Everything posted by comanchekidwa
The Duratracs are great tires... We have sold a lot of them and haven't heard one bad thing.....
And It begins
comanchekidwa replied to comanchekidwa's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Update.... Its been awhile... I decided to put my winch on my Jeep its been sitting under my tool box for a Year. Started with a winch plate from Harbor freight and cut my bumper to figure out how to use it.. Got the plate tacked on.. Bent up some tube to protect the winch and reinforce the bumper. Couple of supports and paint... Image Not Found Winch bolted on and Masterpull XD rope spooled on... Winch box mounted under hood I did in the cab controls. Upgraded my battery. Image Not Found- 32 replies
- bobbed bed
- custom bumpers/armor
(and 1 more)
Tagged with:
Stuck, and no start
comanchekidwa replied to MJ is dead's topic in MJ Tech: Modification and Repairs
Try unplugging and plugging the Crank Position sensor plug a couple times. Mine does this ever 6 months or so I really need to replace it... -
Not working for me...
Optima's were never designed for what we in the offroad world use them for.... Ever since Optima moved there plants over seas the quality has gone down hill.... There are 4 levels of Optima batteries. Don't ever buy one from Costco they get the bottom of the list. the good ones go to the top battery company's... If you want a battery that you don't have to worry about buy a Odyssey battery Yes they are a little expensive but they come with a 3 or 4 year warranty depending on battery, they have a 2 year shelve life before needing charged. They can take being drained and recharged several times without hurting the battery. I don't want to write out all the specs you can go to their website or here is the spec sheet http://www.odysseybattery.com/batteries.html Jason
And It begins
Ok so it got done for the weekend had a blast in the snow. Driving with 106" wheelbase is freaking awesome I didn't have make wide turns and its nice having the rear tire's so close to the cab. Here are some pics from the weekend. this is our group...- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
So this week I have been working on the Jeep at work when time permits. I got the tail light"s cut in and wired. Got the shocks on and bump stops on and my mudflaps back on. The truck box is mounted. Its going over the get a new tail pipe made.- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
Ok so this weekend I got most of the stuff done. I will be finishing it up during the week at work... Gas tank is mounted here's the bottom.. and the top... That's all I got for pics this weekend I was to busy trying to get sh*t done... Its all painted and the bed is mounted and it runs... I need to figure out the shocks and button up some stuff, I should be ready for the weekend....- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
I got tired of ripping off tail lights and then trying to find some to replace the broken ones... it still looks like a mj...- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
Tail gate works what a pain in the azz.. It took all day to figure out how to make it work. but it works as good as I can get it to...- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
Ok so I got the hole cut in the bed for the gas tank. Fits like a glove I need to build a support for the tank out of 1x1 box and then add some straps. I also got the front bed mounts moved and the middle supports made... No pics of that sorry.. I started on the rear bob.- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
So wed. was dead at work so I left work early and went to weld on the Jeep... Driver side all done. almost got Pass. side done and ran out of wire..- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
I was going too, but with what a pain welding the front is we will see....- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
Ok so Saturday I got the end of the frame cut off and the bed shortened and started welding the uneven and dented sheetmetal back together WHAT A PAIN IN THE AZZ.... Now some pics.- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
Yes Auburn Car Repair and Offroad...- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
Willy Looks like a pretty nice shop. Where is this work taking place? Willy Thanks... It's a buddys shop- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
And It begins
For where I wheel and how I wheel. I needed less wheel base. I was down at the Rubicon and destroyed my drive-shaft Video below. And in Moab I got screwed on some obstacles because I was to long and was getting hung up on my drive-shaft. I don't plan on running anything bigger then a 35" tire. So making my wheelbase shorter is what need to be done. I wheel with a lot of Cherokee's on 35's and I see if they had a few more inches in wheelbase they would have a easier time climbing and making some stuff. Cherokee's have a 102 to 103 inch wheelbase when lifted depending on lift.- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
So I started my wheel base mod this weekend. I started off with a 114" wheel base and I'm shorting it up 8" so it will be at 106". Which I think will be perfect. So first I had to get the bed off which is kinda a pain. So I did some measuring and found out I couldn't use a regular front leaf spring mount because it would put the spring to far below the frame and lift my jeep 2". So I decided to do my part and Reduce, Reuse and Recycle and reuse the front spring brackets. I had to drill out all the spot welds holding the leaf spring brackets on the frame :bang: . Then I decide to reuse the rear hangers too. So out came the drill and more drilling :bang: . So with all spot welds drilled and the mounts off I started measuring again and I had to notch the frame so the front leaf spring bushing would clear and not lift my rig. So came the notching of the frame and finding something that was 4" round to fill in the notch, I happened to find an old oxy bottle cap and it worked perfect. Got the front leaf spring mounts cut so they would fit Then started tacking the mounts on front and rear. While I was doing the rear hangers Brady shorted my rock rails so they will clear the tires... And here it is on the ground, I will be final welding all the brackets next weekend and start on the bed To be continued.......
- 32 replies
- bobbed bed
(and 1 more)
Tagged with:
Homemade bracket I used a bolt to attach the base and made a bracket for the front of the jack and drilled a bolt and padlocked it... and keep a can of WD40 around to keep jack lubed up....
I just did this and I'm still in the process of doing it I started last saturday about 10 hours and have been working on it after work bout 3 hours a night and I'm going in tomorrow and finishing it up it is a lot of work... Here is the complete harness, dash and A/C out of a 90 xj. Which I found out after words that the harness is different. So in order to get the fuel pump and rear lights to work I had to do some wiring and splicing... Dash out and new a/c box installed front of jeep tore apart to install the condenser and compressor. The old dash and wiring...
I did this to my MJ and it worked great... I used the brake booster, master, proportioning valve and pedal assembly out of a 96 cherokee... I used the main line that went back to the rear valve, used a brass coupler to remove the brass T that was there... I re-bent the line to the pass. side and replaced the driver side with a new line. and it works great with the Waggy Dana 44's front and rear..... I can take pics if you want...
Gas Mileage Issues - Now AW4 Issues
comanchekidwa replied to 500 MJ's topic in MJ Tech: Modification and Repairs
I'd check for a intake leak and if thats ok... then more and likely the O2 sensor and don't buy a cheap one buy a Bosch O2 sensor.... -
show me your rock sliders
comanchekidwa replied to Fsj Super Swamper's topic in MJ Tech: Modification and Repairs
I used 3x6 box tube 3/16 and cut out the stock rocker and welded in the box tube..... Then I tied it into the frame... -
I live in the southend puyallup area... If you are looking for peeps in pnw check out are club board www.pnwjeep.com ..
