Jeep Comanche 4.5in lift leaf springs
I'm not 100% sure if that would net you 9-10" of lift.. Guessing that from SOA's giving you 4-5" and those springs are 4.5 lift.. someone will chime in I'm pretty sure.
wow. what would you have to do to the front then?
Check my build thread , i didnt do the rustys springs but i did do an add a leaf on a soa and got 9" +-
you would probably get a 9-10in lift if you did that. and you would get a really high center of gravity as well.
Would prob look like a baby version of these new trucks ( Fords, Chevy's and Dodges) lifted so high they don't even look like they are anything other than someones RC toy on steroids.
doing some figuring to see what i'll need one of these days. i only want a 6.5 inch lift. now do the front and rear equal out if you do it front and rear that height or what do you have to do? i know you get an mj lift for the front, and either a aal or soa for the rear, and i am going to do a soa for the rear.
6.5 is easy, grab some old MJ leafs or explorer leafs and bastard pack the two together on SOA til desired ride height is accomplished :cheers:
front, grab some rubicon express (doesn't really matter who's springs but i swear by RE) 5" springs or 6" springs and use a small spacer to get your 1/2"
at 6+" you'll NEED to address control arms and probably steering. and definitely track bar. a drop bracket kit for CA's would do it, or a Long arm kit, anything for a 6" cherokee lift will work
