Eagle
Moderators
    27
Everything posted by Eagle
  1. Which translates to 87 thru 90 for the flex plate
  2. Eagle
    yay DD!
    DC, you obviously don't live near an actual ghetto, you've just read about them. You messed up on a couple of KEY points: (1) The tires and wheels MUST exceed the value of the vehicle by a factor of ten. Thus, if the car cost $200, you have to spend at a minimum $2000 on tires and rims. That's actually pretty low-tech ... most genuine ghetto cruisers spend $2000 on each wheel. (2) The chassis must be slammed. If you can turn from a main street into a driveway ... you didn't do it right. Pneumatic suspension is, of course, better. If the vehicle can jump up and down when stopped at traffic lights, it gets 7.43 more MPG when moving. (3) And don't stint on the limo tint. If the po-po can see you, you lose points. (4) A true ghetto vehicle doesn't have license plates on the outside. They get stolen. The license plate has to be taped or propped up in the rear window (which, of course, has been obscured by the aforementioned limo tint, thereby rendering the marker plate invisible).
  3. All that matters is that the hole spacing be correct. The XJs and MJs all used the same drive shaft u-joints, so the same u-bolt that works with a D35 should work with a D44. I bought some awhile back with the thought of converting my XJ, but I've not done it because I haven't had any reason to drop the drive shaft. I'll have to look, but I think it should work as well on a rear D44 as on a D35. Dunno if I got the correct ones, but I think the ones I got were listed for a Ford pickup. Most of the auto parts chains have these in the HELP! line, in blister packs, you just have to search for the correct one.
  4. Please do NOT post huge pictures. They take forever to download, and they just mean we have to scroll around to see the entire view. 640x480 is fine, or 800x600 is a practical MAXIMUM for viewing on the Internet. I'll tell you right off, I'm on a dial-up connection. If your pics are larger than 800x600 I won't see them, because I don't have time to sit here while they load. Xacto's pic above is 900x564 and it takes up MORE than my full screen width, meaning I have to scroll back and forth to see it all. There's no point in posting pics that large.
  5. I'm not sure what controls the tranny in the newer XJs with OBD II. I think i'd go ahead and try it. If you have problems, ask a dealer if they can flash it to tell it it's now a manual tranny. Remember that you'll need a new flywheel if your MJ is a Renix. I don't know if the 91-95 flywheels are the same as the 97+ with regard to the tooth pattern for the CPS.
  6. I admit to be biased because I have met Clayton and wheeled with him, but I think Clayton's long arm kit is head and shoulders over the others. He didn't design it to sell, he designed it for his own use, and since he wheels hard he designed it bulletproof. Then other people in his club wanted them, and it took on a life of its own. He's an industrial engineer by profession, so it's not a booty-fab design. Plus, unless he has grown a lot in the past year, he is still small enough that you can call him up and tell him you need a kit for a Comanche rather than a Cherokee, and he'll work with you. Clayton's Off-Road, Waterbury, CT. If you decide to go that way and he needs a Comanche to see what's different from the Cherokee, lemme know and we can arrange for me to stop by his shop and let him eyeball one of mine. I haven't seen the new shop since they moved, anyway, so it would give me a reason to get over there.
  7. You can't upload pics directly to the forum. Put your pics on a photo hosting site such as PhotoBucket, then you just post links to the pics in your posts here.
  8. There is no relay in the headlight circuit. The headlight switch incorporates a circuit breaker, and all the wiring carries full power. Did you replace the dash switch, or the dimmer switch at the base of the steering column? Also, did you check the sockets at the headlights to see if you're getting power and perhaps the sockets aren't contacting the pins (spades) on the lights?
  9. John, a picture of your interior would be useful and informative. Most MJs (Comanches) came from the factory with a bench seat and a short, "mini" center console. Eliminators had bucket seats, and the XLT (or whatever they called the top model in 1986) had buckets, but by far most had a bench seat. So yours may be original.
  10. No. Caster is measured with the wheels turned. Camber is measured with the wheels straight ahead. BTW - what do you means by caster "out" 4 degrees? 4 degrees isn't enough caster, you should have about twice that much.
  11. WJs are different. I think it's 5 x 5 but I don't remember for certain. I AM certain that it is NOT 5 x 4-1/2
  12. My '88 Comanche did. The warning module finally bought the farm this past winter, which I discovered the day I came out of work and couldn't even get the dash lights to glow. I agree, however, that I've never encountered an MJ with a headlight warning buzzer. My '87 Pioneer doesn't have one and my '88 Chief doesn't. No reason why a Cherokee warning module couldn't be retrofitted, though -- if they are still available.
  13. I was able to buy the rear window gasket from my dealer about a year ago. I dobt there's been a run on them, so the warehouse may still have them.
  14. Some Chebbies are 5x5 and some I think are 5x4-3/4. And they use 7/16" lugs rather than 1/2". Nope, Chebbie rims don't fit Jeeps.
  15. Oops. BIIIG OOOOOPS! My apologies, I didn't notice the location. I don't know what the laws are in Canada, but courtesy toward other drivers would make me think it makes sense to proceed according to those guidelines whether they are law or not. There have been days when I was wishing for a full load of photon torpedoes when I run by a bunch of SUVs (why are they all Exploders?) who insist on running their fog lights even though we haven't had a real fog here for three years -- and the damned fog ligts are aimed wrong and are blinding for on-coming traffic (i.e. -- me).
  16. The factory wiring should be through a relay, but the wire is a bit skinny if your lights are anything more than 55 watts. BUT ... Correction -- you do NOT have "driving" lights from the factory, and you cannot (legally) connect off-road lights to the factory wiring. By federal law, "fog" lights (very low, wide beam with a sharp vertical cut-off) may operate only with the low beams on and MUST turn off automatically when you switch to high beams. They can also operate if only the parking lights are on, but they must still turn off automatically if you turn on the high beam headlights. By federal law, "driving" lights (long, narrow, pencil beam) may operate ONLY with the high beam headlights, and CANNOT operate when the low beams or only the parking lights are on. "Off-road" lights are neither "fog" nor "driving" lights. They are essentially flood lights. I don't know if they are addressed by federal law, but most states do not allow them to be used on pavement at all, because there's no way to aim them so they won't blind on-coming traffic. My state, Connecticut, requires them to be covered when on public roads. Virginia doesn't allow them at all -- when the Liberty model with those roof-mounted off-road lights came out, they had covers for states like Connecticut, and that model was not available in Virginia at all. Bottom line: skip the stock wiring. Run your own, using 12-gauge wire as a minimum for the power. Use a relay, and control the relay from a separate toggle switch. (Don't forget a fuse or circuit breaker.)
  17. Eagle
    Parts
    Doesn't Quadratec have them? You're referring to the front header panel that holds the grille, right? Or are you looking for the interior dashboard panel?
  18. I stand corrected (on the '88 Eliminator). Now ... about those Pioneer decals. What year(s) were they used? My '87 SWB is a Pioneer, and it doesn't have ANY decals. It has the same plastic "Pioneer" badge on the front fenders that my '88 XJ Pioneer has.
  19. God! I have a snake phobia. Reading that gave me the shivers. And it was NOT funny!
  20. The '88 speedometer didn't use a retaining clip. The upper end of the cable has an integral white nylon fitting that snaps onto the speedo head and is released (as noted above) by squeezing the outer ring to release the locking tabs.
  21. What's your definition of "performance"? Mine is earth-ripping, tall-building-hauling torque. Other people seem for some inexplicable reason to think that an off-road machine NEEDS an engine that produces 17,000 horsepower ... at 8,000 RPM. Define the parameters or you won't get useful responses.
  22. Because you used a FRam filter, of course.
  23. 97 thru 2001 for the doors. I don't know if the 97 and newer radiator is the same as a '91
  24. I think I would have let him wade out. A hydrolocked engine is no fun, and if you haven't raised and waterproofed your air intake to the throttle body, you're risking sucking in water when you ford. Especially since the air box has holes in the front and bottom that let water in as easily as out.
  25. It depends on the amount of lift. The Trailmaster lift in my MJ was a 4" lift, which leaves to drop brackets at stock height above the ground when the rest of the truck sits 4" higher. The brackets were always getting hung up on rocks. Once you get about maybe 6" of lift they're not as much in harm's way. As to the durability, those MJ frame gussetts are VERY heavy metal, so they have to help. It also helps if you run control arms with something like heims or Johnny joints allowing some rotation at the ends, so that flex doesn't stanantly transfer a lot of stress into the brackets (and thence to the frame pockets).
