deziped Posted July 10, 2008 Share Posted July 10, 2008 Thats a major leak yuh got there. A couple of 4 x 4 sheets of plexaglas & 1/2 dz rolls of duct tape ought to plug it up. Link to comment Share on other sites More sharing options...
watchamakalit Posted July 10, 2008 Share Posted July 10, 2008 PPPPSSSSHHHHHH. $#!&'ll buff out. Link to comment Share on other sites More sharing options...
Lewt2007 Posted July 17, 2008 Share Posted July 17, 2008 mine only leaks at the top of the drivers door and i can see the weather striping at the bottom of the door when the door is closed at the rear of the door. i used a old spark plug wire with the ends cut off to force the rubber striping down to make it seal better does anyone know where to get the rubber pieces that go down along the windshield frame because mine are missing Link to comment Share on other sites More sharing options...
Eagle Posted July 17, 2008 Share Posted July 17, 2008 I'm pretty sure mine is somewhere on the firewall. Haven't located it yet, its on my to do list Ditto Link to comment Share on other sites More sharing options...
Wildman Posted July 17, 2008 Share Posted July 17, 2008 mine only leaks at the top of the drivers door and i can see the weather striping at the bottom of the door when the door is closed at the rear of the door. i used a old spark plug wire with the ends cut off to force the rubber striping down to make it seal better does anyone know where to get the rubber pieces that go down along the windshield frame because mine are missing Yea......there really pricey, but - http://www.teamcherokee.com/Weatherstrip/index.html Or find some good ones in a junk yard????? Link to comment Share on other sites More sharing options...
jtdesigns Posted July 17, 2008 Share Posted July 17, 2008 Mine leaked on both sides at the door, ran down past the hinges under the door sill plate and then ran into the cab from under the sill. Turned out to be the strip of seal JEEP added to the under side of the A pillar when they found out they had a leak problem. I pryed them away from the pillar a bit & squirted sealer under them & then used masking tape to hold them tight against the pillar until the sealer dryed. Haven't had a leaak since. Here's a pic of that rubber strip.Image Not Found[/img] I need to replace one of those.. I have the piece but were do i get the rivets for it?? Can I just use reg metal rivets?? I was just going to use some 3M double sided tape, but now I don't think only the tape will hold... Link to comment Share on other sites More sharing options...
jtdesigns Posted July 18, 2008 Share Posted July 18, 2008 Any suggestions to the above???? Link to comment Share on other sites More sharing options...
dragonrider477 Posted July 20, 2008 Author Share Posted July 20, 2008 rained like hell here today.the water pours in through the vent window rubber gaskets,drips on the interior door panels and puddles on the floor. this explains why the door panel cardboard was wet when i changed the radio speakers last month.if this is the only leak i am going to swap the fixed vents from my 1993 xj parts truck.will they fit my 88 mj? are they less likely to leak water?the vents always had wind noise so i was planning to swap them out eventually to the fixed type but now i will move this mod to the top of the list.just an update on the leaks. since swapping out the vents the leaks have totally stopped.i would have never thought in a million years that so much water could pour in through those moveable vent assemblies! live and learn. Link to comment Share on other sites More sharing options...
Wildman Posted July 20, 2008 Share Posted July 20, 2008 Any suggestions to the above???? I pull one off today, yes there plastic pop rivets........and guest where I found them.......Here Link to comment Share on other sites More sharing options...
jtdesigns Posted July 20, 2008 Share Posted July 20, 2008 Any suggestions to the above???? I pull one off today, yes there plastic pop rivets........and guest where I found them.......Here Hey man you think it needs a special rivet gun or just any will work?? Link to comment Share on other sites More sharing options...
Wildman Posted July 20, 2008 Share Posted July 20, 2008 Any suggestions to the above???? I pull one off today, yes there plastic pop rivets........and guest where I found them.......Here Hey man you think it needs a special rivet gun or just any will work?? Any pop rivet gun will work, I've use the nylon rivets before in a regular gun ;) Here's the whole set :brows: Link to comment Share on other sites More sharing options...
highlandjeeper Posted July 21, 2008 Share Posted July 21, 2008 My 91 has a leak above the windshield. The roof sheet metal is rusted away along the pinch weld. I am trying to get it sealed up for now. Today I cut a new roof skin from a good cab in the wreckers so that someday I can mabe change it out. Link to comment Share on other sites More sharing options...
Jiffy Posted August 9, 2008 Share Posted August 9, 2008 I once had an early Lotus Elan that leaked so bad it would fill up to the door sills. Used to have to bail the drivers side to drive home. finally gave up and drilled drain holes in the floor. It still leaked, but the water went right through. Make sure the drain holes in the fresh air vent in front of the windshield isn't plugged with leaves. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 9, 2008 Share Posted August 9, 2008 Make sure the drain holes in the fresh air vent in front of the windshield isn't plugged with leaves. Where exactly is that and how do you get to it? Pics will help. :D Thanks. Link to comment Share on other sites More sharing options...
highlandjeeper Posted August 24, 2008 Share Posted August 24, 2008 My leak is gone :D . All this hot weather must have softened the sealant (appears to be roofing tar) the glass shop put on trying to stop the leak enough to run into the leaky spot. We had rain for almost 2 days and not a single drop came inside. Now I can put my headliner and interior trim back in. Link to comment Share on other sites More sharing options...
mjdoa Posted August 25, 2008 Share Posted August 25, 2008 I love when stuff fixes itself. :cheers: Just never seem to be that lucky myself. Link to comment Share on other sites More sharing options...
