mjeff87
    8
Everything posted by mjeff87
  1. Thanks Twisty...it's a work in progress (which will probably never be "done") Pat, I've already been bit by the inchitis bug.....I want 33's now :D Between them, the lift, and the new seat position with the buckets, I'm gonna get nosebleeds sitting up so high LOL
  2. John (and anyone else that's considering a tucked in bumper), to do a flush-mount bumper, you'll have to cut out the body panel beneath the tailgate, and loose the spare tire winch. To keep the spare still underneath, you'll have to get creative and make a new cradle or something to hold it there, and it'll probably be too low to be practical. This didn't bother me (I just tossed the spare in the bed for now), and am planning to use the little bit of space left under the bed for an OBA tank. Here’s what I cut out, and a shot of what room is left: Jeff Starting out: Image Not Found cut out: Image Not Found finished: Image Not Found
  3. Pong Fabrications, Inc. :D Pat (pingpong) made it for his longbed, and I adapted it, so to speak, for my shortbed. Drop him a PM.....he's starting to mass produce them, couple different versions depending on what you're looking for. I might get to guinea-pig some of them, maybe :brows: Jeff
  4. Thanks....I haven't had it up to speed yet, just around the neighborhood carrying a torque wrench, and the lugs haven't loosened up yet (knock on wood). I'm not completely comfortable with the amount of thread engagement with these aluminum wheels....yet. But so far, I'm staying in gears longer than I did with the 235's (not sure how off the speedo is either). Been in PA alot lately, we're about to have a death in my wife's family and will be going back up for the funeral, probably sometime midweek, so I don't know when I'll get back to wrenching on it. Sucks to have something half-done.... Jeff
  5. I haven’t been around much lately :cry: , thanks to work and some family issues, but I did manage to get a few hours in on the MJ this weekend. I got my $100 BFG’s mounted on a set of aluminum YJ wheels, and got ‘em on. Here’s me getting back from the tire shop…had to get the old rubber off the YJ wheels and get the 31’s mounted. Tires??? I got tires! Image Not Found Here they are installed: Image Not Found They “just” fit with the 2WD springs: Image Not Found If all goes well (which it probably won’t), I can get the front lifted this weekend. I’m going with a set of ZJ springs, WJ LCA’s, the ACOS, 2” bumpstops, new brakelines and a set of Rancho’s all the way around. If I manage to get it all done, I’ll post up some more pics. Jeff
  6. mjeff87
    ACOS....
    Interesting.....wonder how much $$$ (?) offroader461- nice pics, thanks. It's funny, too, because I'll be installing a set of Rancho's and BFG AT's when I put these in...same setup as yours LOL. Jeff
  7. mjeff87
    ACOS....
    :brows: :brows: :brows:
  8. mjeff87
    ACOS....
    Just scored a set of almost-brandy-spankin'-new ACOS from a local club down here for a Benjamin and a case of Bud Light. Now I don't have any excuse not to get the front end lifted to match the rear..... :cheers: but I have to go to Philly this weekend with the wife. No Jeep for me :headpop: Jeff
  9. or check UNL1MTD on here. He had a set off a parts MJ he was selling...not sure if he's still got 'em or not, though. That was a couple weeks ago. Jeff
  10. Well, there ya go.....mystery wire solved :D Id'a never guessed it was a second horn wire....never knew it was an option :nuts: Kenny, I learned something today..... Now you got me thinking about adding a second horn to my MJ! Jeff
  11. You do sidework writing for Haynes/Chilton's? :rotf: Jeff
  12. mjeff87
    Hi Guys
    RIck 'ol boy....how are ya???? Good to see you here. Stick around a bit, beer's in the fridge.... :cheers: Jeff
  13. The AX5 in my MJ is about in the same shape as yours. It's got over 210K on it, and it sounds like a can of marbles in anything over 2nd gear, especially when coasting. But, it still pulls fine (knocks on wood). I just picked up another one from UNL1MTD last week that I'm going to clean up and swap in, sometime.... Jeff
  14. I've got now two spare 2.5/AX5 rear driveshafts, in addition to the one currently under the MJ (yes, I'm a packrat....) Problem is that there all from D35 rears. I've got a '44 going in shortly, and can measure the pinion length difference between it and a '35, and measure one of the shafts if you want me to. Then you can just do some math and see what you need. IIRC, the pinion is 5/8” longer but don’t quote me on that. I’m hoping that when I put mine in, the driveshaft will remain the same because of lift. When I swapped the springpacks and got that 3” lift in the rear, I noticed my slipyoke pulled out about ½” or so. Hopefully it’ll all balance out (but if it doesn’t I have 3 driveshafts to choose to cut down :D) Jeff
  15. yep, overflow for one thing. Also, water run as black and murky as you have ever seen, and there were some verrrryy strange sounds coming from the plumbing inside the walls and ceilings. God only knows what all broke, but there were alot of service vans and maintenence people running around the rest of the day. Heh, that was almost 20 years ago, and I remember it like it was yesterday.....good times.
  16. synchronized toilet flush......and make sure you get the females involved too. Count the number of heads in your school and find that number of accomplices to man each one. At precisely the same time, EVERYONE flushes, then runs. It is destructive, though. I can vouch for that :brows: Jeff edit: this message will self-destruct in 10 seconds......
  17. The driverside has a tiny lean to it toward the door, but I think I lost the little shims/washers for it when I pulled the bench out....I space it back up level on the final install. The black vinyl bench absolutely sucked in the summertime, and I'm glad the seats are fabric. Hopefully the won't get as skin-burning hot. Probably won't install the full center console, but I noticed driving it to work today that I need some kinda armrest in the center for longer trips. I might homebrew something or adapt something out of the junkyard for inbetween the seats. I kinda like seeing all that floor now....kinda like riding in a YJ...kinda....:) Jeff
  18. I just stabbed them in in a fit of "git-'er-dun" emotion . I got the bench bracket I needed from Sean (that was holding up the whole install), and decided to see how it all fit up. Everything is coming back out, once I determine the final ride height, and getting sandblasted and repainted before it goes in for the final install. I was just so giddy that I finally got 'em in that I had to post up some pics :D
  19. I think they'd be too tall for you. The one minor thing I've noticed (other than thwacking my skull on the door frame getting out a couple times) is there's alot less space between the seat bottom and the bottom of the steering wheel (even with the seat rocked the whole way back). Not so much an issue now, because it's summer and I'm wearing shorts, but come wintertime, with long pants/long coat it may cause problems. It sure is different sitting that high up inside the cab, though. Feels a bit "tipsy", even though nothing has changed but the seat height. Oh, and I also had the flip the rearview mirror over so I could sight out the rear window. Wish I had put the CC sticker on the bottom of the window, not the top across the center. It's right in the sightline now.... :D If I end up getting down to Pat's place anytime soon, maybe we can meet up somewhere and you can do a test-sit. Jeff
  20. and 86's were all longbeds, too. Jeff
  21. mjeff87
    Back home
    Welcome home Cole. Glad you made it o.k. :USAflag: :cheers: Jeff
  22. Yeah, I got that on, but it turns out I need the rear plastic clippy thing that the handle attaches to. Can you pull that off before you send the MJ away? Jeff
  23. Spent some quality MJ time this weekend. First, on Sunday, went up and met Sean (UNL1MTD) and tore apart his parts MJ…..got the tranny, TC, driveshafts, and some miscellaneous other stuff :cheers: Then yesterday, I got all inspired and mounted up the XJ buckets I pulled out of the junkyard last year. They’ve been sitting under the house all this time because I needed a driverside bench bracket. Mine’s trashed, and luckily Sean had a good one. Suffice to say, swapping brackets is a PITA, especially doing them in the driveway on a sunny 94 degree summer day. My weapon of choice was the angle grinder and punch to get the rivets out (almost set my lawn on fire, though….) The XJ rocker buckets do indeed sit a couple inches higher, but they’re not so bad. I’m only 5’8” and still have plenty of headroom, but if you were taller I don’t think it would be comfortable. I got the rockers because they were in great shape, and black (you know how hard it is to find black interior parts???). If I decide I don’t like ‘em that high, I’m gonna cut and weld/bolt the front bracket to bring the ride height down some, but so far I like them the way they are. I just have to remember to duck my head a bit getting out (already found that out the hard way). Here’s a couple pics….I still need the bracket cover for the driver side, but you can see how the bench brackets bolt to the slider. I also repainted the grill and headlight bezels, and mounted the front plate with a plastic bracket I got from Sean also. Jeff Driver side: Image Not Found passenger side: Image Not Found driver side bracket (missing the cover): Image Not Found passenger bracket: Image Not Found I love spraypaint: Image Not Found
  24. It's a generally accepted fact that XJ/MJ stock brake systems are inadequate (that's putting it nicely :D ). Larger than stock tires only make it worse. One thing to check is rear brake adjustment. The self-adjusters tend to not self-adjust very well......once you have the rears adjusted, bleed the entire system. That should help, some. Jeff
  25. It's inside the cab. Look under the dash beneath the glovebox for where the blower housing is. There will be a long, flat 4 wire connector plugged into the housing. The connector is plugged into the resistor. HTH, Jeff
