Confedneck
Everything posted by Confedneck
  1. any of you guys swapped round headlamps in?? has it been done? how about narrowed fronts? how'd ya do it, what'd ya hafta move? thinkin about doin both to mine... j
  2. don't do it, i spent ALL day outwheeling tjs on 31s LOL... i only got stuck once, that ruby got stuck 4 times :X lol
  3. it's not a c30 if its 4wd, it's a k30.... front axle = chevy dana 60 =$1200 on a bad day with good brakes... SRW k30 with a solid body, expect 1500-3500 depending on your fellow bidders... good luck, post pics
  4. nice swap, diggin the yellow, and the magic-markered JEEP logo
  5. i priced all new stuff today, minus the hood cuz i forgot, new fenders, header panel, grille and both headlight buckets $340.00 may go new if i can't find a decent used one...
  6. no more vacuum leak, 90$ worth of ford gt aluminum suspension washers and it's 4wd again.... now onto the column shift??? common or not? gotta fix the tilt wobble too, bushings or not??
  7. brent, you may be right, I'm gonna have to find something and make something
  8. t40 for the hinges, i think the latch is a 27 or a 30
  9. fenders, hood, header panel, grille, headlights, and trim...
  10. its got the 231 pattern... i didnt know the 231 had the part time light though, learn something new every day
  11. first off, I'm taking bets.... who wants to guess what t-case i have before i crawl under and look.... when i bought it, i assumed it was a 231 from the shift pattern, but now my dash lights up sometimes in 2wd with a "part time" light, which would mean i could have a 242, right?? so place your bets.. also, how common is it to have a column shifter in an MJ?? and c: what is the jeep part number for the bushings for the tilt?
  12. Confedneck
    New Toy
    where ya at? i got a window you can have if you come get it, I'm in south florida
  13. whiteshark, how did you stabilize the bed sides... and to avoid having to use rubber trim on the edges, just cut a 1/2" notch in the fender at the corners of your cuts and fold them... on my fronts on my manche thats all i did, i removed the flares, cut the notches and folded, kept all the stock body lines, i need to trim it higher, because i cut the rears so high, but it looks clean...
  14. there isnt that valve on it at all, the one in his picture, its just the blue hose with the rubber nipple...
  15. it's a beautiful area up there, nice pics... crossing my fingers now...
  16. sounds eerily like a bad MAP or MAF sensor or even tps sensor, or bad ignition control module... don't know which of these your jeep has, but test the ones ya got...
  17. so i bet if i unplug that blue line, that has a screw stuck in it on my manche, my 4wd might work, seems maybe it's the problem??
  18. battery trick works on obd1 and previous computer controlled vehicles... nothing 96 or newer
  19. ok will do boss, thanks for the site...
  20. why is it locked and empty?? do i need to pay to view it or is it just empty???
  21. for lockers for both axles?? nice!!
  22. should fill alligator alley southbound with jeeps, put your commanches on trailers and tow em with your XJ or vice versa
  23. nice rig, how do you like the aussies?
  24. possibly caused by a rear window leak, leak check the rear window just to be sure...
