Whitaker717 Posted March 8, 2025 Share Posted March 8, 2025 Hi guys I need some emergency help. The good news is I fixed the vent issue. The bad news is I had to take the lower dash balance off so everything was disconnected. Once I got everything put back together the idle is so high it sounds like a jet plane. It’s almost like the computer isn’t talking to the engine or something. I don’t see any loose or disconnected hoses. I unplugged the battery , the iac, and tps and no luck. Can someone give me a troubleshooting hand. Link to comment Share on other sites More sharing options...
Whitaker717 Posted March 8, 2025 Author Share Posted March 8, 2025 So going through some trouble shooting, looked at the hoses they looked good, tps was like 4.87 I think, cleaned the iac, and somehow it is back normal. Are those iac’s that temperamental? Anyone have any reccomendations for a new one?Or even have a working used one. Link to comment Share on other sites More sharing options...
Ωhm Posted March 8, 2025 Share Posted March 8, 2025 15 minutes ago, Whitaker717 said: tps was like 4.87 I think, If true, something had your throttle plate held wide open (WOT). Link to comment Share on other sites More sharing options...
Whitaker717 Posted March 8, 2025 Author Share Posted March 8, 2025 What’s weird is I drove all day turned it off and when I turned it back on it sounded like an airplane. Idling time now though. Link to comment Share on other sites More sharing options...
pizzaman09 Posted March 9, 2025 Share Posted March 9, 2025 Check to make sure something isn't catching the throttle linkage, either in the footwell or engine bay. Link to comment Share on other sites More sharing options...
watchamakalit Posted March 10, 2025 Share Posted March 10, 2025 Loose manifold bolts causing a intermittent vacuum leak can cause a surging or occasionally high idle. Link to comment Share on other sites More sharing options...
camjeep3 Posted March 10, 2025 Share Posted March 10, 2025 20 hours ago, pizzaman09 said: Check to make sure something isn't catching the throttle linkage, either in the footwell or engine bay. This is what I was thinking since you were under the dash already Link to comment Share on other sites More sharing options...
BizarroStormy Posted March 11, 2025 Share Posted March 11, 2025 Make sure your throttle position sensor is not binding, that will cause your computer to open your idle air control valve all the way up. Link to comment Share on other sites More sharing options...
