MancheKid86
Everything posted by MancheKid86
  1. when you upload them on photobucket, click on "customize your upload options" (in the uploading window, below the facebook myspace msn twitter boxes) i use the 640x480 resolution :thumbsup:
  2. lol, missed the tid bit about COG being off (center of gravity) with out the lift, you'd make it fine just like in the pick, with 6 1/2 inch lift, no more comanche :thumbsup: wheres pics!!! ( i know, tomorrow but...) :needpics:
  3. Thanks man! :cheers: I'll post up pics of my lift progress later, off to the garage :wrench: don't be tryin that with your lift installed :thumbsup: your cog will be way different, but id have to agree with comanche country :D
  4. I'm thinkin, locate the brake light wire, and splice it into that? :yes:
  5. any bigger pics? :yes:
  6. especially the large unknown stain in front of seat. :thumbsup: can't be as bad as my unknown stain :rotf:
  7. any replacement weld in patches for the well from the box to the side of the sheet metal? or do i have to get some custom made?
  8. still waiting for my neighbor to get home, then we are going to weld some more up but i like posting pics so here you go this side done for now time to move onto this side :shake: more too come
  9. finally found the wiring diagram in the Renix FSM. and wired in my high beam switch manually, turns out i got the right part sent to me, just the previous owner took a switch out of a 91+ cherokee. will probably weld more metal in tomorrow. :thumbsup:
  10. time for an update? i think so :clapping: been a while (been workin my @$$ off during the day, and partying during the night lmao) also got my lazy @$$ accepted into college and start in sept, going to be an aircraft maintenance engineer mechanic specializing in helicopters :brows: got some time today to do this more cutting :yes: all ground down my neighbor doing his thing (metal bump'in whisperer) tracing out card board cut out for sheet of metal (gave 1/3 inch of metal for overlap for everything except for bottom which is flush) peice of metal after the "nibbler" got ahold of it all bent up drilling holes for spot welds Bart doin his thing all ground down primed before and after
  11. wire up the rear of the 4 door switches to use the front/back winches (if you get some) :D
  12. viewtopic.php?f=7&t=24458&start=0 :thumbsup: I'm not crazy, go4lo was only his CC alais :smart:
  13. got go4lo's build i see, it was great watching him built it up over the month's that truck is worth it :thumbsup: in the end, my jeep will be ending up looking like that, its what inspired my next mj project to look like (which is now slowly happening) only difference is i won't make custom rear panel guard :P can't wait to see more updates on this beauty
  14. besides me, there is only one other person in my town with a comanche. his name is rosko, i know this because he's tried to pick up my mother, but he doesnt have time to go onto comanche club XD
  15. well thank you :yes: its nice to have some feed back on my work :wrench: it wasnt too hard, i disconected my roll bar removed the 8 bolts to the bed then disconected the ebrake, wiring, and dropped the gas tank. i used a 3 foot breaker bar to remove the bolts, make sure you soak them into penetrating solvents. and tighten then un-tighten over and over as you are removing the bolts, this will clear any crud that is caked on the bolts. i broke 4 or 5 of the bed bolts. so i have to pound out the old bolts n coils. i used this gator grip socket to get stripped bolts out, worked like a charm http://s.kmart.com/is/image/Sears/9990000003389511 will be going out of town for about of week, so i will update when i get back finished my license prohibition, so i will be on the road right quick no more stupid drivin for me, thats how i lost my first MJ Mary Jane ***EDIT*** PS. i get my sister to help me lift the truck bed :dunno:
  16. out came the rust converter :chillin: frame all neutralized ripped lower dash out started one fixing the p/o's wiring on the high beam switch
  17. with every inch of lift, you should be able to fit an inch more of tire, stock suspension can run 31's so 2" lift + 31" = 33" tires :yes: can't wait to see more on the soft doors. :D
  18. sorry yo, you missed it by 2 years o_O chrysler decided to delete all record of old vehicles after 21 years
  19. your part of team evil? vKH4wRxCDTg 0:58 in
  20. Not to poop on your parade, but did they remember that the MJ/XJ flywheel isn't flat? It has a convex or concave shape to it that it needs to retain. I forget which... Without it there are usually operational errors. I hope the machine shop knew about this. Rob L. :smart: i was going to say something about this, but i thought it was for the ax-15:?
  21. good ol' factory splices :yes:
  22. started welding patches in, got one of the corners done. will have more pics of it, they are on my neighbors crackberry.
  23. any one have a chart with the bearing numbers? i need to get a re-placement since one of them went, got a bearing press, can do all the work at home, just need the number (have a harbor freight parts book :roll: :yes: will order from there)
