Cruise control switch/stalk, can't find one
  • Replies 54
What I've had good luck with is cutting the wire off of the thing in the column you are replacing, then tape your new connector to it, and pull the wire through the column. Most recently, I had to do it with my whole turn signal switch, but I'd think it should work for anything in the column.
