BPB Posted June 9, 2008 Posted June 9, 2008 I got coats 1 and 2 of flat black on, one more tomorrow. ran #4 wire in the cab and hooked up and mounted my power inverter, and i also got my cd player installed (no more beating the hell out of my tape deck every five minits). I will have pics up tomorrow.
Guest vzehler Posted June 10, 2008 Posted June 10, 2008 :needpics: i second that... I wanna see one in flat black... did you bomb can it or spray it pro style?
Tank4L Posted June 13, 2008 Posted June 13, 2008 :needpics: i second that... I wanna see one in flat black... did you bomb can it or spray it pro style? I third...i vote can....it's easier cuz when you pro it you have to use a Satin finish agent in the clear... if you don't clear the paint rubs off in a year....
BPB Posted July 1, 2008 Author Posted July 1, 2008 Here are some pics finally I got it a little dirty camping, the power inverter worked out great it even ran my 3/4 inch drive electric impact gun. The back is just wall mart 99 cent cans 16 to be exact still need to do the second coat.
Darren Posted July 2, 2008 Posted July 2, 2008 i can paint that for you kid! doesnt look to bad. you should run the wiring the right way though. buy me some beer and i'll help you with that.
BPB Posted July 2, 2008 Author Posted July 2, 2008 My comanche needs a good day of wiring so that I can gt my blinkers working and everything.
Darren Posted July 3, 2008 Posted July 3, 2008 hook me up with some beer and i'll solve all your wiring problems
BPB Posted July 3, 2008 Author Posted July 3, 2008 hook me up with some beer and i'll solve all your wiring problems Sounds like a plan
BPB Posted October 5, 2008 Author Posted October 5, 2008 I opened pandora's box today. I got my new wiring harness wednesday, went to take the dash out and a few hours later there is nothing but metal left inside my mj. I pulled the cloth off the seats and ran them through the washer, then the carpet came out..... the floor boards had some surface rust.. nothing abnormal on an 18 year old truck. then on the tranny tunel there is a crack. One of the weirdest things that i have seen. So I drilled each end of the tare, then bondo'd it shut, i will sand it out and primer it. I also got some rubberized undercoating that will go on the floor to help with road noise. I will have pics up soon. My next item on the agenda is noise reduction. I am going to coat the entire cab in 1/4'' thick foam pad that goes under pergo floors. the floor will get three coats and the wall one or two... we'll see what works. btw I have to drive this truck to school monday.
BPB Posted October 5, 2008 Author Posted October 5, 2008 I like the gun rack. Where did you get that? u-pull-it..... it was in the back of a van
BPB Posted October 6, 2008 Author Posted October 6, 2008 full day number two is in the books, ran into some trouble.... the hot lead to the ignition switch (red wire) is not hot fallowed with diagram and had no luck ran a hot lead to that wire and vualla, my truck fired up. I also replaced the ignition cylinder. have gotten the pad and carpet down. dash and guages all in. now it is bed time. driving the kia to school tomorrow. Edit/Delete Message
BPB Posted October 6, 2008 Author Posted October 6, 2008 I hate upolstery!!!!!!!!! :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop: :headpop:
BPB Posted October 15, 2008 Author Posted October 15, 2008 I now have it all back together!!! :driving: The foam pad that i used for sound deadening was a great success!!!! :banana: Now the only thing that I can hear in the cab while cuising is my exaust leak. I am going to have that fixed in a little over a week. Now I need to figure out where my shimmy is coming from.
BPB Posted October 16, 2008 Author Posted October 16, 2008 I have pics on my phone, will put them up asap. Everything works except the coolant guage, also get this.... when I push in my clutch the brake dummy light comes on.?.?.?.?
BPB Posted October 25, 2008 Author Posted October 25, 2008 The shimmy is gone, it was the top track bar joint. Fixed it for now. Hope to find ZJ steering next weekend. Started work on my header this evening. Everything is going way faster and smoother then expected. I now have the intake manifold and header installed. The power steering pump is back on as well, I replaced the belt while I had it off. I am going to look for a plug for the egr on the bottom of the manifold. I also have to finish fabbing up the exaust. Have work in the morning, will have pics up soon.
BPB Posted October 27, 2008 Author Posted October 27, 2008 The header is in. Aside from fighting leaky injectors everything went pretty smooth. Here is the relocated o2 sensor here is my old manifold, pretty bad eh? Here is my redneck exaust work, I had to reduce it from 2" to 2 1/4". It took 2 sleeves and 3 clamps. Then to be safe, I sealed around all the fittings with muffler mender All put together My painted skid plate Image Not Found
