Will has been a week or two since my last post and I did promise a list of the things that I fixed, and a cost. First off my Comanche will be inspected tomorrow and have license by the end of the day. Here is the long list of everything I repaired and the cost.
Purchase 1987 Jeep Comanche - $475.00
Taxes - $41.76
Jeep Manual - $13.90 (Ebay)
Sockets (for rounded bolt heads) - $90.20
Donor Jeep - $450.00
Engine oil, filter, bolts, battery cables, and starter - $113.28
Engine plugs, wire, and grease - $18.25
Wheel cleaner, front wheel bearing & race, brake cleaner, & misc. - $37.50
Body primer - $26.93
Light bulbs & butt connectors - $14.89
Window cranks & turn signal arm - $55.96
Window crank washers - $3.34
Taillights - $100.00
Distributor rotor - $5.30
Nuts, screws, & bolts - $11.04
Total cost of repairs $1459.27 (out of pocket)
Here is list of everything repaired using parts from the donor Jeep.
Battery tray and hold down
Front grill and bumper
Plug wires
Starter relay
Radio & speakers
Front brake pads
Rear brake springs & cables
Driver’s side vent wing window
Repair, weld hood & primer
Floor Curtesy lights
Rebuilt steering column & steering wheel
Replaced fuel pump relays
From black to chrome door handles
Replaced exhaust system
Fresh brake fluid (had in shop)
Battery (had in shop)
Front cowl
Wheels & tires
I set a goal to get the Comanche up and running, & pass inspections for less than $1500.00 and do it within 30 days. I have achieved that goal.
The question you may ask is it done? NO I will still continue to work on the truck.
My next goal is to remove all the dents and paint the whole truck. I will attempt to do this within a year and not spend more than $2000.00 on the entire truck. If you think that is impossible remember that I will do all the body work myself, and paint. I also have a donor Jeep to sell for scrap.
I should have called this tread a Comanche on a budget build!!!!!!!!!!!
