garyindiane
Everything posted by garyindiane
where did you guys put your balls?
garyindiane replied to 89eliminator's topic in MJ Tech: Modification and Repairs
Mine took the place of the green turttle bottle when I switched to a open cooling system. -Gary -
Just a update since it has been a while. The beast is down for maintenance. The pukegoet slave finally gave up the ghost. So I am in the process of doing a lot of work to it. New slave cylinder New clutch master All new lines Clutch plate Pressure plate All new u-joints in both shafts New lower shift boot Some exhaust work I found a freeze plug leaking. So I am installing a block heater in its place. Pic Image Not Found IRO adjustible double sheer track bar and bracket Viair OBA guage panel Hopfully soon I will have this thing on the road.
Internal slave hyd line?
garyindiane replied to garyindiane's topic in MJ Tech: Modification and Repairs
Thanks for the information Jeff. I will use you cotter pin method. I do have some good news. My local KOI auto parts is going to try and bend the lines up for me. Their using a quick connect fuel line for the slave side fitting, and it should work great. I will keep ya'll posted in case anyone in the future has the same problem. -Gary -
Thanks, but I need the line from a puegeot BA 10-5 Trans. -Gary -
The input side is flare but the output to slave is ment to be held in with a pin clip. Here is a pic of the lines. You can see where the PO tried to repair the input. Image Not Found I posted in the wanted section hopefully someone has one. viewtopic.php?f=25&t=20983 -Gary -
Hey, I need the input line for the internal slave cylinder. Mine is busted and I can't find one. Paypal preferred. Let me know what ya have and how much shipped to 47016 Pic Image Not Found Thanks, Gary garyindiane@gotsky.com
My new one did not come with the lines :dunno: It figures that the last thing I need I can't find. :doh: I might post in the wanted section. I'm sure with as many people that have upgraded to the AX-15 external setup someone might have one laying around. -Gary -
Hi guys, I need to get the input line for my internal slave. Not the main line. I have it. The line that goes from the main line to the slave. I just saw that the PO tried to half @$$ repair it. I want to replace it before I put my trans back in. So does anyone know where I can get one ASAP? Thanks Gary. :cheers: 89 4.0 Pukegoet
my first trail ride...pics and video.....way too much fun
garyindiane replied to STERLING STINGER's topic in The Pub
That right there is why we get these things... :cheers: -Gary -
It's there to quiet the intake down for soccer moms. Pro: Possibly more airflow. Con: Intake may be a little louder. Gary
Backfiring usually relate to timing. I'll let the others chime in. -Gary
MAP sensor maybe... Maybe these linke will help http://www.lunghd.com/Tech_Articles/Eng ... ostics.htm http://www.pirate4x4.com/tech/billavist ... manual.pdf :hmm: -Gary
Police package idle adjust
garyindiane replied to maddzz1's topic in MJ Tech: Modification and Repairs
Interesting... I did not know that option was available on the renix era jeeps. Just read up on this the other day on jeep forum. http://www.jeepforum.com/forum/f11/exte ... ry-610688/ -Gary -
Might try somthing like this it's for boat steering cables. http://www.discountmarinesupplies.com/L ... _LUBE.html -Gary
:cheers:
Exhaust manifold flange bolts?
Autozone shows this http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?skuDescription=Felpro+/+Exhaust+Flange+Gasket&categoryDisplayName=Exhaust&fromString=&itemIdentifier=225378_3214_5901_&productId=225378&sortType=&parentId=61-0&filterByKeyWord=&isSearchByPartNumber=&navValue=16100530&categoryNValue=&fromWhere=&itemId=530-0&displayName=Exhaust+Flange+Gasket&store=1719&searchText=&brandName=Felpro Quadratec shows one gasket http://www.quadratec.com/products/51404_06.htm :dunno: The one from quadratec looks better. -
Trust me my hands are staind from using so much anti-seize. I do have one more question. I just looked up the donut gasket for the flange and it say their are 2 required? Does anyone know where the other one would go? Do I use one on the down pipe and one on the manifold? I'm just trying to make sure I have everything i need. Thanks-Gary -
Thanks for all the quick replies. Hopefully they will come out easy for me. Thanks again, Gary -
Trailer Wiring for 4 wire and 6 pole receiver
garyindiane replied to Akula69's topic in MJ Tech: DIY Projects and Write-Ups
Very nice write up. -Gary -
Hi, I'm in the process of droping the trans on the beast. When I removed my down pipe the flange bolts broke. My question is are the studs removable. Can I just replace them with some bolts? Grade 5 or better? Specs: 89 4.0L Any help or info will be greatly appreciated. Thanks in advance -Gary
Here is some good links: http://www.naxja.org/forum/showthread.php?t=921205 http://www.lunghd.com/Tech_Articles/Eng ... ostics.htm -Gary
I got... IRO double sheer trackbar and bracket( Pure Beef ) Viair OBA guage and switch panel kit Firestik antenna and bracket Clutch parts: Clutch, Slave cyl, Master cyl, Hyd lines, Pressure plate, New CPS, and all new front and rear shaft U-joints. I have a wonderful wife :D
manual transmission floor boot/seal
garyindiane replied to azscott's topic in MJ Tech: Modification and Repairs
Does this work with the pukegoat? I just found out mine was destroyed yesterday. Thanks in advance... -gary -
Have one at work. I run a soap based product called Polychem. It works great. -Gary
The leafs are different.
