Antwon Posted Sunday at 09:18 AM Posted Sunday at 09:18 AM Can someone tell me why my interior lights aren’t working, the headlights and taillights and radio lights work as well of the parking brake light I know you are supposed to turn the light knob but that isn’t working
Pete M Posted Sunday at 01:45 PM Posted Sunday at 01:45 PM the lights themselves should rotate up and down, with one of those 3 positions being "on".
AnotherOldJeepGuy Posted Sunday at 04:04 PM Posted Sunday at 04:04 PM There are actual bulbs in the fixture, perhaps they have burnt out?
Torq_Shep Posted Sunday at 08:31 PM Posted Sunday at 08:31 PM Be aware, the factory housing are insanely fragile. Only try and take the lens off if you are checking the bulbs, do not try to pry out the whole assembly or it will break.
jodawill Posted Sunday at 10:25 PM Posted Sunday at 10:25 PM I've had great success repairing the clips with Gorilla Glue. I found three of the four tabs inside the pillars when I pulled the carpet. If you want to replace them, I can sell you the ones I bought and didn't use. They require you to cut the trim just a bit, which I have no interest in doing if I don't have to.
Torq_Shep Posted Monday at 12:18 AM Posted Monday at 12:18 AM 1 hour ago, jodawill said: I've had great success repairing the clips with Gorilla Glue. I found three of the four tabs inside the pillars when I pulled the carpet. If you want to replace them, I can sell you the ones I bought and didn't use. They require you to cut the trim just a bit, which I have no interest in doing if I don't have to. I personally committed to the Euramtecs they look close enough to the originals and aren't made of dust but I didn't enjoy trimming the 1/4" out of the one side.
fiatslug87 Posted Monday at 12:26 AM Posted Monday at 12:26 AM Interestingly, I found there are two types of lights, on one the back plastic is gray the other yellowish. The gray ones do not seem to be as fragile. The top one is NOS, tabs never compressed.
llhat Posted Monday at 12:42 AM Posted Monday at 12:42 AM 4 hours ago, Torq_Shep said: Be aware, the factory housing are insanely fragile. Only try and take the lens off if you are checking the bulbs, do not try to pry out the whole assembly or it will break. guidance on removing the lens?
Torq_Shep Posted Monday at 12:48 AM Posted Monday at 12:48 AM 6 minutes ago, llhat said: guidance on removing the lens? Pry carefully between the lens and the chrome surround putting inward pressure on the lens side until it pops out of the socket. You only need to get one side loose and the lens will come off. Left and right side is where the retaining sockets are, do not pry on the top or bottom sides. The lens rarely breaks. It is the chrome surround and other plastics that fall apart so when in doubt put pressure on the lens.
jodawill Posted Monday at 04:00 AM Posted Monday at 04:00 AM 3 hours ago, Torq_Shep said: I personally committed to the Euramtecs they look close enough to the originals and aren't made of dust but I didn't enjoy trimming the 1/4" out of the one side. I don't want to do it until I have no other options. If I do, I'd like to have the bezel chromed first so it matches the original.
