Kenosha Warrior Posted March 31, 2008 Share Posted March 31, 2008 Normally it won't do it on take-off or 2nd but 2-3 and 3-4 shifts it will stutter, shake and waddle like its a dog passing a pinecone. Oddly though, it won't do it all the time. I'm as confused as hell, I cleared out my airintake blockage, Ive put a new gascap on it, all EVAP lines are good, what is my problem!? argh its an 89 4.0 BA-10 5spd. Link to comment Share on other sites More sharing options...
Wildman Posted April 1, 2008 Share Posted April 1, 2008 Sounds like a problem with the valve body or a solenoid. How 'red' does the fluid look??? How many clicks you have on that XJ??? Link to comment Share on other sites More sharing options...
jtdesigns Posted April 1, 2008 Share Posted April 1, 2008 Sounds like a problem with the valve body or a solenoid. How 'red' does the fluid look??? How many clicks you have on that XJ??? hey man the ba-10 is manual... Link to comment Share on other sites More sharing options...
Wildman Posted April 1, 2008 Share Posted April 1, 2008 :nuts: :nuts: :nuts: It's late, I'm tired......ZZzzzzz time. Link to comment Share on other sites More sharing options...
Oizarod115 Posted April 1, 2008 Share Posted April 1, 2008 my truck was acting up between shifts and it turned out some dumbarse... (coughMEcough) had put the TPS in improperly. check the TPS to make sure its working, it would only do it between shifts and it felt like backfiring. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 1, 2008 Share Posted April 1, 2008 Check your EGR valve and transducer while you're at it. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted April 1, 2008 Author Share Posted April 1, 2008 How would I check the EGR? Its sorta like backfiring. But, now I see, that in-city I don't notice it, but if Ive got more than 1/4 tank, it won't do it. Link to comment Share on other sites More sharing options...
Eagle Posted April 1, 2008 Share Posted April 1, 2008 How would I check the EGR? Its sorta like backfiring. But, now I see, that in-city I don't notice it, but if Ive got more than 1/4 tank, it won't do it. You may have water or sludge in your gas. That'll do it. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 2, 2008 Share Posted April 2, 2008 How would I check the EGR? http://comancheclub.com/forums/viewtopi ... highlight= Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted April 2, 2008 Author Share Posted April 2, 2008 cool, Thanks. Link to comment Share on other sites More sharing options...
pingpong Posted April 3, 2008 Share Posted April 3, 2008 it could also be a sign of your fuel pump starting to go bad. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted April 4, 2008 Author Share Posted April 4, 2008 I fiured that. in the few days Ive been offline due to a dead modem, I grabbed a few working spares and scured all the tools to do it roadside-stye if need be. Link to comment Share on other sites More sharing options...
FxRacing282 Posted April 4, 2008 Share Posted April 4, 2008 engine light on? Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted April 4, 2008 Author Share Posted April 4, 2008 what engine light? Renix has no CEL. Link to comment Share on other sites More sharing options...
