Everything posted by MiNi Beast
mini beast Project: Stock To Beast!!!
MiNi Beast replied to MiNi Beast's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Well got me a little something for Christmas, new cb set up for the rig, paid $35 to my door for everything. I don't mind ebay every now and then. :yes: -
box 4 rocks kit write up????
MiNi Beast replied to justinquilliam's topic in MJ Tech: Modification and Repairs
really? And has he posted build thread? -
huh yes I see. -
say what? need a little more to the sentence as in to understand who and what your talking about or referring to. -
Now you see my jeep is pretty solid yet. :shake: Yeah I got to go pick me up some sheet for it, I can get floor pans for like $65, but think just do they sheet and call it a day. This is going to be my breaking in project as to me learning how to weld. Will not post pics later. :roll: -
Actually the XJ is consider solid and the closet you can get to rust free up here. And be sides not like I paid for it or anything. -
best your going to get.... Working on mine as well. :thumbsup: http://www.pirate4x4.com/forum/showthread.php?t=577021 -
finished cutting up the floors and got the hole cut to raise the gas tank.
Well got some more done tonight. Rest of the floor cut out in the rear, and the hole cut for the gas tank to be dropped in. Now just debating if I want to cut and open up the fenders or just leave them be, more stock look, being I'm running full size axles and inside of the tire will be flush with the outside of the stock fender flare, I'm thinking I may just leave it and call it a day. If not can cut it out later. My helper working hard... :shake: -
Well just got in, and I got some work done tonight. Cleaned up the shop a little bit and added some insulation, :ack: Then I dropped the gas tank and started to cut out the floors. Go the front section done, now need to measure up so things and make sure how I'm going to raise the gas tank in the rear up into the frame and mount it on the floor. I'm thinking I'll end up doing something of this sort here and perhaps something like this for some sort of skid . Then I'll build a rack to go over it to haul gear. So that's about it of what I got done tonight. Mess with the rear some more tomorrow night. Off to bed now :shake: -
YOu going to @#$%ing do something then @#$%ing do it right the first damn time. Been saying that on the last two rigs, god damn it going to do it this time. I already lost some time other misc things, so I'm not going to lose my rear coil set up. I'm @#$%ing doing it. I want to turn my XJ into something like this inspiration. Got a lead on a set of rear brackets that are from RockKrawler, who puts out the front and rear long arm coil set up like this... same long arm I had on my last jeep and what I'm basing this build off of , and thus making everything myself or ordering the brackets from Ballistic will cut the cost way down, coil mounts for the rear , rear link axle mount setup and can be custom. But the thing I was having problems with was the frame brackets for the rear and that was what was leading me to just settling for the leafs, but @#$% that wasted money, and time can just be the same if I get these, the rear bracket needed to set the triangulated 4 link setup , and bolt these on and set up the rear off these, will take allot of guess work out of it, especially being at my place. Then I have always been partial to rod ends, I have just always liked them. So undecided on what to use either these, BTF Flex joint , Ballistic Premium Rod ends , (costly there), MWC Rod ends , cheaper but I ran there stuff with my steering set up and I was pleased all around with them and their stuff, or there's these, Summitmachine Flex-joints. So that's where I'm at right now and why thing are kinda at a stand still. :thumbsup: -
Got my Ruff stuff diff cover today thanks to Monkeyevil. Good thing to cause I going to need all the protection I can get. :shake: http://www.ruffstuffspecialties.com/cat ... -p-86.html -
shoot you got that here in MI. :rotfl2:
the new plan though, in hopes to make it to the Badlands first weekend of March to wheel with my lover, is to run leafs out back and get things squared away with the long arms and axle swap up front and the doubler, then add the coils later on, $#!& I might even like the leafs yet out back, no problems with them before, just never had the boomerang shackles in which I should of had. -
finish ripping out the interior
well finished ripping out everything on the inside as I need to do some touch up to the floors, and going to be putting in a cage so need it all out anyways. And after breaking 3 torx bits I took out the old carpenter knife and cut out the seat belts. Forget it I'm going with harness belts now. :yes: First pic is of my new place, and I had to makeshift a place to keep the jeep for the winter, and as you can see where I added on. :roll: My helper waiting for me to come back out. :shake: -
how is it plugged in? or is it spliced in? Does it look factory or like someone added it.
:rotfl2: at first I thought your were just a horney idiot. :rotf:
:agree: but I like this one better.... how to post pics
:agree:
I will, I will, nothing much right now just pulled the rear. -
Well finally got the rear end out of the jeep, rear interior gutted, ready to measure and start cutting away to lose some excess weight :yes: -
I could of told you that, why I have an extra icm on the self. :yes:
looking good there CW, no more belly! :thumbsup:
