1J7FT26S5NL129750
Ricky8227
Hello I’ve tried searching in the group where to post vin to find my build sheet and can’t find any answers. So I figured I’d post it here?
1992 jeep Comanche
vin: 1J7FT26S5NL129750
  • fiatslug87 changed the title to 1J7FT26S5NL129750
BODY: TL62
BUILD: 09/23/91
SELLING DEALER: WILLIAM CLARKE MOTORS INC
CHARLESTON, SC
*C1 DESCRIPTION NOT AVAILABLE -SA CHARCOAL ALAP
BARP 90 AMP ALTERNATOR BCDP 550 AMP MAINTENANCE FREE BATTERY CBAP STRAIGHT BACK BENCH SEAT
CKAP CARPET DBBC ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION
ERH 4.0L I6 GRZP LEFT REMOTE MIRROR GSZP RIGHT REMOTE CONTROL MIRROR
GTZP MANUAL REMOTE MIRRORS HAA AIR CONDITIONING JHAP VAR INTERMITTENT WINDSHIELD WIPERS
JJAP CIGAR LIGHTER KERP DARK SILVER MET. - BADGE - LWB MBJP BLACK FRONT BUMPER
MDA FRONT LICENSE PLATE BRACKET MHAP BLACK WINDSHIELD MOLDINGS MMKP
PE4   RAAC ALL RADIO EQUIPPED VEHICLES RAFP OPEN
RCDP 4 SPEAKERS SBAP POWER STEERING SCGP LEATHER WRAPPED STEERING WHEEL
SUA TILT STEERING COLUMN TMWP TIRES TZHP MICHELIN BRAND TIRES
WJHP 15X7 ALUMINUM WHEELS WLZC ALL ALUMINUM WHEELS YGEA 5 ADDITIONAL GALLONS OF GAS
Z01P REAR SPRING GROUP I Z58P LEFT FRONT SPRING GROUP VIII Z78P RIGHT FRONT SPRING GROUP VIII
2TCA CUSTOMER PREFERRED PACKAGE 2TC 25C CUSTOMER PREFERRED PACKAGE 25C 3VNA CUSTOMER PREFERRED DISCOUNT
4BJA WHEEL CREDIT 4HA SPECIAL SCHEDULING CONDITION I 4M1P RETAIL TO BID DIVERSION TRACKING
4UAA
APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES CUMS MINI FLOOR CONSOLE
DMMS 3.07 REAR AXLE RATIO DRJS DANA 35 REAR AXLE GACS TINTED GLASS WINDOWS
GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS GEHS FIXED DOOR VENT GLASS
JAZS DO NOT USE - SEE JP, KA CLASSES JCAS 85 MPH PRIMARY SPEEDOMETER KWRS STRIPE/BADGE/MOLDING/COLOR
K3ZS STRIPE/BADGE/MOLDING/COLOR LAPS SHIFT INDICATOR WARNING LAMP LBCS GLOVE BOX LAMP
LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER MFFS BLACK GRILLE
MMCS   MMGS BELT MOLDINGS NAAS FEDERAL EMISSIONS
NBKS EVAP CONTROL SYSTEM NF5S 23 GALLON FUEL TANK QE4S
Colorado Red
SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBCS COMPACT SPARE TIRE
TBMS TIRE CARRIER WINCH XBSS PICKUP BOX YAAS BUILD TO U.S. MKT. SPECIFICATIONS
Z1AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL 167S ZONE 67-CHARLOTTE
9 hours ago, jdog said:
BODY: TL62
BUILD: 09/23/91
CHARLESTON, SC
*C1 DESCRIPTION NOT AVAILABLE -SA CHARCOAL ALAP SE DECOR GROUP
CKAP CARPETS - FLOOR AND CARGO AREA DBBC ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION
ERH 4.0L I6 POWER TECH ENGINE GRZP LEFT REMOTE MIRROR GSZP RIGHT REMOTE CONTROL MIRROR
JJAP CIGAR LIGHTER KERP DARK SILVER MET. - BADGE - LWB MBJP BLACK POWDER COATED FRONT BUMPER
MDA FRONT LICENSE PLATE BRACKET MHAP BLACK WINDSHIELD MOLDINGS MMKP LOWER GRILLE SURROUND-PAINTED SILVER
PE4 Colorado Red RAAC ALL RADIO EQUIPPED VEHICLES RAFP OPEN
SUA TILT STEERING COLUMN TMWP 18 TIRES TZHP MICHELIN BRAND TIRES
4UAA SCA TISSUE NORTH AMERICA LLC
DMMS 3.07 REAR AXLE RATIO DRJS DANA M235 WIDE REAR AXLE GACS TINTED GLASS WINDOWS
MMCS REAR SWING DOOR PANEL INSERTS MMGS BELT MOLDINGS NAAS FEDERAL EMISSIONS
NBKS EVAP CONTROL SYSTEM NF5S 23 GALLON FUEL TANK QE4S Colorado Red
Thank you so much. So this means my jeep was originally Red? Crazy cause it looks like it was blue from factory. Looks original paint with decals
Paint codes have been reused over the years. Double check your firewall tag for the same color code.
Would the original color be what’s under the carpet? I have the carpet removed and the tunnel and floors are gloss metallic. Fire wall tag? Like the sticker that is usually on the drivers side? Previous owner painted over it lol
8 minutes ago, jdog said:
the firewall tag will be in the engine compartment, if i remember right it is under the wiper cowl
Is it a sticker? Or metal tag? Previous owner painted over the sticker
