Pete M
Administrators
    114
Everything posted by Pete M
  1. Home at last! I'll start putting the pics together tomorrow night after class. Or maybe during class if it's boring. But right now I'm off to enjoy my nice warm bed in anticipation of NOT waking to the sound of ATVs in the morning. :D Jeep on! --Pete
  2. I uploaded 20 more pics from my harddrive to pituretrail so I finally have more to offer. :D Jeep on! --Pete
  3. You guys can probably park your trailer and tow rig at the campground if you wanted to avoid congestion in the Badlands parking lot. Might cost a couple bucks to be a "visitor", but maybe not since the campground will hardly be crowded. The old guy running the grounds last year had a really nonchalant attitude about everything. 8) What were we doing for lunch? I was just going to bring along peanut butter and honey for sandwiches. Jeep on! --Pete
  4. That's proving to be a tall order. I've gone through about a thousand MJ shots so far and the closest I've seen is a couple lighted sun visors. If I get some more time after I finish packing I'll look through more. I can't imagine I don't have at least one. :( Jeep on! --Pete
  5. Well, it looks like I'm stuck at home tonight. Mike has a stupid quiz tomorrow morning and we'll be leaving as soon as he's done. Should arrive in Attica sometime around 7 or 8 on Friday, hopefully before dark. If anyone that's camping arrives before me, I'll be picking an electrical site furthest away from the majority of the other electric sites (so as to avoid the RVs). Camping is nice and all, but the extension cord for my electric blanket is only so long. 8) Jeep on! --Pete
  6. Oh boy! 57* and rainy! 8) Don't forget your sunsceen! :roll: Jeep on! --Pete
  7. Oil pressure is good, spark plugs were pulled and they are good too. I haven't done a compression test yet since my kit is missing. Visual tests haven't produced any clues as of yet. The fan was my first thought but nothing is making contact (I don't have a shroud at the moment). I don't have to be moving to have the noise. Just sitting there with the clutch disengaged and the noise may appear. The first time I was driving when it appeared and there was no change as I came to a stop and got out of the truck. I actually wish it would come back. That way I could do a more thorough diagnosis. It's not a "marble" in a coffee can, more like a single large bolt. Right now it usually manifests itself as a single thwack, like a snap. I've had plenty of bearings fail on me and this, well, this is different. I wish I could let you all hear it. :( Some of you may get your chance at the PowWow. I think today I'll put it all back together and try my luck getting it to a mechanic to let him hear it. Knowing my luck the noise will go away. :( Jeep on! --Pete
  8. I feel the same way. Lots of skids under there and I'm not done yet. I like the way that the solid Ford tierod easily bends back. :D Jeep on! --Pete
  9. 88 MJ, 190k+ mile 4.0L It's sounds like a cross between a bolt being shaken around in a coffee can and a spoon in a garbage disposal. It doesn't have a particular rhythm to it and it isn't obvious as to precisely where it is being emitted from. I've pulled the oil pan and valve cover and everything looks fine. Nothing broken or loose as far as I can tell and no metal shavings in the pan. The worst part is that it's intermittent. During the first occurrence it was persistent at all rpms, the second time only above idle, now it usually only happens for a short time, sometimes only a single thwack. It sorta sounds like the time when my water pump allowed the impeller to eat away at the housing, but I just now went out and pulled the belt off and it still does it. I'm stumped. Short of stripping down the block, any ideas? Anything else you guys need to know? The truck runs fine before, during and after the noise. It doesn't stutter or anything. I need the truck this weekend for the second annual Comanche Club PowWow. I'm flat-towing it to The Badlands, so I only need it to perform when we're there. But I also don't want to have the block blow up on me in the middle of a trail. I can't fix anything if I can't find a problem! : Jeep on! --Pete Some more back story if you want it: It happened a month ago at a local wheeling event. I hadn't gotten a 1/4 mile away from my tent before the noise started. I pulled over but couldn't precisely locate the source of the noise so I told everyone in my group to carry on without me while I limped back to camp to diagnose the problem. I was thinking the starter gear was maybe touching the flywheel so I pulled it. Everything looked fine so I put it back together to try something else, but the noise had now vanished! I took it for a test drive and everything checked out, so I hooked up with the last group. The truck ran great all day. A couple weeks later (maybe 3 miles later as far as the truck knew since I flat towed it home) the noise came back while in an Autozone parking lot. The shmucks inside came out and were stumped (big shocker there). It drove ok last time the noise happened so I figured I could limp the 1/2 mile home. Before the noise was omnipresent, now it only happened above idle so I tried to keep the rpms as low as possible. About half way home the noise suddenly stopped with a quick squealing sound. Now another week has gone by and I've pulled the valve cover and the oil pan. Everything looks nice and tight. The noise happens only occasionally now, but without finding a problem, I can't fix it or predict whether it'll get worse again. :(
  10. My trans is much higher than 1/2" over stock so I imagine that it'll be fine. Watch the angles and clearances of the t-case shifter linkage. I built a custom bracket setup for my TJ trans, so I don't know how the rise will affect a stock situation. I've never heard of people having problems with the t-case drop kits, so I think you'll be ok. Jeep on! --Pete P.S. I'm genuinely shocked that Rustys hasn't tried it on an MJ!! :shock: They are usually pretty good with their stuff.
  11. I'd never thought about a Renix rev limiter, but I'm quite familiar with the limiter in my mom's PT cruiser and it cuts the power pretty abruptly. Feels like I pushed the clutch in and let off the gas, but I haven't yet. Angers me to no end too 'cause that turbo 2.4 really likes to sing and the limit is found before the tach even gets to the red. Jeep on! --Pete
  12. The computer does different things at WOT, but only above 3k? Thats odd for sure. Jeep on! --Pete
  13. While we're sharing our exhaust systems: Mine is a Borla. Biggest one they made for 2.5" tube. Makes the truck pretty quiet until I step on it. I used to have a flexy pipe for the crossover and tucked it up close to the trans, but that bit the dust (they literally fall apart when even partially crushed) and I've since put in a stock one back in. The pipe is attached to my new trans crossover here: And obviously ends at the rear hanger. I tucked everything up as far as possible and only the very bottom of the muffler hangs below the frame. When I finally get around to building the stroker, I'll have the front half of the exhaust redone by a shop so it doesn't hang down and eliminates the restrictive factory bends. I've had the muffler since before the 4wd swap and lift, and even then saw no reason the exit needed to be behind the rear axle. It's just so much simpler this way. And I like simple. :D Jeep on! --Pete
  14. I took my peugeot apart and it was a blast! Oh wait, you'll probably be using wrenches and pliers, not the sawzall and sledge. Oh well, I'm sure your teardown will be fun too. :D Jeep on! --Pete
  15. MJs and XJs will share that part. As to year, well, I'm betting that it's the same 87-96 and the same 2.5L and 4.0L. Take yours to the yard to make sure. Jeep on! --Pete
  16. How about everyone meet at my tent? Seems to me that the campground was pretty empty last year but the Badlands parking lot was crowded. They open at 9:00am, so that seems as good as any for a meeting time. Can everyone make that? Anyone remember if there is any cell phone coverage there? My number is 313-510-9100 and I have nationwide coverage so feel free to call. How about channel 14 for the CB? Jeep on! --Pete
  17. I'm not certain about the Mobil 1, but AX-15s require a GL-3 rated oil. Or more precisely, they require that we NOT use a GL-5 rated oil. Unless the bottle specifically says something to the contrary, GL-5 rated oils contain sulphor compounds that will eat away at the synchros. GL-3 stuff is hard to find though. Dodge and Jeep dealerships sell it in bottle labeled "for AX-15s". Some synthetic oils are said to be OK too, but they should say something about being safe for yellow metals. This is all compounded by the fact that Jeep put Gl-5 in the older shop manuals. :( Jeep on! --Pete
  18. Pete M
    New Newbie
    This is what I did to my Peugeot: I made little trophies! Seriously though, if topping off the fluid level doesn't help, start looking for that AX-15. The Peugeot is notoriously hard to take apart, expensive to fix, and rarely lasts very long after even a complete rebuild. My theory is that the case deforms over time (or from abuse) and so after all the new parts are installed, the case is still deformed and it's only a matter of time before something goes BANG. I'm basing that theory solely on the incredibly weak looking case though, no actual measurements and data. Jeep on! --Pete
  19. Pete M
    New Newbie
    You're welcome Eagle! Glad you finally made it over. 8) Jeep on! --Pete
  20. I had a 4x75 rms and a 150x1 rms in the MJ in years past. The amps have migrated over to the Dakota R/T, but the door speakers are still in the MJ (didn't fit the Dak). I cut a hole for the tweeter to set it flush in the door. To this day, that truck had one of the best sound I've ever heard in a automobile. Symphonic and live tracks felt like you were there. :D High quality componants (and the power to drive them) are worth every penny in my book. Since the wind noise on the highway can overwhelm my current reciever-driven system, I think I'll put a small amp back in the MJ to help out. Although the ambiance of my truck can be strangely appealing. I drove 3000 miles to Moab and back this summer and only listened to about 3 hours of music total. :D Jeep on! --Pete
  21. :D :lol: :P :D :lol: :P :D :lol: :P
  22. Is the fluid in your tranny topped off? My 2wd Peugeot would always get cranky when the level dropped (which was every 5000 miles or so due to a leaky rear seal). Jeep on! --Pete
  23. Except that there are dozens of common questions and no guarantee that the next question about swapping seats will be exactly like this one. Feel free to remind everyone that we have a search feature, but I prefer to take each case as it comes in. 8) I've never liked post counts so believe me, if I could get rid of it I would. I don't feel they add anything to the discussions. Jeep on! --Pete
  24. I might be driving down on thursday for a bit of light wheeling on friday. Seems a shame to drive allllll that way for only 1 day. But it depends on both my and my friend Mike's schedules. Jeep on! --Pete
  25. For what it's worth (cause they don't exactly tell if it had a tow package or not) car-part.com has a listing for a Dana 35 with 3.73 gears and ABS. There are only 2 pages of listings (and some of those listings aren't even 3.73, cause junkyard guys aren't apparently all that computer-savy) as compared to 150+ pages of 3.55 geared axles. Jeep on! --Pete Welcome aboard Eagle!! :D
