Everything posted by mjdoa
What a view! Us Fla flatlanders never see any hills like that. Where is it?
Tracy Ludington "88 shortbed,4.0,Ba10 lifted and locked Fort Myers,Fl. Parts counterman, Chrysler-Dodge-Jeep dealer.
:agree: But how 'bout tractors. "She tihnks my tractor's sexy" Doh. :eek:
Crankcase breather hose grommet
mjdoa replied to 500 MJ's topic in MJ Tech: Modification and Repairs
The rear grommet is only sold with the 4762592 harness. Retail is $16.50. The front grommet is pt# 53004721.Retail is $5.70. The rear grommet is 26 mm id.The front is 22 mm id. Get 2,make the rear one a bit bigger inside. -
If that carpet is attached to a removable panel, take the panel out,scrub it with Greased lightning or some such grease remover,then rinse it down with a mix of vinegar and water,let it dry,spray it with Febreeze or some other odor remover. Or,tell your mom to learn to enjoy the smell.
Well.looks like I still have a job,for a while anyway. Evidently you all are right,they apparently will be downsizing to some degree. I'm sure a lot of smaller dealerships will be closed. I see one immediate effect so far. Manufacturing is going to stop Monday for 30 to 60 days. Can't wait to see the backorders now. It's already been bad for 6 months,a lot of suppliers had cut Chrysler off. We've had stuff like oil and oil filters on backorder,, and I see that getting lots worse before it gets better. That is all.
Sir Sam,is that set yours,did you purchase a set? If so,tell us how you like them,'cause I'd probably get a set.
Sorry,youre correct. I work at a Dodge dealership. And none of them have amber turn signals. A big Doh! to me. :oops: They're the same "style".
Those look an awful lot like either newer Dodge pickup,Dakota, or Durango taillights. I'll take a walk on the lot and look when I get a break. In the meantime,you're right,they don't fit either.
That's too funny,there's exactly one other in my town, is a fairly close neighbor.Guess what.Hispanic landscaper.Doh!
One of my balls fell off - now what?
mjdoa replied to MrSimon's topic in MJ Tech: Modification and Repairs
Just in case you guys want them. Part # for round mj ball is 36001728.Discontinued. For Wrangler 53003408.Discontinued. For blimp,used with cruise control, 53003052,available,$12.65 retail. -
54 Oldest so far me thinks. And not jealous of the young guys. Not getting older,getting better.
Nope,thanks for the offers,I made cardboard tempplates and it worked out fine. When I get it finished I'll post up the specs. As always,thanks everybody.
Nor does any other website it seems. I can't draw like that guy did but we'll have the specs on our website shortly,as long as you guys promise not to laugh at my artwork. :no:
Except,on second look,those are front brackets,not rear. And that is the drawing I remember. I'll go back to that site,see if anyone's posted up the rear dimensions. If not,I'll make a template and post up the measurements in case any of you all ever need them.
Thankyou,Wildman,you are the shizz. :clapping: I've been hunting that for 2 days. Was about to try and cut a clear plastic sheet I could hold up there and mark the spots.
Some where,on some forum ,I saw a picture a guy had drawn and posted of the mounting holes in the rear brackets where they mount to the frame. I'll be dipped if I can find it. Has anyone else run across it? I'm finally getting around to doing my rear bumper, and the old one and brackets are long gone. need dimensions to drill new brackets I'm building. I'll keep sirching. Thanks
You've got a bad connection somewhere,probably a battery cable, and probably a ground. Check them,especially where the negative cable grounds to the engine. Or did you get ti going?
1/2 Tank, Right Turn = Engine Cut-Out
mjdoa replied to 88XJSport's topic in MJ Tech: Modification and Repairs
Along the same lines,I'm having a problem too. Anything below a half tank or so,I make a right turn, and cannot accelerate without the truck missing as if it's running out of fuel. Takes forever to get to cruising speed,smooths out if not accelerating,and will not fix until I baby it to the gas station and fill it up. Then it's fine till I burn off half the tank. I have no cliue where to even begin with that one. :hijack: Sorry. -
garmj,yea,I know that feeling. I get tired of being called "sir". :roll: How's your mj coming along?
Yes,mine closed down. The franchise was picked up by the local Chrysler-Jeep dealer. They hired myself and 4 techs. The other 60 or so... out on the street. Wasn't a pretty scenario,but I got lucky. Lost my house in the process,making a lot less money,but at least I'm employed. I'm still getting calls from people I worked with who are yet to find work. And what do you mean "our age"? I'm still a young pup. :chillin:
Thanks,good to be back. :clapping: Galeana Chrysler-Jeep(now Chrys-Dodge-Jeep). They hired me when Gulf Coast shut down, I've just been trying to get acclimated, and not play on line too much. They're used to me now I guess, and not riding me about it. I've been reading some back posts, good on you for staying out of this rotten business. I hope your schooling all works out ok, and we WILL be up to meet you two soon. Let these guys know if they need part #'s or vin info or whatever,I'm gonna be on the board as much as possible.
Hi,all,I'm back from the dead... :cheers: Lost my house,got moved,seem to be getting life back in order again. My dealership went out of business, am back at a Chrys-Dodge-Jeep dealer. I know everybody's been missing BLHTAZ's parts knowledge,I am available if anyone needs OEM part information,at least until Chrysler goes belly up. Pm me anytime,I'll stay logged in at work and check the board periodically during the day. Glad to be back,missed you guys,will stay in touch. Yea I still have the mj,been wheeling once in 6 mo's, last Sunday.Time to crank that action back up too.
It looks good. Easy to use. Thankyou for staying with it, and for all your hard work. More smilies,too.Cool.
WAHOO,Tell us how you really feel. :D
