Antwon Posted 1 hour ago Posted 1 hour ago I have the basic cluster with the big gas gauge and mph gauge but I want one with a tachometer. Is there anything I can pull one from that is just plug and play
eaglescout526 Posted 1 hour ago Posted 1 hour ago Plug n play. Just need to swap the oil sender for a sensor. Same with the temp sender. And depending on the engine you might have to adjust the tach. also Speedo is important too.
