Gjeep
    3
Everything posted by Gjeep
  1. 94.5-96 XJ's ran 134 refrigerant from the factory. I'm currently running that exact set up in my '92 MJ and just installed it in my current '91 build. I like having things factory when I can.
  2. I wouldn't cut it as it ties into other things; in addition to what eaglescout called out, the other connectors are overhead console related and interior footwell lighting. Again, it's all tied into other things that may or may not be affected when you chop away.
  3. From all the research I’ve done going through photos on the internet of factory original/ not repainted Comanche Chief’s, the rocker area of the MJ was not painted matte black to blend in with the decals. The reason I got to digging is that I noticed when prepping the decal set on my other MJ, the decals land about 1/8-1/4” from the bottom of the visible rocker depending on the body panel. I just don’t see that looking right… as I’ve seen several redone Chief’s on the internet also that did paint that rocker area prior to laying down the graphics – and it looks more finished. Interestingly enough, the XJ Chief did have the rocker area painted matte black from the factory. So, I’ll be painting a soft line 1/2" up from the rocker area ending in-line to where the end lowest point of the decal falls. Currently working on the prep to get me there, degreasing, sanding, etc. Aiming to paint rockers this weekend. Back before I moved out of California, I was in an absolute tear to finish up my youngest’s XJ. I tossed the scab wheel/ tire combo that I typically used in paint, and needed to find some tire covers that would protect the good wheel/ tire set when I painted the lower area argent (Below’s a pic of the XJ since I never created a build on this site as I did with the others.)… and these covers worked great, fit up to 32” tires, and were $21 for a set of 4. Will be using them again on this MJ.
  4. Installed all around. These rims are spot-on for Chief graphics.
  5. That's a beauty but indeed a second gen-ish step bumper as majority of the Renix years had the black plastic around the license lights.
  6. I’ve had a set of American Racing Vector rims since 2006, deciding if I wanted to go in the direction of a Comanche Chief for my now sold red ’89 Comanche. Indecision and the center caps were the problem... I’ve never liked the aftermarket center caps of old that stick out 3 or more inches like Pinocchio’s nose. Fast forward to present day and I unearthed these rims from the parts shed, dusted them off and decided to figure out the center cap issue as I’m going Chief on my silver ’91 MJ build. Lots of searching and buying various products brought me to this cobbled stubby center cap combination. There’s a ‘80s Buick GN repop company that makes new centers for the old Buick’s Vector-like rims, which thank fully have the same odd diameter as the American Racing rims (my guess in American OEM’d them for Buick). The 2004-2012 Nissan Titan/ Armada had an 85mm OD/ 78mm ID center cap that fit near perfectly into these GN centers, and the online 3D center caps vendor supplied the Jeep logo’d emblems (needed to be 80mm to fit the Titan caps properly). Finally, the original American Racing Vector rims supplied center cap rubber band-ish ‘bushing’ to properly seat the center into the rim without rattle. Done. Just took a little patience. Also decided to go with BFG 30's versus the 235's I had purchased for the OEM steelies. The past month I’ve been buried in house projects with the latest MJ build taking a back seat. Hoping this weekend to paint the rocker areas the necessary matte black to match the Chief decals I recently purchased and trimmed-down from Graphics Express. Temps are rising here in Oregon which is a good thing. The aim is to lay the Chief graphics down by end of the month.
  7. I see a narrowed bed and sportside MJ.
  8. Once I got past the internal rant in my head about it -- I realized it's not too shabby looking. Nice and simple. In the end, not for me. I'll stick with the 4.0L.
  9. From your pic, I don't think the frame is damaged. You'll see once you have fun unbolting all of that. You can most likely easily straighten the sheet metal that serves as attaching points of front most bumper brackets. My wife drove into a cross traffic dump truck one time with my '95 XJ long ago -- don't know how she missed it or how more damage didn't happen -- but looks similar. Was fixable.
  10. Found a great mom & pop mobile glass company in Southern Oregon who installed a new windshield with the molding versus the metal framing. Looks cleaner than the 6 piece original setup.
  11. ‘8-Ball’ was this MJ’s nickname (former column shift knob), but with decal set waiting to be laid – the truck is now ordained ‘Little Chief’. It'll be running different rims and tires with the graphics as well. This should be a good first time trial run in graphic laying experience before I do the same on my ’92. I hacked up some aftermarket front flare liners to use as rear liners. The originals unfortunately crumbled when removed. The difference between the aftermarket liners and the NOS rears I have (for the other Comanche) is like comparing paper to cardboard – but they’ll work. Three of the holes line up and the rest can be punched. I have the cut aftermarket liners clipped to the factory ones below for reference. This is a good option until I find a minty factory set. (PS -- If you have a set, ping me.) Front air dam was notched for tow hooks, and soon to be painted SEM trim black like the fender flares. 1987 Pioneer trim black power window/ door lock panels have been cleaned and conditioned with speaker grilles and map pockets to be reinstalled shortly. A new windshield is going in at the beginning of next week and then I can move forward on getting Little Chief running, burped, bled, AC charged and interior installed.
  12. Backing into things sounds crazy. Not sure what you're looking to spend, but the repair on mine which was somewhat worse than 92MJ's bumper was $350 ($250 repair + $100 shipping) for repair shipped back from them if I remember correctly. I had to pay shipping to their shop. I should mention the repair will cost less if you remove all the plastic and ship it metal bumper only. http://ssbumperrepair.com/
  13. Nice job and congrats -- CA smog is no fun with modified trucks.
  14. I’m a huge fan of test fitting before final assembly. Nothing worse than having things looking good and last minute find out modifications need to be made. The overhead console install is one of those projects where it’s essential. This console I made taller than in my other MJ, so the XJ modified (front) mounting bracket needed to be bent a little differently and the rear mount platform needed to be taller. Good contour fit of the reshaped shell and the headliner insert cuts were spot-on. My highly technical tool, the Q-Tip, served to mark the location of the rear most screw (found inside the sunglass bin) with a dab of black paint; and it also confirmed the height the bracket needed to be at to seat the console properly keeping it flush to the headliner. All good there.
  15. Got it done – Rear axle brake lines bent, flared and in place. Off the list. And cut the overhead console for the hands-free mic. Time to clean up and refinish.
  16. Fine tooth combing the little things to move forward on assembly… Put together the shoulder belt assembly, attaching it to the modified MJ bracket with grade 8 hardware and sleeved the bottom attaching point (at rocker) to keep it looking factory. Also sleeved the buckle for form and function – the C4 Corvette has an identical length seat belt buckle setup, and what I like about it is it keeps the center console from getting damaged/ carved into as so many of them (especially AMC era) get. It angles the buckle inward and away from the console plastic. Took some time to find just the right set up for this. Lots more details to accomplish for this build before I start getting the interior back together. Next up is the overhead console. Also, been on an insane journey that I now give up on... I wanted to simply replace the Dana 35 hard brake lines. Ordered from Inline Tube just that – first time I got I don’t know what; second time I was hopeful as the line at least has the shape of a pumpkin but turned out to be near 8” too long with incorrect bends. I lost a good month and a half trying to get something that seemed like it would be a simple buy delivered. I give up and will bend my own lines like I did last MJ build.
  17. Thanks NRT_Chris for the tip. ACC did a good job this carpet stamp – the usual front of footwell issues weren’t present. Two thumbs up. The driver side rocker stamp is never proper and takes a heat gun to shape around that side reinforcement plate; And the rear cab wall is spot on passenger side but then goes wonky off by 2” driver side. Again, heat gun to the rescue. Finally, matting will be stuffed in the trans tunnel areas so when the center console is installed it will fit without gaps. But for now, the carpet is coming out as next up is the windshield replacement with the newer style gasket surround. The black Mesa fabric bucket seat bottom upholstery is headed in for repair. I’ve already removed the piece that wraps over and around the frame that the upper seat latch clips into. The little piece of vinyl takes a beating and typically looks like hell even when the rest of the seat looks brand new. It’s the bolt covered rubber ‘bumpers’ Jeep installed to adjust/ prevent seat back wobble. The rubber tip of the bumper breaks off and then exposed bolt tears into the vinyl. Holes in the replacement panel will be cut AFTER the seat is together and flap clipped into place, so no misses on the cut location.
  18. Carpet in place and ready to be trimmed first thing in the morning. Those who have installed carpets know the insane amount of extra material that surrounds the core. It’s nut. I’ll call this ‘in place’ but it still needs to move a good 4” forward once cut down. Tomorrow…
  19. https://www.facebook.com/marketplace/item/1706172260316577/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A291b6c05-2b33-4b32-9cbb-bda99f4d144c
  20. Long live Tomken Machine. Not sure if they’re still in business, but they were the go-to for my lifted XJ/ MJ’s sway bar end needs. Beefy and same design as stock but fatter bushings. I decided to go with the factory heavy duty XJ 28mm factory front sway bar with Energy greasable bar bushings. And with temperature up in Oregon, on went the matte black ‘Jeep’ tailgate letterset.
  21. Got to cuttin’ – always a bit stressful to put areas that are somewhat visible under the knife. Measure, measure, measure, cut. Great fit and looks right. Had been searching for just the right era appropriate look for years. Drilling mounting holes next…
  22. Gjeep
    Comanche on TV
    And there's at least 2 of them as the grille's etc are different. I remember a year or so ago some one here posted an auto transport with 3 Comanche's on it that they thought were heading to movie stardom. I think those are these in Severence. Found it -- video too blurry to see grilles --
  23. Used a portion of a scraped MJ room to check fitment (mainly interior clearance) for the 3rd brake/ cargo light combo… and it works. Ford Ranger sockets were the go-to because they are rubber (quiet) and the right size. Now to trim the real roof.
  24. That wood grain looks sharp -- two thumbs up on choosing to round the corners on all ends. Makes a huge difference.
  25. Getting there… 1” lowering blocks got me to the stance I was looking for – 1.25” higher in the rear after I jumped up/down in the bed for 3-4 mins. Rear suspension torqued to spec. Rear bumper in place as well.
