mjeff87
    8
Everything posted by mjeff87
  1. No, but I was starting to think that.... I put the heat gun on it this morning after a 30 min drive into the office. Upper radiator temp is about 180-185, and the head right where the sensor screws in is running 195-200. I tried to get a reading on the lower rad hose but couldn't get an accurate one. Lots of spinny things in the way and I have good clothes on :D Think I'll put the old sensor back in, and maybe try to "adjust" the needle on the gauge. Jeff
  2. Like CW, I usually remove the washer resivoir to gain access. Either that or use a crow's foot wrench (if you have one). Jeff
  3. This is where it read with the sensor from the junkyard. I just shut it off right before I took that pic (not too shabby oil pressure for a 180K 2.5L, eh?) With the brand spankin' new sensor it floates up about 1/2 way into the red (actually made it worse). I guess the sweep right is normal, then? I've got the heat gun...gonna get a real read tonite after work. Jeff Image Not Found
  4. When mine sweeps right, it goes way right, like to about the 3 o'clock position :cry:
  5. One tiny problem with the full gauge cluster I swapped in last week....the temp gauge is reading too high, like 260 degrees when fully warmed up. All other gauges work fine, BTW. I pulled the cluster from a 90 MJ (non-HO so the wiring has the same polarity), 4.0L, and grabbed both the oil and temp sending units and swapped them onto my 2.5L. With the 4.0 sensor, the gauge read from 160 to 240, so I ponied up and bought a new sending unit and put it in yesterday. Now it reads 180 to 260 (almost pegged).... Also, when starting up, the needle pegs waaaayy past 260 while cranking, then drops back to 180-ish when it starts. By comparison, the OP gauge zeros itself with key-on, then springs right up to 60-65 psi when started and running. I did pull the plastic bezel off the cluster and cleaned all the gauge faces carefully when I got it....I'm thinking I may have futzed the needle on the temp gauge accidentally. I've got a heat gun here at work to borow tonight and see what the actual temp really is when hot, then maybe pull the bezel off and push the needle a bit to match. For those of you with gauges, what does your temp gauge do when you hit the key, sweep far right, far left, or not move at all? Jeff edit: you can watch and see when the tstat opens, so I know everything's working like it's supposed to. Just seems like the gauge is registering about 40-60 degrees too high.
  6. Thanks Pat.....I've been looking for a new sig quote :D Jeff
  7. Check the bottom of Jim's page: http://www.yuccaman.com/jeep/re_db.html HTH, Jeff
  8. Just make sure you incorporate that bling-bling grill into the build. 20 extra style points for that :D (I sawed a YJ frame into thirds with the sawzall and thought I was the cat's azz....but that doesn't even compare to cutting an XJ in half with a plasma cutter ) Jeff
  9. FYI...I just met up with a local board member today after work (VA Jim), and he just SOA'd his shortbed MJ with stock D44. Pulled the tape measure out and figured out he got roughly 5-5.5" of lift. HTH, Jeff
  10. You could use the factory tow bar piece (that I was lucky enough to find at the U-pull for $7...didn't know what it was at the time but grabbed it because it did just what you're talking about). Or fab up one of your own, but omitting the small receiver ends for a cleaner look. Jeff Image Not Found
  11. The YJ yoke is only marginally longer than the XJ/MJ one, about ½ - 5/8 inch. But, the inside of the yoke isn’t fully splined, so what you gain in length you loose in spline engagement. The real beauty of the YJ yoke is the yoke shoulders have more space in them, allowing greater driveshaft angle. Here’s a couple pics (sorry for the blurriness…I was just learning how to use a dig cam back when I took them :oops: Jeff YJ on left, XJ/MJ on right: Image Not Found splines: Image Not Found
  12. mjeff87
    sad news
    Thanks guys. It was expected....she had a massive stroke right out of the blue a couple Fridays ago. About 75% of her brain died, and she had a DNR that was executed the next day. Surprisingly, she stayed alive over a week, on nothing more than IV morphine. She's finally at peace now. I'l pass on your sentiments to my wife. We'll be leaving for PA later this afternoon. Jeff
  13. There were 4 of them down there yesterday. The one I got (because it had the closest mileage on it to my original) had a dark gray overlay, but I swapped the black one out of my original cluster. I suppose you could spray paint it if you wanted (the overlay, not the gauges). $13.99, all day...every day Jeff
  14. mjeff87
    sad news
    For those that knew about it, my wife's grandmother finally passed away early yesterday morning. We'll be in PA from later on today until Thursday, then back to VA for a day, and back up to PA for the weekend for my brother's wedding (I'm da best man....). Gonna be another long week. If anyone needs to get hold of me, PM me or call me on my cell. Hopefully I'll be able to get internet access whille we're up there. Have a good week, y'all! Jeff
  15. Swapped out my idiot light cluster for a full gauge cluster with tach yesterday . I got the sensors for the coolant and oil pressure and put those in too, and everything works (yay). Literally a plug-and-play operation, but I’m gonna spring for new sending units because the coolant gauge is reading in the 240-250 range, and oil pressure is anywhere from 40-85 psi. I don’t think that’s quite accurate LOL :roll: . But the tach and the voltage gauge work fine, and the bonus is I now have a resettable trip-odometer! (and the new cluster has about 4K less miles on it than the old one) Jeff Old cluster, yuck!: Image Not Found One style of speedometer end (I forgot to get a pic of the corresponding cable end, but will soon): Image Not Found new cluster: Image Not Found Image Not Found
  16. probably leftover inventory :nuts: I'll see if I can't get you any of that from down here. I haven't been to the 'yard in at least 2 months :mad: for one reason or another, and my neighbor says there's a 2WD longbed down there now. Mebbe it's got what you're looking for (but I'll check the XJ's too). Jeff
  17. JIC you didn't know, black interiors were an AMC-only thing, so you need not look at anything post-'87 in your search for replacement interior parts. I've got all black, and it's a pain for me to find interior parts down here in VA....that's why I'm taking such good care of the original stuff! I grabbed those XJ buckets over a year ago when I saw 'em (same ones as you have), and stashed them away until I could get around to installing them. Hopefully, I'll get a chance to run down to the 'yard tomorrow sometime. I can look-see if there's any black stuff in there, just let me know what you're still looking for..... Jeff
  18. Therin lies the rub....for me, at least...I think ;)
  19. yupyup...thanks for the reminder :cheers:
  20. Yeah, I made sure of that....they're the same style as the ones that were on the YJ the wheels came from. Both the stock steelies and these aluminums have the same tapered seat But I'm gonna spring for a new set of them, seeing as mine have been with me since I got the truck and are a tad rusted/chewed up. I should do it right and get new studs too, I suppose. I can get 1/2" longer ones to boot, just for peace of mind. Jeff
  21. The mounts are virtually the same, except the top bolt. 84-96's top bolts are parallel with the ground and screw in from the back of the bracket, while 97+ are perpendicular and bolt from the top of the bumper down. Not a problem, just have to drill a new hole thru the bumper, or else make sure you grab the brackets along with it. Both brackets screw into the same 3 holes in the framerail. Kinda the same situation, I was running a set of 97 tow hooks/brackets on my MJ with the stock 87 bumper, and all I had to do was notch out the bumper a hair above the brackets, and drill 2 holes for the upper bolts. Jeff
  22. Just got home a bit ago...none of the lugs loosened. I pulled one off both the front and the rear and rethreaded them, and got about 8 1/4 turns on them until they seated, plus another 3/4 turn or so until they torqued to spec. So I suppose they're ok (?) Maybe it's just a depth perception thing, since these aluminum wheels are recessed so much....I dunno. But, if they ain't flown off yet after a 70+ mile roundrip on the interstate, I'm thinking they're good to go :D Kinda hard to get a good pic, but this is what I gots. They're '94-'95 YJ wheels on an '87 XJ D30 (the studs are centered although the bottom pic looks like they aren't...I had to angle the camera lens to get a pic of the stud length: Image Not Found Image Not Found
  23. I'm thinking it's just that, finally, my MJ is looking a bit less like a big pile of @$$, and she's a little more willing to be seen in it, or have the neighbors see it sitting in the driveway...... :chillin: To break it down, she's "big city", and I'm "big country". It's a yin-yang kinda thing. Whatever it is, it works for us Jeff
  24. For those that don't know the history of me and my MJ, long story short is that my wife really doesn't like it. Tolerates it is a more fitting description. BUT..... Last night after dinner, she says the new shoes I put on look really nice, and she said "you really need to finish lifting the front and get rid of that dumb looking rake it has. It's really noticeable now, with the AT's on" verbatim, I swear I was speechless...... Jeff
  25. For some reason, stuck in my mind is a guideline of thread engagement on the stud should be at least 2X the diameter thickness of the stud. Not sure where I picked that up from, but it sounds good :D I've got about 3/4" of stud exposed with these alum wheels, whereas I had about an inch with the stock steel wheels. I didn't count turns, but IIRC I did get at least 5 when tightening (it's raining now, and I ain't going out to unthread one and count, but will later). I drove it to work this morning, about 35 miles, and am gonna check them with the torque wrench at lunch. Thanks! Jeff
