shdbriding Posted February 27, 2008 Posted February 27, 2008 For a 91 with a gear indicator for a column shift. Do they exist??????
JeepcoMJ Posted February 27, 2008 Posted February 27, 2008 police cruiser option. pretty much you won't find it BUT you can take your indicator out and install it in a full gauge cluster. just need to cut out the hole for it on the tach
mjeff87 Posted February 27, 2008 Posted February 27, 2008 there's a column shift 2WD MJ down at the local junkyard right now (but it's older than 91, thinking it's an 88 or 89 IIRC). Not sure if it's a full gauge cluster or not, but if it is and anyone wants it, lemme know and I'll pull it this weekend. I'm heading there to pull some parts off it anyway.... Jeff
A-man930 Posted February 28, 2008 Posted February 28, 2008 I've got a full cluster from a 90 if you're interested.
Eagle Posted February 28, 2008 Posted February 28, 2008 I've got a full cluster from a 90 if you're interested. 90 was the last year for the mechanical speedo. He has a 91 -- he needs an electronic speedo.
HOrnbrod Posted February 28, 2008 Posted February 28, 2008 For a 91 with a gear indicator for a column shift. Do they exist?????? You could always install a 91-96 full gauge cluster w/o the shift indicator and use one of these:
Chico Posted February 28, 2008 Posted February 28, 2008 Oh for the love of god hornbrod, couldn't you have posted that up earlier. I ripped apart 3 Tachs cutting a straight freakin line. Where did you get that?
jaekl Posted February 28, 2008 Posted February 28, 2008 There's always the default indicator. Look out the window. If the scenery goes front to back you are in D. If the scenery is moving and the engine is off, you're in N. What about after dark? Turn on the illumination (headlights). Sorry, I'm having a slow day.
shdbriding Posted February 28, 2008 Author Posted February 28, 2008 Hey Hornbrod x2 on where did you get that and how much of a pain was it to install?? :bowdown: That looks really nice. Does it light up with the dash lights?
HOrnbrod Posted February 28, 2008 Posted February 28, 2008 Hey Hornbrod x2 on where did you get that and how much of a pain was it to install?? :bowdown: That looks really nice. Does it light up with the dash lights? Unfortunately does not light up, but I'm fooling with some LEDs to come on with the headlights mounted inside the column and will ride the pointer. Just have been too lazy to do it. These are made by Ididit and are made specifically for the GM 3-speed auto trannys, but the pointer lines up perfectly in all gears w. the AW4. They can be had here: http://www.ididitinc.com/column_ad_ons.htm I found two of them on Ebay for cheap. Of course I had to go for the chrome outer shell which screws on instead of using double-sided tape. The install is stupid simple.
Chico Posted February 28, 2008 Posted February 28, 2008 Man , I love the people on this sight! :bowdown:
tjbliley Posted February 28, 2008 Posted February 28, 2008 I have one of those to go in mine when I paint the column. Summit racing.
shdbriding Posted February 29, 2008 Author Posted February 29, 2008 The install is stupid simple. Gotta love that. I will definately be keeping my eye out for one.
