Beatrice should be coming home this weekend. Decided first thing I wanna do before it gets too cold is wash her down well, and try to get rid of 10 years worth of grime build up on her due to being left "abandoned" in a field . Never bought a pressure washer up until now. Been looking thru marketplace. I want to try and get something "good" that will hold up in the future and that I can also use to clean the exterior house walls, wooden decks, concrete slabs, gutters, etc..
I'm partial to DeWalt,  just because I like yellow :roflmao:
Seriously though guys, what should I look for?
Gas powered?
Brand?
PSI?
Anything else anyone recommends?
All opinions welcome and appreciated!
Thnaks!
*Not a pressure washer expert.
Gas over electric, and the highest pressure and flow you can afford.  I think they are all very similar as far as build goes.  Motor pump and a hose, not much to them.  I purchased a Coleman(?) Several years ago from tsc. Honda motor on it, the whole unit has been a home run. I'd buy another today if needed.
I've had a couple gas units and been happy with them but with the cost of fuel and the maintenance on them for seasonal use I gave an electric unit a try.
6-7 years later our ryobi unit from home depot still does the job! Psi not accurate to my machine but thats the essential unit.
I got one from Costco years ago for a solid price. Mine is gas and I prefer gas over electric, but that's me. I've been snagging some of vevor's stuff lately and for the price hard to beat but not everything ahs been great of theirs.
https://www.vevor.com/pressure-washers-c_11609/vevor-gas-pressure-washer-3400-psi-2-6-gpm-gas-powered-pressure-washer-with-aluminum-pump-spray-gun-and-extension-wand-5-quick-connect-nozzles-for-cleaning-cars-homes-driveways-patios-p_010834768806?adp=gmc&srsltid=AYCX9vKykJMOr1clk-zSFLzvOqoOStt_LIDNllLD0hZNvKP3epqVTiXBt-c
There's always hobo freight too.
https://www.harborfreight.com/2650-psi-24-gpm-56-hp-196cc-pressure-washer-epa-71098.html
End of the season so some times can find clearance deals at lowes and home depot
As for specs at least 2000 psi, gas or electric (I've had better luck with gas),  tecumsech, honda, yamaha, honda, briggs and stratton all good engines.
Ok,
I started researching some online.
Thanks for all the input guys!
1) Majority rules so we're going gas, not electric.
2) One of these engines, " tecumsech, honda, yamaha, honda, briggs and stratton"
3) Brand? Guess there's plenty of options
4) PSI, no less than 2000
5) GPM ?
6) Plenty of nozzle options and a foam cannon
So now,
Forget cost, let's say budget doesn't matter....
I give each one of you an empty credit card, and tell you the stuff I'll be cleaning yearly with it at my house. (the stuff mentioned above),
and then using it at my 80 year old aunt's house,
and my 65 year old cousin's house,
and the two 70 year old ladies that live next door,
and...you get the picture.
( Renting not a good choice Pete.) ( My $250, 20 year old, marketplace, 42" deck, lawn tractor, runs for 6-10 hours straight every Saturday during the summer. (lol) ( Craftsman, It's got a Honda engine :applause:)
So I give each one of you guys that blank credit card and say, "go!"
What gas powered  pressure washer you bringing home?
Brand?
PSI?
GPM rate?
HP?
And let's get a move on it Pete. (Wahoo's not here so, I gotta harass someone constantly, sorry.)
After this we're doing "basic tools needed for a complete teardown".
Or do we have that thread already so I can save some time? :roflmao:
"AND GOOOOOOOO!!!!!!!"
Make it something hot water capable at that point. Hot water is a game changer in pressure washers. And if I'm not mistaken a "hot water"pressure washer can be used with cold water also with no changes.
I mean, I clean my mower with the garden hose and an old mop, so...  :laugh:
I own a westinghouse electric that does 2300 psi.  it's ok for regular jobs.  I would not use it for big jobs like a house or driveway.  takes too long.  but on the plus side it fits in a rubber maid tote so it's easy for me to transport to other peoples' houses inside the car.
If cost isn't a consideration then 100% a portable hot water pressure but now your into the thousands.
I'd be looking at bang for the buck but that is just me. I'd hold out for a HF coupon and get one of these or a smaller one.
https://www.harborfreight.com/4400-psi-42-gpm-13-hp-420cc-commercial-duty-pressure-washer-epa-71102.html
Otherwise just look around at something on sale local.
https://www.costco.com/p/-/yard-force-3200psi-25-gpm-honda-gx200-196cc-gas-pressure-washer/4000309374
https://www.lowes.com/pd/SIMPSON-Powershot-3500-PSI-2-5-GPM-Cold-Water-Gas-Pressure-Washer/5014825463
All of the advice in this thread is spot on.
I've used a few electric and gas ones, they all worked well.  Higher pressure is better if doing larger areas.
My family shares a rather new DeWalt with Honda engine and 3200 psi rating, it is excellent.  I will say it was very annoying to change the engine oil on.
I have borrowed a Green Works electric one running probably 2000 psi, it also is quite good.
