Guest vzehler Posted June 16, 2008 Share Posted June 16, 2008 Got a little work done this weekend. Picked up a whole 98 Cherokee Sport for $400.00. It's sittin in the background of the pic. Anyways, I robbed the front end off of it and put it on the Comanche. Still got work to do on the flares and front bumper but it's almost complete.. Check it out :) Link to comment Share on other sites More sharing options...
BLHTAZ Posted June 16, 2008 Share Posted June 16, 2008 Looks good :cheers: Now to get the rest painted to match ;) Link to comment Share on other sites More sharing options...
Geonovast Posted June 16, 2008 Share Posted June 16, 2008 Looks good :cheers: But just so you know...a Cheromanche is something completely different. Link to comment Share on other sites More sharing options...
Guest vzehler Posted June 16, 2008 Share Posted June 16, 2008 Looks good :cheers: Now to get the rest painted to match ;) You got it. Just gotta put the rest together, do a little dent repair here and there go get her painted... Still gotta settle on a color though.. Appreciate the kind words. Looks good :cheers: But just so you know...a Cheromanche is something completely different. I stand corrected... Changed the title for ya.. Thanks for the compliment though :D Link to comment Share on other sites More sharing options...
89eliminator Posted June 16, 2008 Share Posted June 16, 2008 it turned out nice! :cheers: Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 16, 2008 Share Posted June 16, 2008 Georgeous. Love the chrome bumper too. :D :eek: But you need MORE chrome, like the grille, mirrors, door handles, etc. etc. w. a dark color, like my gray. This color was only available on 91-92 MJs. Yes I know; I'm shameless. :cheers: Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 16, 2008 Share Posted June 16, 2008 you goona swap the front doors out to keep the clean paint going, then turn the other doors into half doors? :brows: :brows: Link to comment Share on other sites More sharing options...
Guest vzehler Posted June 16, 2008 Share Posted June 16, 2008 you goona swap the front doors out to keep the clean paint going, then turn the other doors into half doors? :brows: :brows: ohhhhhh... I hadn't thought of that... Thats a fantastic idea. What would I do about hinges though? Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 16, 2008 Share Posted June 16, 2008 you goona swap the front doors out to keep the clean paint going, then turn the other doors into half doors? :brows: :brows: ohhhhhh... I hadn't thought of that... Thats a fantastic idea. What would I do about hinges though? Link to comment Share on other sites More sharing options...
lostissues Posted June 16, 2008 Share Posted June 16, 2008 you goona swap the front doors out to keep the clean paint going, then turn the other doors into half doors? :brows: :brows: ohhhhhh... I hadn't thought of that... Thats a fantastic idea. What would I do about hinges though? *edited out pics I think he means pre 97 hinges VS post 97. it would be hard to make something to swap back and forth easily. although i have no idea how the newer ones bolt to the door itself, maybe its just unbolt newer, bolt on older. but that would be to easy. Jonathan Link to comment Share on other sites More sharing options...
Eagle Posted June 16, 2008 Share Posted June 16, 2008 you goona swap the front doors out to keep the clean paint going, then turn the other doors into half doors? :brows: :brows: ohhhhhh... I hadn't thought of that... Thats a fantastic idea. What would I do about hinges though? Hinges are not the problem. The doors bolt to the hinges. The problem is that the 97+ doors have the striker mounted at a different height. You have to do some customizing to make the latches ... latch. Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 16, 2008 Share Posted June 16, 2008 you goona swap the front doors out to keep the clean paint going, then turn the other doors into half doors? :brows: :brows: ohhhhhh... I hadn't thought of that... Thats a fantastic idea. What would I do about hinges though? Hinges are not the problem. The doors bolt to the hinges. The problem is that the 97+ doors have the striker mounted at a different height. You have to do some customizing to make the latches ... latch. ????????????????????????? Link to comment Share on other sites More sharing options...
Guest vzehler Posted June 16, 2008 Share Posted June 16, 2008 you goona swap the front doors out to keep the clean paint going, then turn the other doors into half doors? :brows: :brows: ohhhhhh... I hadn't thought of that... Thats a fantastic idea. What would I do about hinges though? Hinges are not the problem. The doors bolt to the hinges. The problem is that the 97+ doors have the striker mounted at a different height. You have to do some customizing to make the latches ... latch. actually, theres more to it than even that. Its a different style latch alltogether. The 97+ model uses a pin style while the old comanche's use a hook. Either way there is no easy way to make use of both doors. I either keep the old ones or upgrade to the newer style door with the power options... Decisions decisions....... Link to comment Share on other sites More sharing options...
offroader461 Posted June 16, 2008 Share Posted June 16, 2008 there is a simple way to modify the door striker from the +97 to adapt them to our late model frame...ill post up the link later...its sticky'd on my laptop :roll: Link to comment Share on other sites More sharing options...
