STERLING STINGER Posted May 12, 2010 Posted May 12, 2010 here's some pics of a mod for a dakota light for my mj....its a trial run so no crap from anyone :fs1: nib 88 dakota tail light.... dremel the crap out of it got some nuts and dremeled an old beat up mj light oh noooooooooo cut it to fit as best as i could, gorilla glue, then caulked it up and waa laa
freakjeep93 Posted May 12, 2010 Posted May 12, 2010 as much as many of us hate the thought of desroying a factory light that can cost so much now. id like to seee how this turns out. might be good for wheelers who want that stockish looking taillight.......
STERLING STINGER Posted May 12, 2010 Author Posted May 12, 2010 thats it, its done. it just needed another socket on the back
STERLING STINGER Posted May 12, 2010 Author Posted May 12, 2010 got any pics of on in the truck? ya but its JUST A PROTOCOL....really my plans are to use a larger angle without holes and bring it right to the top of the light here you go....i warned you
Automan2164 Posted May 12, 2010 Posted May 12, 2010 have you test fitted the housing on the truck? Agreed. And really? I mean, you had to test on a NIB Dak light? That would be like the Dak guys trying to make tails and cutting up a NIB MJ light. Should have started with a used one. Rob L. :dunno:
STERLING STINGER Posted May 12, 2010 Author Posted May 12, 2010 have you test fitted the housing on the truck? Agreed. And really? I mean, you had to test on a NIB Dak light? That would be like the Dak guys trying to make tails and cutting up a NIB MJ light. Should have started with a used one. Rob L. :dunno: it worked though so it dosent matter .....i was sitting there with both of them in my hand, bored and was like f it......started cutting.....dove right in and i knew i was dedicated after the first incision....i still think for a FIRST STAGE they look ok.
dasbulliwagen Posted May 13, 2010 Posted May 13, 2010 As Mr. Horse says from the Ren and Stimpy cartoons, "No sir, I don't like it." It just doesnt seem to fit right or look right. With the gap at the tailgate side it makes it look like its sitting crooked/slanted. I think I would stick a trailer light in mine before going that route, but thats just my opinion. Its good to know that someone has tried it though to see if it would work.
STERLING STINGER Posted May 13, 2010 Author Posted May 13, 2010 I know its crooked...just a trial remember..ill mod it better..just give me some time...they look real nice on the white mj...they stand out better
STERLING STINGER Posted May 13, 2010 Author Posted May 13, 2010 how will you be attaching them? If your looking at the light from the rear, the piece that the two screws on the left screw into needs to b bent out a little then new holes drilled. The screws on the right screw right onto that angle...the new angle won't have holes prefabbed in it
500 MJ Posted May 13, 2010 Posted May 13, 2010 :ack: No Thanks Boss, Are you so hard up for a good pair of MJ lights that you have to do this, what is your reasoning? Also, please don't hack up another MJ light so you can do this to the other side... there are plenty other tail-lights out there to hack up.
Darren Posted May 13, 2010 Posted May 13, 2010 Will you be doing the Datsun tailgate conversion or the the S-10 cab swap next?
landlubber Posted May 13, 2010 Posted May 13, 2010 meh, if I had to replace my tail lights with something other than stock, I'd go this route.
jpnjim Posted May 13, 2010 Posted May 13, 2010 Wow, you'd think he posted about kicking out a stained glass window on a Catholic Message Board. ;) Sooner, or later either: 1)someone will start making MJ taillights, or 2)someone will have to find a way to adapt what is available to use on MJ's. Personally, I'd hope if we had to go with #2, that 'some' slightly smaller, but close in size taillight could be used with a simple bolt on adapter bracket, or framework.
-600JeepMJ Posted May 14, 2010 Posted May 14, 2010 :hmm: not sure if I like the looks of them. :cheers: for at least trying some thing new.
STERLING STINGER Posted May 14, 2010 Author Posted May 14, 2010 Will you be doing the Datsun tailgate conversion or the the S-10 cab swap next? i wish......how about just don't post anything if u got nothing constructive to say. :eek: and i guess noone understands what prototype means.......i have scads of lights to tear up, i just wanted to see....is that so bad, i tore up an old cracked mj light.....
STERLING STINGER Posted May 14, 2010 Author Posted May 14, 2010 :ack: No Thanks Boss, Are you so hard up for a good pair of MJ lights that you have to do this, what is your reasoning? Also, please don't hack up another MJ light so you can do this to the other side... there are plenty other tail-lights out there to hack up. i am just using the remainding piece on the light i already cut.....easy :no:
Backroads Posted May 14, 2010 Posted May 14, 2010 On the note of 'other' replacements. I didnt do any real comparisons but I saw an older dodge pickup (smaller one, maybe an old dakota?) that had tail lights that looked very similar to the MJ.
500 MJ Posted May 14, 2010 Posted May 14, 2010 :ack: No Thanks Boss, Are you so hard up for a good pair of MJ lights that you have to do this, what is your reasoning? Also, please don't hack up another MJ light so you can do this to the other side... there are plenty other tail-lights out there to hack up. i am just using the remainding piece on the light i already cut.....easy :no: OK. Just please tell me why.
STERLING STINGER Posted May 14, 2010 Author Posted May 14, 2010 :ack: No Thanks Boss, Are you so hard up for a good pair of MJ lights that you have to do this, what is your reasoning? Also, please don't hack up another MJ light so you can do this to the other side... there are plenty other tail-lights out there to hack up. i am just using the remainding piece on the light i already cut.....easy :no: OK. Just please tell me why. why am i using an already cut up mj taillight? cuz i don't wanna cut another one and theres no need to. i just need 1 socket hole for the dakota light. here it is
STERLING STINGER Posted May 14, 2010 Author Posted May 14, 2010 meh, if I had to replace my tail lights with something other than stock, I'd go this route. are these bought or did someone fab them? there real nice..... :thumbsup:
