Comanche Devil
Everything posted by Comanche Devil
  1. Thanks for all the replys thats great, lots of choices now Comanche Devil
  2. When doing a soa what do you do about the lower shock mount? Actually what would be the easiest way of mounting the lower shock mount? Ford & GM Style I was thinking of. Any sugestions???
  3. tjbliley just did about the same amount of lift and he did an AAL and chevy drop shackles and netted a solid 4" he said. What are these chevy drop shackies? and what was the arc on the aal Thanks for the info. 2cents from you is 10 dollars to me
  4. OK just starting the my cheap lift on the Comanche Devil. Put in the T-Bird springs upfront. Netted 4" lift, today I made sway bar disco's from 2000 Grand links , this weekend I will be lifting the rear, so here is the Question. Do I re-arch the spring pack to achieve the 4" needed or make up longer shackles, or do the both? And about how much arch to net 4"? I know for a 3" lift the springs need a 5" arcs for a 4" would you go 7" or 8"arc? Don't want to do a soa because i will get 4.5-5" and thats too much. Now for tires do I go with 31" or 32"? I want some opinion I know there are only a 1" but what is the pros/cons. Need some experience opinions.
  5. :Canadaflag:
