they are beefy. On top of all that I like the look! Wiring also is elementary just splice directly into your existing harness. Sent from my SAMSUNG-SM-G890A using Tapatalk
  11. I've often entertained the idea the obvious swap would be out of a late 90's Dakota almost exact column with column shift. Sent from my SAMSUNG-SM-G890A using Tapatalk
  12. The reason I don't like the idea of that way to go is the fact if you ever need rotors your gonna need to grind out center hole again Sent from my SAMSUNG-SM-G890A using Tapatalk
  13. If interested here is a link a guy used Ford Explorer stuff and parts from teraflex http://www.naxja.org/forum/showthread.php?t=967146 Sent from my SAMSUNG-SM-G890A using Tapatalk
  14. Teraflex kit installed one on dad's D44 everything HB stated is spot on nothing in it is special except backing plates which can be fabbed but why would be my question? Everything else can be purchased at your local parts store in 20 yrs if you still breathing good luck Sent from my SAMSUNG-SM-G890A using Tapatalk
  15. Also for anyone interested in a pair I would go ahead and get a set, you gotta think they probably made one run of these and that's it considering the limited number of comanches out there. Sent from my SAMSUNG-SM-G890A using Tapatalk
  16. Gonna try to get them welded up this week. Sent from my SAMSUNG-SM-G890A using Tapatalk
  17. Like zeb said they are multi functional, as far as side markers not gonna add them these things are bright and LA not real tough on inspection! I am going to add some flush cubes in rear bumper for work lights, but I may wire them as reverse lights too [emoji106] Sent from my SAMSUNG-SM-G890A using Tapatalk
  18. They fit alot better than I thought based previous pics online, with a little patience and washers for spacing they follow the body line almost perfectly! These are perfect for my future end result which is to weld them in place and little filler then paint! Sent from my SAMSUNG-SM-G890A using Tapatalk
  19. Thanks Sent from my SAMSUNG-SM-G890A using Tapatalk
  20. The four door panels manual Sent from my SAMSUNG-SM-G890A using Tapatalk
  21. Bump Sent from my SAMSUNG-SM-G890A using Tapatalk
  22. Same stuff I used looks good! Sent from my SAMSUNG-SM-G890A using Tapatalk
  23. I've had a Bluetop in mine for 2 yrs great battery worth the money! Sent from my SAMSUNG-SM-G890A using Tapatalk
  24. Yes, I was refunded in full
