Pete M
Administrators
    114
Everything posted by Pete M
  1. They should at least make it an option. Plenty of us have already hacked off the lower sheetmetal. :D
  2. They should at least make it an option. Plenty of us have already hacked off the lower sheetmetal. :D
  3. Is that a stock C6? Does it run out of gearing?
  4. Is that a stock C6? Does it run out of gearing?
  5. Nope. That's my sister's house. It's down the street at my parent's house. Just keep busting down garage doors and you'll find it eventually. :D
  6. Nope. That's my sister's house. It's down the street at my parent's house. Just keep busting down garage doors and you'll find it eventually. :D
  7. Oh, I'd post one if I had one. No doubt. :D next phase; washing it.
  8. Oh, I'd post one if I had one. No doubt. :D next phase; washing it.
  9. Junkyards. Any XJ 84-96 should have the same part.
  10. Junkyards. Any XJ 84-96 should have the same part.
  11. Welcome!! :wavey: You'll need to host the pictures online and then link to them here. See this post: viewtopic.php?f=6&t=11077 It might be a bit tricky at first, but once you get the hang of it, it's easy. :D
  12. Welcome!! :wavey: You'll need to host the pictures online and then link to them here. See this post: viewtopic.php?f=6&t=11077 It might be a bit tricky at first, but once you get the hang of it, it's easy. :D
  13. Pete M
    New Manche
    I would: -pull up the carpets and check for moisture -replace the battery cables if they are even slightly aged -check the condition of all the front suspension and steering -oil change, air and fuel filters, -trans filter (not a full flush though, I'd just replace what came out when I dropped the pan) -Check the gear oil level in rear axle, -completely bleed out the brakes with new fluid . . .
  14. Pete M
    New Manche
  15. The Haynes manual is prone to, um, "inaccuracies".
  16. The Haynes manual is prone to, um, "inaccuracies".
  17. Finally! I've got a good vector image and it's at the sticker shop. Should be getting them any day now. :D
  18. Finally! I've got a good vector image and it's at the sticker shop. Should be getting them any day now. :D
  19. Update: one tire went flat. That is all. :D
  20. Update: one tire went flat. That is all. :D
  21. I love the "microscope" feature on the Sony T-10. :D
  22. I love the "microscope" feature on the Sony T-10. :D
  23. Pete M
    paint
    For drop cloth, I went to Lowes and bought a roll that was 12 feet wide by like 100 feet long. And I used every inch of it. For under 20 bucks I though tit was a wise purchase since you can cut off sections that are much longer than table cloths.
