thejim42
Everything posted by thejim42
  1. Sounds like you found a good place to start looking
  2. Just kind of a shot in the dark but the connector can't be in upside down can it?
  3. I've repaired it twice already.
  4. Anyone got one? I have an 88 4.0 swb. My needle on the fuel gauge is now horizontal after hitting a series of bumps and then driving up the steep incline if my driveway.
  5. The vacuum res. Is the plastic canister mounted in the bumper on the passenger side right?
  6. I considered using the 5.2 drivetrain from the Durango I had that got into a fight with a tree and lost. Until I did the research and realized what all was involved and how expensive it could get.
  7. Love the wildernest camper top. Can't wait to find one for my trailer project
  8. I have an 86 long bed donor truck for my pioneer that I have been considering doing this with. Definitely going to make a trailer but a camper would be awesome.
  9. I bought a running parts mj with a broken frame that and messed up trans that I'm using for all the parts except trans to convert my 88
  10. There is a switch on both the brake and clutch so if you step on either pedal it shuts cruise off.
  11. Anyone ever add factory cruise control to their truck. I want to put in on my 88 4.0 5 speed. I have an 86 2.5 5 speed parts truck with factory cruise that I can probably scavange most of my parts from.
  12. And you can not get a 2000 Cherokee with a 5.2. 5.2s and 5.9s were only in the zjs and in 99 when they went to the wj in 99 they started putting 4.7 v8s in them which I won't touch with a 10 foot pole.
  13. Its a lot easier to just get the 4x4 running gear and use your 4.0
  14. Some factory lwb trucks came with a 23.5 gal tank
  15. I have all the parts for the conversion including a brand new slave cylinder, master cylinder and clutch kit
  16. I have a rebuildable 5 speed trans and a 207 t-case. T-case still works though with 107xxx. Trans is stuck in reverse
  17. Check all the connection points for power
  18. I have tail lights $80 each or $150 for the pair
  19. Also get a laser thermometer and make sire the guage is accurate.
  20. Use a volt meter and make sure you have power to the light socket. Check the switch on the brake pedal
  21. Water pump and thermostat would be what I check first. And do a coolant flush
  22. Mine is the same as the 2nd one. It lights up and I got humming out of the speakers and some static
  23. Ive got one that I can get fo come on and the speakers hum not sure if its a radio issue or a speaker issue or an antenna issue. Let me know if your interested
  24. Well finally got my b-pillar lights working. I think its a problem with tue fixture. Installed my footwell lights and I'm thinking about installing the cargo light I got off my parts truck but I'm not sure how well it will work with my roll bar.
  25. I got one in Birmingham AL. Asking $100
