MancheKid86
Everything posted by MancheKid86
  1. if you know how to do metal bumping, that bedside dent should pop right out if bump'ed properly
  2. got most of the under coating off, still gotta do the bottom, and the top left corner.
  3. flipped her over and took her to the spa :D still gotta remove the rest of that bed liner :fs1: chippin away i lied, i do have pics :roll: stuck the fuse in with the fuse-able links since there was no cap to cover the 80 amp fuse :thumbsup:
  4. great work keep it up :thumbsup: :hijack: i got 2 10" kicker cvr's with a 630w alpine amp :D
  5. for the longest time, we would see this squirrel at my back door, so we gave it a pink scarf to see where it was nesting, about 3 weeks later, i noticed a little spec of pink where the compressor bottle goes. sure enough, when i tore it apart, it was the squirrels nest o_O :headpop: needless to say after that, when ever i would go out side, the squirrel would beak me off, and made it very apparent he wasnt too impressed with me :rotfl2: ohh and i don't know how i missed this :needpics:
  6. hit the back button and leave to the previous page, then click the forward button :thumbsup:
  7. i change mine the day before right when i get off work, makes it seem like nothings changed
  8. wired in my subs, :banana: threw in one of my audio decks, since the touch screen one split my low/mid/high bass into 3 diff settings o_O can't have that now can we? (you don't want that because it will eliminate the other 2 and only put out, the high mid or low, not all 3) no pics
  9. a new meaning to the term ghost car bigger one here XD
  10. haha, looks like ima have to start another thread off :needpics: can't wait to see pics :thumbsup:
  11. i need this! p/o slice the $#!& outta my old wiring, abandonded 3 prongs from the plug, i need to re-wire it back up to par, because i have no dash lights for at night
  12. just did this the other day, took about 30 mins, over 20 mins of that time was on that little clip :fs1: only thing i did different was used a 6" c clamp and held the lock plate down, because the screw driver was damaging it. :thumbsup: also used the part listed above by $500MJ, worked like a charm
  13. viewtopic.php?f=9&t=20204
  14. so, any one got pics of wiring/ a wiring diagram? i need to trace theese wires back and fix these, i have no dash light because of it.
  15. passanger side rocker :rotfl2: tad bit of a joke :yes: :thumbsup: :rotf:
  16. so where is this rust you speak of? :shake:
  17. here's the pics of my sub box :thumbsup: more pics truck, this is how i have the gas tank strapped down how i am able to drive it, connect a wire to the ground of the tank, and bolt here. to my surprise there is a frame under all that crap :banana: almost finished all the grinding :jump: i just need my sheet metal now, then will sand, bondo, prime and paint a bit. oh... and i also salvaged my gas tank straps :chillin: :shake: going to thru some rust converter and make those babies hard as rock. more to come :wrench:
  18. that box is way too big, i bought a box online, turns out the i knew the guy who was selling it :rotf: its 40" L 8" W 13" H i will take pics of it tomorrow :thumbsup: it is fairly simple to build a box, get the sub you want, go online and find the proper cubic feet need for the box, from there its simple, just do the math on the dimensions to get the proper space needed, ive built a few, but i don't have the money tools or even the supplies to make one, to make it even simpler check this out http://www.ajdesigner.com/speaker/index.php :thumbsup:
  19. removed my bed, need my truck moving tho, where is the ground i need to re-locate? do i just run a wire to the frame from where the tail light harness plugs in?
