fuel miser
a1awind
no tailgate?!?!? but mythbusters proved it doesnt make a difference!
That is funny, I have had 6 pick-up's in my life and I have went with and w/o a tailgate on all of them.
Some like my 1st Ranger, S-10 and F-150 did not make a difference and then I would have some like my 96 Ram that would make a difference of 3-4mpg :nuts:
I was doing some quick research today to see what the HP rating was when the 4.0 came out in 87 compared to 88 and up. I had read that in 87 the 4.0 was 150hp, 88-90 177hp, and 91-92 190hp. Various info on that w/no confirmation, because I also found new info that basically said the 87 had 173hp and after a few tweaks in 88 it went to 177, w/torque also rising slightly.
Anyhoo, I also saw that when AMC replaced the GM 2.5 w/their own, which was after they were bought by Chrysler if I am correct, that Chrysler also had a 2.5 rated at 100hp. I did not read the piece word for word from there to the end but I'd say it's a fair guess that's your fuel miser engine.
if the gm 2.5 and amc 2.5 are the same engine they they should have interchangable parts right ?
These are NOT the same engine!
Here is a link to the Iron Duke information: http://en.wikipedia.org/wiki/GM_Iron_Duke_engine
The AMC engine is a cut down version of the 4.0 litre 6 cylinder.
They are two different engines that have about the same displacement.
Iron Duke has a 3 inch stroke and a 4 inch bore. check this link:
http://www.jeeptech.com/engine/gm151.html
;The AMC 2.5 litre engine has a 3.88 bore and a 3.19 stroke. See the following link:
http://www.jeeptech.com/engine/amc150.html
Hope this helps you.
...........and then a third 2.5L built by Chrsler, also with different specs.
I still think this is the engine that was in the Fuel Miser MJ because about that time Chrysler had the Omni Miser and I think a K car Miser pkg; point being that it would make sense to use the same engine in similar marketing rather than have to de-tune and AMC 2.5L. I could be completely wrong, because this was when Chrysler was struggling to survive and apparently didn't have the brightest bulbs in the house when it came to mgt at that time, but logic would suggest it makes sense, IMO.
I realize this may just be semantics, but the '91+ 2.5L was redesigned/modified by Chrysler (electronics, head, etc.) but they kept the major dimensions/specs of the block. I'm told any 91+ XJ/TJ 2.5L block can be swapped pretty much directly into the older MJs. I'd bet the 2.5L in a Dakota would work the same way. :brows:
:yeah that:
The 2.5 Chryco engine was derived from the 2.2. An OHC engine. Never in a Jeep. Dakota used both the OHC Chrysler engine, and also the AMC 2.5.
AND, the 2.5 AMC engine came out BEFORE the 4.0L did. 1984 for the AMC 2.5 and 1987 for the 4.0L. These were both derived from the AMC 258/232.
