comanchekidwa
    Washington
  • Interests
    4 wheeling and camping
comanchekidwa's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. The Duratracs are great tires... We have sold a lot of them and haven't heard one bad thing.....
  2. Update.... Its been awhile... I decided to put my winch on my Jeep its been sitting under my tool box for a Year. Started with a winch plate from Harbor freight and cut my bumper to figure out how to use it.. Got the plate tacked on.. Bent up some tube to protect the winch and reinforce the bumper. Couple of supports and paint... Image Not Found Winch bolted on and Masterpull XD rope spooled on... Winch box mounted under hood I did in the cab controls. Upgraded my battery. Image Not Found
  3. Try unplugging and plugging the Crank Position sensor plug a couple times. Mine does this ever 6 months or so I really need to replace it...
  4. Not working for me...
  5. Optima's were never designed for what we in the offroad world use them for.... Ever since Optima moved there plants over seas the quality has gone down hill.... There are 4 levels of Optima batteries. Don't ever buy one from Costco they get the bottom of the list. the good ones go to the top battery company's... If you want a battery that you don't have to worry about buy a Odyssey battery Yes they are a little expensive but they come with a 3 or 4 year warranty depending on battery, they have a 2 year shelve life before needing charged. They can take being drained and recharged several times without hurting the battery. I don't want to write out all the specs you can go to their website or here is the spec sheet http://www.odysseybattery.com/batteries.html Jason
  6. Ok so it got done for the weekend had a blast in the snow. Driving with 106" wheelbase is freaking awesome I didn't have make wide turns and its nice having the rear tire's so close to the cab. Here are some pics from the weekend. this is our group...
  7. So this week I have been working on the Jeep at work when time permits. I got the tail light"s cut in and wired. Got the shocks on and bump stops on and my mudflaps back on. The truck box is mounted. Its going over the get a new tail pipe made.
  8. Ok so this weekend I got most of the stuff done. I will be finishing it up during the week at work... Gas tank is mounted here's the bottom.. and the top... That's all I got for pics this weekend I was to busy trying to get sh*t done... Its all painted and the bed is mounted and it runs... I need to figure out the shocks and button up some stuff, I should be ready for the weekend....
  9. I got tired of ripping off tail lights and then trying to find some to replace the broken ones... it still looks like a mj...
  10. Tail gate works what a pain in the azz.. It took all day to figure out how to make it work. but it works as good as I can get it to...
  11. Ok so I got the hole cut in the bed for the gas tank. Fits like a glove I need to build a support for the tank out of 1x1 box and then add some straps. I also got the front bed mounts moved and the middle supports made... No pics of that sorry.. I started on the rear bob.
  12. So wed. was dead at work so I left work early and went to weld on the Jeep... Driver side all done. almost got Pass. side done and ran out of wire..
  13. I was going too, but with what a pain welding the front is we will see....
  14. Ok so Saturday I got the end of the frame cut off and the bed shortened and started welding the uneven and dented sheetmetal back together WHAT A PAIN IN THE AZZ.... Now some pics.
