mjeff87
    8
Everything posted by mjeff87
  1. Well, I didn't measure before and after, but I do know that with 31's on it, the rear flares are 37" from the ground (fronts are 36"). From the rear, if I lean on the tailgate, the top of it is armpit height on me, and I'm 5'8". I'd say altogether the SOA netted about 5.75 to 6" of total lift 8) As far as time goes, it only took about a half a day (and an 18 pak of Bud Light), but I've been planning this build for a good while now, and had most everything in hand, parts-wise, before we started. Even with all the pre-planning, I've still got a few issues to deal with post lift.
  2. Don, you just missed the big annual Urbana Oyster Festival this weekend. Estimated 100,000 in attendance. and cops everywhere. and me driving my hoopty MJ right past it all....... 8) Jeff
  3. :razz: I wasn't gonna mention that......
  4. Thanks! We welded the new perches parallel with the old ones (the stock SUA ones are still on the tubes) to keep the same stock pinion angle which is about 7 degrees. Didn't install any shims, and there's only a tiny vibe between 38-42 mph. But, I think that is being caused by the rear UJ which I didn't change out. Put a new one on the front because I swapped in a YJ yoke, but was too lazy to replace the rear one. I'm gonna swap it out later this week and see what happens. Even if it's not the UJ, the vibe is so minor that I don't think I'm going to worry about it right now. On the AAL, you're gonna be hella high if you leave it in I would think. The SOA netted a good 5" in the rear, and I have those ACOS spun down as far as they will go and the front is still about 1" lower. Those are V8 ZJ coils in the front, which got me a good 2" of lift just by themselves (mine's a 2.5L), but they are really compressed now as they sit. Crazy amount of extension yes, but I think I'll end up redoing the front with taller springs. I've got a set of 5.5" TJ coils at my disposal...I think those along with the ACOS collapsed will do the trick. But for now, it's all functional. Jeff
  5. I can X2 on the bracket differences..... My rear bumper came off Pat's Pong. He built it to fit Pong, which is (was?) a longbed, using the factory brackets. Just like Tracker said, when I tried to mount it, I had to cut off the rear part of the framerail and notch both sides so the brackets would line up. Angle grinder and sawzall, 'bout 20 minutes after I figured out where and what to cut ;) Jeff
  6. mjeff87
    Jeff
    Yeah.....now all I have to do is paint everything :chillin:
  7. I stopped once in West Point to do a visual, and the front pinion seemed hot but not too hot so I kept going. Got on the interstate and rode it up to the 106 exit, got off and pulled into a truckstop/gas station. Troopers gave me a few compliments, and even asked if I wanted them to call for help ;)
  8. Spent Saturday down at Pat’s house springing over the MJ and drinking beer :D We bumped it up on his trailer and did the rear first. I opted to leave the e-brake cables and brake line connected and just remove the leaves…..I’m sick of bleeding brakes (see my other thread about the XJ booster install last weekend). Got the rear done in about a half hour: A shot of Pat’s better side LOL Image Not Found Image Not Found Then we moved on to the front. Pat’s knowledge and trailer straps made the job go pretty smooth. Kept the wheels on to replace the LCA’s (1” longer than stock), which centered the wheels in the wheelwells perfectly: Image Not Found Passenger side, with new LCA: Image Not Found Driver side, with stock LCA: Image Not Found I spun the ACOS down as far as they would adjust, (still have about a 1” rake which I wanted), and reseated the springs: Image Not Found Image Not Found Then we installed the RE adjustable trackbar and bracket, after the ride height was set: Image Not Found I had already installed longer front shocks which I “thought” would be long enough, but they weren’t. Pat dug thru his parts pile and found a set that would fit to get me home :cheers: Image Not Found Couple shots of Pat’s XJ museum. I purposely didn’t take a pic of Pong…..it doesn’t need to be seen in the shape it’s currently in (under construction):D Image Not Found Image Not Found Image Not Found Image Not Found I still have lots of little bugs to work out, mainly in the front end. I NEED longer UCA’s……caster right now is about 10 degrees :oops: and I actually had to stop halfway home and pull the front driveshaft because of the funky pinion angle. Once I get the UCA’s in and caster/pinion angle back, I need a set of disco’s or at least extended sway bar links (my sway bar is verrrry unhappy with me right now). Also need front shocks, and have to figure out what to do for rear shocks. We tried reusing the MJ spring plates on top of the packs, but that puts the lower mount too close to the upper, about 14”. I put my stock shocks back on just to get home, but they bottomed out on just about every bump I hit. I took them back out and ran around yesterday with no shocks…..very interesting experience to say the least. I’ve got a local shop ordering me in a set of shorties (11”/17”, for an Exploder I think) today just to get around, but ultimately I’m going to have to get the lower mounts back on the tube and get some longer shocks. Also, the Dakota rear line is too short at full flex, so I either have to replace that with something longer or extend the hard line down off the frame some. And the YJ front lines are just barely long enough...I'm going to drop the hard lines a bit on the framerails or add some extensions. All things considered, I’m very happy with the results so far. Either 33” MT’s or 34X9.5’s are in the near future. Jeff
  9. It's the centering ball in the front DS. Trust me......I almost blew mine up yesterday, and it was making the same squeak sound (plus some scary grinding noises :D) I stopped at a podunk gas station and pulled the front shaft out.......while two state troopers asked me what I was doing :chillin: Jeff
  10. mjeff87
    Jeff
    baby MJ growed up a bit....... :D I'll start a new thread tomorrow, but here's a pic of how it sits now. Pat............... :cheers: Jeff Image Not Found Image Not Found
  11. or you can pull the CAD motor and shim the shift fork over with some flat washers, a hose clamp, or whatever else you can find that'll work. Here's mine with the washer method: Jeff Image Not Found
  12. Can't speak to the front, but I just locked my rear. Yes, there is torque steer, but it's only something you have to get used to while on-road. It's predicatable, and aviodable once you get used to it (as in when upshifting, let the clutch engage fully before hitting the gas). I'd imagine it'd be less noticeable with an automatic. Jeff
  13. I don't think it matters, all the contact switch does is close the circuit.
  14. It's the center set of wires, pink and white. Jeff Image Not Found
  15. you really have to press down hard on that cup.....there's a spring underneath it. Plus it's likely to be slippery from gear oil, and it's a tight space to work in. But it'll depress, eventually... Jeff
  16. I bumped uglies with a ZJ on the interstate and caved my driver side door in a couple years ago. I used a kitchen plunger to pop it back out. Not perfect, but good enough :D Try that first and see what happens. Jeff
  17. Since you said 4.0L, you're talking about either an AX15 or the BA 10/5.... The AX15 (and AX5) shifter is held in the shifter tower housing with a spring-loaded cup. Remove the rubber boot that's bolted to the tranny hump floorboard and press straight down on either side of the shifter where it enters the housing. While holding the cup down, rotate it CCW 90 degrees and it'll pop up...then pull the shifter out. Alternately, you can pull the 4 bolts that hold the housing to the tranny and pull it all out as mentioned above. Unfortunately, since yours is an 88, you probably have the Peugot, and it's different. You have to locate and remove the three bolts that hold the shifter housing to the tranny and remove it all as an assembly. Jeff
  18. No mods, it is identical to the old part except for the bracket welded onto the front of it to hold the switch. BUT....it was an incredible pain in the ### working under the dash getting it in. Glad I did though.
  19. Here's the one I had cut down 1-1/4" a couple weeks ago by a shop up here in Richmond that does heavy truck work.....$65 to shorten, plus $25 for new UJ's pressed in Image Not Found
  20. 47", but that's with a 231 not a 207....not sure if there's a difference (most likely not). It would probably be cheaper and better to shorten an MJ shaft vs. lengthening an XJ one.....to shorten, shops grind off the weld of the rear yoke and pull it out (it slips/presses into the shaft a couple inches), cut the shaft and then reinsert/reweld the yoke back on. Not sure you could extend the XJ shaft to the length required cheaply or as easily. HTH, Jeff
  21. The black box is the brake light switch from a 96 XJ....I swapped in a dual diapraghm booster and master cylinder from it. I ended up also swapping in the entire clutch/brake pedal assembly, too (long story). The top of the clutch spring fits in a notch at the top of the bracket assembly. I can get a pic of it also if you need it. :cheers: Jeff
  22. I don't like wrenching on greasy #&@*#(..... ;)
  23. I got it...thanks guys! The splice I did on the ground wire from the left side taillights came undone :oops: Now I don't have to worry about po-po pulling me for something stupid like a plate light (I'm funny like that) Jeff
  24. Thanks. Can you tell me where wire #72 goes (or comes from)? I'm trying to find out where I'm loosing power at. I've got taillights, just no plate light. Jeff
  25. anybody have a wiring diagram that shows the license plate light circuit? Mine stopped working sometime last week (I think) and I can't figure out why. No power to the bulb (I'm only using one, relocated underneath the plate). It's frustrating me to no end..... Jeff
