MJ 4.0 Posted April 24, 2025 Share Posted April 24, 2025 I recently purchased some Hella Fog Lights for my 88' Comanche, (thanks to a recommendation from a Comanche Club member!) I'm in need of a rocker switch, hopefully that matches what's already installed in the dash. Am I better of going to a salvage yard or is there OEM switches available? I looked on Ebay and most switches fit late model Cherokee XJ's but I'm not sure they are the same size? Appreciate any guidance! Thx. LB Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted April 24, 2025 Share Posted April 24, 2025 The part number for that switch is 56000025. I have pulled several out of Cherokees from the junkyard. I am fairly certain that Jeep used the same switch for the power/comfort transmission switch. Link to comment Share on other sites More sharing options...
llhat Posted April 24, 2025 Share Posted April 24, 2025 ^^^ i understand this to be true, but 'many' years ago i used a switch obtained from parts store and put i in the space on dash for the oem fog.... it looks 'different' but is functional ( remember 'many' years ago)... used an aftermarket relay for couple of retangular Chibie lights (these were GM parts counter units!) which now don't work and unsure what i use to replace them. also have seen many OEM switches on the evilbay.... Link to comment Share on other sites More sharing options...
MJ 4.0 Posted April 24, 2025 Author Share Posted April 24, 2025 6 hours ago, Eagle_SX4 said: The part number for that switch is 56000025. I have pulled several out of Cherokees from the junkyard. I am fairly certain that Jeep used the same switch for the power/comfort transmission switch. Thanks. I checked a couple OEM dealers online for that part #. It's evidently been discontinued. Looks like salvage yard is where I'm headed! Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 24, 2025 Share Posted April 24, 2025 Yeah that switch was discontinued back in 2021. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted April 24, 2025 Share Posted April 24, 2025 11 hours ago, MJ 4.0 said: I recently purchased some Hella Fog Lights for my 88' Comanche, (thanks to a recommendation from a Comanche Club member!) I'm in need of a rocker switch, hopefully that matches what's already installed in the dash. Am I better of going to a salvage yard or is there OEM switches available? I looked on Ebay and most switches fit late model Cherokee XJ's but I'm not sure they are the same size? Appreciate any guidance! Thx. LB I sure wish my 1990 looked as good as yours! I assume you must have gotten it repainted. I did ask a shop once if they would quote a repaint and they said they would not touch it, apparently way too much prep work would be needed.. Link to comment Share on other sites More sharing options...
MJ 4.0 Posted April 24, 2025 Author Share Posted April 24, 2025 2 minutes ago, AnotherOldJeepGuy said: I sure wish my 1990 looked as good as yours! I assume you must have gotten it repainted. I did ask a shop once if they would quote a repaint and they said they would not touch it, apparently way too much prep work would be needed.. Hey, thanks yeah I got it repainted three years ago. It was rust free and straight as an arrow, but the paint was all faded out. They stripped it down and did a nice job. 5K Got it done. Link to comment Share on other sites More sharing options...
llhat Posted April 25, 2025 Share Posted April 25, 2025 5K Got it done. yep...$$ talks and maybe that is not enough! good luck with parts search. Link to comment Share on other sites More sharing options...
robfg67 Posted April 25, 2025 Share Posted April 25, 2025 eBay has them...buy, pricey. Link to comment Share on other sites More sharing options...
