Everything posted by WyoCherokee
Project Patience....a 90 Eliminator trail build
WyoCherokee replied to WyoCherokee's topic in Member Projects: Your Comanches
A quick update, the new owner has been in contact with me, and i have advised him to check out the thread for all the details. He is on Instagram as @mj_crawl- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
I don't think so. It was a tough sale, but life takes precedence. Love these little trucks. Eventually I think ide like to do some work to a 2wd 4.0 aw4. Hmmmm. For now the 90xj gets some love. I've got a ton of projects to catch up on.- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
Truck is for sale. $8,500 Cash- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
at least daily. theres usually one or 2 rust bucket 2wd's being driven as DD's around here
hmm. ill have to look n see
I already have the brackets. Looking for FACTORY MJ BUCKETS in decent shape. Willing to drive to Denver, Salt Lake, Moab, Grand Junction, Billings, Pocatello....
Crown Auto Cupholder!!
WyoCherokee replied to 1989 Eliminator's topic in MJ Tech: DIY Projects and Write-Ups
i got one of the mounts that goes over the ebrake handle. it holds a soda can but thats about it. Everything else just falls out when you go around corners. But hey, in 1988, if you had a can of pepsi on a saturday going to the lake, you were Cruisin! there werent any of these new fancy coffee mugs and water bottles. I'm debating just getting rid of it. we have sealed mugs, so they usually jsut get stuffed under the seat bracket or in a bag behind the seat -
moving alt to ac mount
WyoCherokee replied to Rokhound's topic in MJ Tech: DIY Projects and Write-Ups
I'm sure you could Fab up a mount. On my Renix, i used an HO compressor mount, found a set of adaptor brackets that a kid on Ebay is making, and plopped in a HO 136 amp alternator and an adjustable external voltage regulator, a 77" belt and a radiator hose for a renix with AC. fits like it was designed. -
Project 4 seat MJ, Killed in the womb.
WyoCherokee replied to Lord Beckbury's topic in Member Projects: Your Comanches
ide drive it! long live the 30 year old mini truck craze and all the odd transformations that folks came up with. -
I'm running the Cav Fab Alpha 3 link. daily driven for near 20k miles as well as trail use. no complaints.
like a raped ape! so much torque.- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
i towed a 2wd MJ from Oregon to Wyoming on a uhaul dolly. just dropped the rear drive shaft from the pinion, tied it up to the body with a ratchet strap to keep fluid in the AX-5 and away we went. blew a rear driveshaft on the tow rig in Boise, hooked the driveshaft back up on the MJ, went and got new u joints, put it back on the dolly with disconnected driveshaft, and continued on our way.
First oil change after the stroker install. Have to do another 200 miles and change it again. Enjoying some 75degree weather and went for a little flexing and sand running.- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
Did cruisers dizzy indexing. it felt so odd cutting the locator tabs. I still don't know how the dizzy doesn't move. Makes a huge difference and idles smoother. no more backfiring, and it pulls like a dream. The before and after pictures of where the dizzy should be are really hard to come by, but imagine this....the distributor rotor rotates clockwise. You want to advance the distributor so the trailing edge of the rotor contact is a paperclip width past the post on the cap. You do not have to cut the cap, i marked on the dizzy with a sharpie marker and used a small straight edge. here's the best picture i could get.- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
Injectors installed, i can actually drive this down the road. The off idle torque is amazing. it pulls hard up past 4200 rpms. the old engine wouldnt pull past 3500. i still need to index the distributor per cruisers tips. hopefully that fixes the half throttle backfiring. need to put about 250 miles on it and then change the oil, and then run another 250 miles and change the oil again.- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
Ford Racing LU24 injectors ordered. Hopefully these work! otherwise ill have to go to figuring out the map voltages and wideband- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
Verified i had 703 injectors in there already. So that tells me i need to step up to the 24's.- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
the stock 19lbs are a wee bit small. seeing some conflicting issues in that some folks run the (91-95) 21lb injectors and some run 24lb injectors. so I'm thinking ill jsut start with a set of 21's since they are cheaper and i can keep em for spares for my XJ.- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
Updates coming soon! Truck runs and moves. fighting an extremely lean issue and backfiring. hoping its just my injectors being to small. 4.5's call for 24lb at 39PSI- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
Engine is just about back together. Summit sent me the wrong valve stem keepers, so ive gotta get the right ones. That's all that's holding me up on assembly. Picked up an HO exhaust header. i grabbed a renix manifold gasket since I'm still using the renix intake. will have to do a little port matching. went with a slightly more aggressive Comp Cam. 68-232-4 if i remember correctly. I want this thing to be a torque monster. I need to drop the tranny and t-case so i can mate them to the engine and drop the whole thing in as one unit. life has been crazy latelly. start a new job in a month so between packing, moving and putting this thing together.....gonna be busy.- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
