MJKally Posted September 22 Posted September 22 Hello, I recently picked up a 1990 4.0 Comanche as a project, with an AX-15 5-speed transmission. It was sat for 20 years until someone bought it and did some work to get it back on the road, they got it running and put a new clutch, clutch master, and clutch slave cylinder on it and (apparently) bled it, then ran out of time and money to work on it so they sold it to me. How much they knew about the issues I'm about to describe is anyone's guess, but it's my problem now. The transmission pops out of first gear pretty easily. It doesn't click into place as nicely as the other gears seem to, and if you give it some gas, it makes a bang and pops out of gear. if you try to hold it in, it grinds and tries to kick the shifter out. Second gear works just fine, and I’ve been using it in place of first to move the truck around, since it seems to be able to set off from a dead stop just fine in second. I haven't driven it far enough to get to third or fourth gear yet, but they seem to shift okay. The other issue is that it gets stuck in reverse quite a lot. I suspect this is a clutch issue and it maybe needs bleeding more, because it refuses to disengage unless you push the clutch pedal to the floor and into the carpet, that just seems excessive. I am aware that there's a technique for shifting into reverse on these boxes which I haven't quite learned yet, but it getting stuck in reverse seems to be more than just user error. I know that I'm in for a rebuild, but what can i expect to be replacing? The rebuild kits for the AX-15 all come with the syncro rings, but I don't know if that'll be enough, or if i'm going to need to replace gears or the sleeves on the shift forks. Thanks.
ghetdjc320 Posted September 22 Posted September 22 I’d suspect you may need a new synchro hub/sleeve and it may be wise to replace firs gear and reverse. There is also an updated 5th gear kit. You have the option to just buy a new or rebuilt ax15 which may be the easier bet. The ax15 is a fun but tedious rebuild process
Eagle_SX4 Posted September 22 Posted September 22 First gear popping out of gear is probably due to a worn shift fork. I had the same problem on a used AX15 I picked up. The previous owner rebuilt it but didn't look at the shift forks. A worn shift fork doesn't let you put it fully into gear and it pops out. The AX15 doesn't have shift pads on the forks and they are a wear item that needs to be looked at closely when rebuilding.
pizzaman09 Posted September 23 Posted September 23 I would at least bleed the clutch and make sure you are getting it fully to fully disengage the clutch. I could see where it is it struggling to get into the gear fully from a standstill in first. I am not confident this will fix it but it is way easier than tearing into a transmission.
87MJTIM Posted September 23 Posted September 23 MJKally, nice to see you found ComancheClub. I had responded to you on JF previously. (I couldn’t recommend you to CC or else JF would chastise me.) You can find all the information I referenced on CC and more. The members here really knowledgeable and will help you with all things MJ. Post some of your other pictures on CC. Also register your MJ in registry section. Welcome to the addiction!
MJKally Posted September 23 Author Posted September 23 Thanks for the advice. It looks like I’m going to have to disconnect the clutch hydraulic lines to get the transmission out whatever I do, so I'll have to bleed the system again when it goes back in. The previous owner, who installed all the clutch parts, did say that he'd bled it and it was apparently difficult to do on these, so any pointers are welcome. I've bled my fair share of brakes, but never a clutch, so I'm not sure if the process is any different. As far as the transmission itself goes, I was thinking a rebuild was my only real option, since I was under the impression they were hard to find over here in the UK. I did a little research, and it turns out that the UK spec 2.5L turbodiesel cherokees all came with the AX-15 untill 1999. I wasn't getting any results for AX-15, but I looked up 2.5L TD cherokee transmissions and found several options. I'm currently looking at one that's less than the cost of a rebuild kit, the seller is going to send me some more pictures, but if it checks out then I’ll go with that option. It even comes with the shift knob, which mine is missing.
Eagle_SX4 Posted September 23 Posted September 23 56 minutes ago, MJKally said: Thanks for the advice. It looks like I’m going to have to disconnect the clutch hydraulic lines to get the transmission out whatever I do, so I'll have to bleed the system again when it goes back in. The previous owner, who installed all the clutch parts, did say that he'd bled it and it was apparently difficult to do on these, so any pointers are welcome. I've bled my fair share of brakes, but never a clutch, so I'm not sure if the process is any different. As far as bleeding the clutch it depends on if you have an internal or external slave cylinder. If yours is stock it should be an internal. It is common to swap to the later external slave for better reliability and easier hydraulic maintenance.
MJKally Posted September 23 Author Posted September 23 The replacement transmission I'm looking at is out of a '98, so it looks like it has the external slave cylinder. If it's all in good working order then I see no reason not to keep it.
89 MJ Posted September 23 Posted September 23 41 minutes ago, MJKally said: The replacement transmission I'm looking at is out of a '98, so it looks like it has the external slave cylinder. If it's all in good working order then I see no reason not to keep it. Definitely keep that external slave, it is definitely an upgrade. The new internal slaves seem to lack in quality.
MJKally Posted September 24 Author Posted September 24 I did some reading, and it looks like I’d need a different bellhousing to use the external slave cylinder. I could potentially find one, since I think some of the wranglers sold here would've come with the 4.0 and the AX-15, and they would have the bellhousing I need. But, I need a transmission now. And I can't really wait around for one of those to turn up, so that can be a potential future upgrade.
Eagle_SX4 Posted September 24 Posted September 24 If you are going to use the '98 AX15 with an internal slave cylinder you will need to switch the front bearing retainer from your old transmission to the new one so the clutch can function properly. You will also need to get a different pilot bearing. The pilot tip changed to a bigger diameter in about '93.
pizzaman09 Posted September 26 Posted September 26 I found these to be super easy to bleed, I let it gravity bleed for 15 minutes and my clutch was perfect.
