8
Everything posted by mjeff87
you'll need a longer speedo cable. Also, while you have the tranny out, you might want to think about replacing the clutch and pilot bearing, or at least the internal slave (if yours is internal). Also, the RMS on 2.5's cannot be changed without taking off the tranny. You'll have to remove the flywheel to get to it, but it's a $5 seal that you'll kick yourself over if you don't replace it and it goes south later on down the road. There's also a freezeplug at the back of the engine you might want to inspect and replace if it even looks suspect. Jeff
need some slip for my yoke :(
mjeff87 replied to mjeff87's topic in MJ Tech: Modification and Repairs
That sounds plausible. Maybe someone on here is running that combo and can measure for ya.... *side note* had my first experience with the new locker in the rain this morning on the way to work......that was interesting ;) -
yup You can usually trust NAPA for them if you don't want to interweb them. I had the driveline shop press in two new ones Monday when they cut my driveshaft down (yeah, I'm getting lazy in my old age). $12 ea for greasables, but they wanted to upsell me to the Spicer sealed ones, which were $4 more. I didn't take the bait. Jeff
How Sophisticated is the 2.5 TBI?
mjeff87 replied to Joe Jeep's topic in MJ Tech: Modification and Repairs
It's a fairly simple system, injector pulse length is controlled by a handful of sensors: O2, coolant temp, MAP, MAT, and TPS feed info to the ECU, which in turn controls the injector. Make sure the vac line to the MAP (sensor bolted to the firewall with a little cover over it) is intact, replace the O2 sensor, and don't get the TPS wet and you'll be good. Jeff -
also, just remembered, if his 86 has a neutral safety switch, you'll have to bypass it. On my buddy's YJ, all we had to do was ground the center wire (3 wire connector). You may not have the same backup light switch wiring either. You'll have to get creative with that to make them work. The b/u switch on the AX5 is on the passenger side below the shift tower. It's a 2 wire switch if I remember. Have fun! Jeff
crossmember will work but you'll need the manual tranny mount. I helped a buddy do the same swap on his YJ, and the pedal assembly is a complete unit that bolts into the lower dash....I don't think it would work on an MJ. Not sure about the driveshafts, either. My 87 is the same setup but it's a shortbed, and the stock driveshaft (rear) is 47" center to center of the JU caps. Jeff
I have a YJ yoke (somewhere) I thought about putting on, but that yoke is riding at the same distance it used to before I got it (judging by the wear mark on it). I'm only running this setup on the road now to break the new gears in. -
Had one of my spare shafts cut down 1 ¼” today: Image Not Found Image Not Found Got the slip back I needed: Image Not Found -
Smooth as a smacked baby's @$$, I'm quite surpised actually. For search purposes, a SWB MJ with a 2.5/AX5 and D44 requires a 46" driveshaft.... When Pat welded on the SOA perches, we set them to the same angle. Hopefully it'll be just as smooth when the springs are on top. If not, I can add shims. -
Finally hung the D44 under the MJ today. Put it in SUA for now, to run it around a few hunderdt miles to break the gears and bearings in (then I'll SOA it). Good news is it went in well, and runs nice and smooth. Powertrax is virtually invisible, so long as I don't hit the gas around a sharp turn :D Bad news is that the D44 pinion is exactly 1" longer than the D35 pinion......I've only got about 3/8" travel in the slip yoke. Once I SOA it, the driveshaft (stock, 47") will be perfect, but for now it's not so good. I've got a spare shaft (thanks Nate!) I'm gonna take up to a shop tomorrow and have cut down. Jeff D44 under, finally Image Not Found not so good.... :oops: Image Not Found
you can swap that tranny (AX4) with virtually the same unit that has an overdrive gear (AX5). That will bring down the highway rpm's some... Jeff
another set of V8 GC coils, another Selectrac vaccuum switch, and something I can't say right now. Somebody else has first dibs on it. There was a bunch of other stuff I could have grabbed, but I wasn't equipped, and had no way of getting it all back down to VA in my wife's new car :D Jeff
the cables from the splitter under the bed are the same length regardless of bed size, and year, throughout all production models. The only cable that has a different length is the forward one, from the pedal inside the cab to the splitter.....different sizes for SB vs. LB $120 PER CABLE (or even both, for that matter)????? Yikes! What's yer mailing address....we can get you a set over here and ship 'em over to ya ;) Jeff
Just got back into town about a couple hours ago.....wife and I were in Philly since Saturday. Went up to Harry's U-pull in Hazelton yesterday with her uncle....found some treasures :brows: Game plan is to swap the '44 under the MJ this weekend, still SUA, and run it around here for a couple hundred miles to break the gearset in. Then I'll come on down Pat, and SOA it, probably in about 3 weeks or so. Gonna grub up and hit the sack now. :chillin: Jeff
88 mj Pioneer cooling/vacuum line problems.
mjeff87 replied to Mobius1's topic in MJ Tech: Modification and Repairs
The two pics on the left are the idle speed control for the power steering pump. It bumps the idle up a tiny bit when the wheel is turned. The red wire coming out of the loom behind the alternator is the positive lead for the A/C compressor for A/C equipped models. Not sure what the wire is under the cover there....mine has one as well. And Pete is spot on with the headlight switch. Replace it and I bet you get your backlighting back. Jeff -
I've got those same wheels on 31's now on the MJ. I wondered how they would look blacked out..... Thanks for giving me another project to add to the to-do list :yes: Jeff
Yes, the fuseblock under the dash. Fuse #8, 7.5A (I've got a 5A in mine for some reason :nuts: ). Problem with mine was the clips that hold the fuse blades in were/are partially corroded, thanks to a leaking clutch M/C in the past that coated my fusebox with brake fluid. Wiggle it around a bit and see if it's not making full contact. I doubt all the bulbs blew, because there are about 8 or 10 of them that backlight the cluster. They are fed power by an orange wire with black tracer on the left side multi-pin connector on the back of the cluster. That power wire comes out of the headlight switch. For the two lines off your valve cover....the big one in the front goes to the side of the airbox, to *theoretically* let clean air in the top side of the engine. The small line on the rear of the cover goes to a small vaccuum port on the base of the TB, left-hand side if you're looking at it from the front. It's supposed to pull crankcase vapors back out of the top end back into the manifold to be reburned. Jeff Image Not Found -
Not trying to sound stupid, but there are factory holes in the rear framerails right there. Why they are there I don't know, but they are. Is that what you are talking about?
We need to know what engine you're working on...2.8 V6, 2.5 or 4.0 before we can diagnose properly. For the dash lights, start by checking the 5A instrument light fuse in the fuseblock. If it's good, wiggle it around a bit...it may have intermittent contact. I had the same problem and wasted days of troubleshooting it until one evening, when it was dark out, I wiggled it and saw tiny flashes behind the fuseblock. Never would have seen it if it weren't dark out :D Jeff -
Just make sure Fed Ex's insurance that you purchase will cover it, since you packed it yourself. I know the bastids at UPS won't cover anything unless they package it (and charge you up the wazoo for it......) I hate UPS..... Jeff
and I've got ZJ steering (tie rod) on my MJ...bolts in directly. Only difference is the ZJ rod has an adjusting sleeve at the TRE end, and the XJ/MJ doesn't. I just set the length to match the old rod and bolted it in. Jeff
You still have an old fashioned timing light stashed somewhere? (I did, but gave it to my neighbor :D ) Hook it up and see if you are getting spark, and troubleshoot from there. If'n ya got spark, pull a plug and see what they look like. My neighbor wheeled his brandy-spankin new 7 HP Honda mower over to me last night because it "just died" on him. He was giving it to me and going to get a new one. Five minutes later and a freshly filed spark plug, and I gave him his mower back :roll: CPS's differ from auto to manual, although I don't know exactly what the difference is.....maybe you picked up the wrong one and the tip is too far from the trigger wheel, or flywheel (?) Jeff
Did a little internet research and found out the patent for the design was issued in 1931 to J.H. Williams Co., who manufactured the "Williams No. 1999 eight-way socket wrench". They supplied Craftsman, who released the revised version you see in 1954. It was available until 1968. Her grandfather wasn't a very mechanical guy, and this tool is in really good shape. Even being 12 pt, none of the points on any of the sizes is worn down at all. Don't think I'll use it much.....just hang onto it in his memory, along with his pocketknife. Jeff
that's 512tr's table He is a CC member Jeff
My wife and I spent Saturday up in PA going thru her grandparent’s estate, and among other things, I stumbled across this Craftsman wrench. Not sure how old it is, but I’ve never seen one before (and I’m 37 :D)….it’s eight 12 pt. wrenches in one (all SAE, from 7/16” to 7/8”). Thought some of y’all might find it interesting. Jeff Image Not Found Image Not Found
