Comanche Devil Posted March 23, 2008 Share Posted March 23, 2008 When doing a soa what do you do about the lower shock mount? Actually what would be the easiest way of mounting the lower shock mount? Ford & GM Style I was thinking of. Any sugestions??? Link to comment Share on other sites More sharing options...
Pete M Posted March 23, 2008 Share Posted March 23, 2008 I reused the stock mount and sandwiched it between the axle and the leaf springs. I had to trim it a bit to make it work but it works pretty good. I was able to reuse my perfectly good stock rear shocks. Link to comment Share on other sites More sharing options...
Galford Posted March 23, 2008 Share Posted March 23, 2008 X2 Link to comment Share on other sites More sharing options...
89eliminator Posted March 24, 2008 Share Posted March 24, 2008 weld on shock mounts from Warrior products. Link to comment Share on other sites More sharing options...
Rokhound Posted March 24, 2008 Share Posted March 24, 2008 made my own from some spring perches and welded them like so (CW's looks better but you get the point) Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 24, 2008 Share Posted March 24, 2008 Yup. I made my own as well. I wanted a "cleaner" look than re-using the stock plates. I also wanted them up on the axle tube, out of harms way. I bought shock mounts form the "HELP" rack at the parts store. I took square "C" stock, cut it at about 2" long. Drilled a hole centered, for the stud, mounthed the stud and put a tack weld on the nut. Took the assembly and welded that to the axle tube. I also decided to make new upper mounts to better fit the long shocks I needed. But this isnt required for all instulations. Good luck, CW Link to comment Share on other sites More sharing options...
Duner Posted March 24, 2008 Share Posted March 24, 2008 I tried to utilize the stock spring plates slightly modified eventually they failed and replaced them with the 1/2" thick plates. Anyway there are a number of solutions in this tech question. search this topic on the tech forum: SOA ????'s Link to comment Share on other sites More sharing options...
mjeff87 Posted March 24, 2008 Share Posted March 24, 2008 I reused the stock plates flipped on top, and bought a set of short shocks. They work fine, but I do have a set of RE weld-on perches to put on the tubes, sometime this year... Jeff Image Not Found Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted March 24, 2008 Share Posted March 24, 2008 I reused the stock plates and put them under the axle. I was willing to give up a bit of ground clearance to run a longer travel shock than if I put them on top. Up top even with my lift I was not happy with how short of a shock it would of required. Link to comment Share on other sites More sharing options...
pingpong Posted March 24, 2008 Share Posted March 24, 2008 who needs shocks :brows: Link to comment Share on other sites More sharing options...
Rokhound Posted March 24, 2008 Share Posted March 24, 2008 who needs shocks :brows: where the hec have you been Link to comment Share on other sites More sharing options...
Comanche Devil Posted March 26, 2008 Author Share Posted March 26, 2008 Thanks for all the replys thats great, lots of choices now Comanche Devil Link to comment Share on other sites More sharing options...
DrThunder Posted March 27, 2008 Share Posted March 27, 2008 high clearance and about as easy as it gets, took a piece of 1" by 1/4" steel, drilled a hole in it and bolted in the shock mount and welded it to the tube Link to comment Share on other sites More sharing options...
Mitch Posted March 27, 2008 Share Posted March 27, 2008 I reused the stock plates and put them under the axle. I was willing to give up a bit of ground clearance to run a longer travel shock than if I put them on top. Up top even with my lift I was not happy with how short of a shock it would of required. please tell me the part number and manufacturer for those rear shocks! Or compressed and extended lengths.. I did the same thing and desparately need new shocks. Link to comment Share on other sites More sharing options...
