camjeep3 Posted October 20 Author Share Posted October 20 After re reading my thread I realized the timeline and context of everything was confusing. At one point I did have good spark at the plug. But now I do not. I picked up a basic spark tester and fuel pressure gauge. Fuel pressure is good. No spark. That brings me back to the cps. The two o thought I ordered I never actually ordered. So those are on the way now. Link to comment Share on other sites More sharing options...
camjeep3 Posted yesterday at 10:51 AM Author Share Posted yesterday at 10:51 AM Swapped cps. No spark. No voltage at plug. Going to try a different meter to rule that out. But this is getting old Link to comment Share on other sites More sharing options...
ratrapp Posted yesterday at 04:58 PM Share Posted yesterday at 04:58 PM you can still have a bad coil or ignition module thats under the coil. Link to comment Share on other sites More sharing options...
Ωhm Posted 23 hours ago Share Posted 23 hours ago Using a voltmeter or 12vdc testlight (preferred) check for Battery_Voltage on the following pins (use battery_negative terminal for ground): D1_5: Battery_Voltage (Hot at all times) D1_6: At KEY ON, (Hot for 2-3 seconds). During CRANK, (Hot at all times). D2_4: At KEY ON, (Hot at all times). During CRANK, (Hot at all times). Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted 23 hours ago Share Posted 23 hours ago 6 hours ago, camjeep3 said: Swapped cps. No spark. No voltage at plug. Going to try a different meter to rule that out. But this is getting old When you are checking the CPS are you cranking the engine over with the starter? The CPS only creates voltage when the engine is spinning. Link to comment Share on other sites More sharing options...
camjeep3 Posted 23 hours ago Author Share Posted 23 hours ago Ohm. I will do that and report back. Eagle. Yes. I have the multi meter in the cps plug and on the hood while I crank. I have tried back probing and directly to the pins in the plug Link to comment Share on other sites More sharing options...
camjeep3 Posted 23 hours ago Author Share Posted 23 hours ago Before I start throwing more ignition parts at it I want to at least confirm cause cps output Link to comment Share on other sites More sharing options...
llhat Posted 19 hours ago Share Posted 19 hours ago sort of a captain obvious here... you are checking the CPS on the sensor side of the plug and not the wiring harness side??? no flames please Link to comment Share on other sites More sharing options...
camjeep3 Posted 7 hours ago Author Share Posted 7 hours ago No flames here! It's a valid question. Yes I am checking at the sensor Link to comment Share on other sites More sharing options...
