NC Tom Posted January 20, 2025 Posted January 20, 2025 Happy New Year! It's been nearly four weeks since my last post about this ongoing issue. But, that's okay, because I have collected some additional data/symptoms/etc. Here is a video of the engine turning over, but not starting, as requested by @89 MJ This video was taken a few days prior to Christmas 2024. After this video I let the MJ roll forward a bit and it started. It's done that before so I didn't question it. Just glad it started. The next day, it started fine and I drove it to work. Leaving work, it wouldn't start. The parking lot is sloped, so I tried letting it roll backwards a bit, but no luck this time. At this point, I was in the middle of the parking lot. I put it in Neutral and a couple guys helped me push it out of the way. During the pushing, one of the guys said, "try it now." and it started. Drove home. The next day, the same thing. Turnover, no start. I primed the fuel pump three times and it started. I started thinking about the conditions under which it would and wouldn't start. At home, it's parked on mostly flat ground with a slight nose-down incline. At work, it's parked with a solid nose-up incline. When I got to work, I backed in, so I had a good nose-down incline. Started fine at end of day. Found an area at home to park nose-down too. Also started fine. Up until yesterday, it has been starting and running well for several weeks as long as it's on an incline, nose-down. The only thing that has changed now is that the outside temps have a dropped a lot over the past couple of days. Wouldn't start yesterday. 13 degrees this morning and no starting. It's still parked nose-down. The only other oddball thing is that it will occasionally stall when sitting in traffic for a good while. However, if I put it in Neutral while sitting, it won't stall. I'm not the gear-head that so many of you guys are, but I'm thinking it's fuel delivery. Likely, my brand new fuel pump is not so good. Thoughts?
eaglescout526 Posted January 20, 2025 Posted January 20, 2025 Wait…is this an automatic? If it is maybe we can suspect that the NSS is corroded or dirty inside.
NC Tom Posted January 20, 2025 Author Posted January 20, 2025 2 minutes ago, eaglescout526 said: Wait…is this an automatic? If it is maybe we can suspect that the NSS is corroded or dirty inside. Yes. Auto.
89 MJ Posted January 20, 2025 Posted January 20, 2025 Ok, the cranking rpm in the video sounds about right, maybe a little on the slow side, but definitely quick enough for it to start. I agree that it could be the NSS. Maybe pull that and clean it and both sides of the connector. Check out the wiring too, make sure there are no damaged spots on the NSS part of the harness, that sort of thing. occasionally stalling in traffic unless it’s in neutral makes me wonder about the idle speed. Have you touched the idle screw on the throttle body ever? Do you have a rough idea of what it idles at?
NC Tom Posted January 20, 2025 Author Posted January 20, 2025 3 minutes ago, 89 MJ said: Ok, the cranking rpm in the video sounds about right, maybe a little on the slow side, but definitely quick enough for it to start. I agree that it could be the NSS. Maybe pull that and clean it and both sides of the connector. Check out the wiring too, make sure there are no damaged spots on the NSS part of the harness, that sort of thing. occasionally stalling in traffic unless it’s in neutral makes me wonder about the idle speed. Have you touched the idle screw on the throttle body ever? Do you have a rough idea of what it idles at? Ok, I'll check the NSS. I have not, intentionally, adjusted idle screw. I do not know idle numbers. BTW, I just looked through your videos and such. I gotta say, I am truly jealous of your mechanical talents. And that Eagle is sweeeeet! I'm 58 and I remember when they first came out. I've always really liked the SX4!
llhat Posted January 20, 2025 Posted January 20, 2025 not sure i'll help much, but... have you tested fuel pressure on the rail during this no start condition? other basic tests... Instructions on site CPS output Spark? think the red herring here is the 'rolling' and then firing... IMHO, probably not NSS Stalling... Idle air controller, cleaning Throttle body and the IAC port the MAP sensor and vacuum line connections Possible leaking injector and 'flooding"? Have you tried crank on Wide Open Throttle to initiate the 'flood' start in ECU?? Yeah these no cranks can be PITA, my recent experience paralled could hear fuel pump run, but NO pressure at rail. its going now though.
NC Tom Posted January 20, 2025 Author Posted January 20, 2025 3 minutes ago, llhat said: not sure i'll help much, but... have you tested fuel pressure on the rail during this no start condition? other basic tests... Instructions on site CPS output Spark? think the red herring here is the 'rolling' and then firing... IMHO, probably not NSS Stalling... Idle air controller, cleaning Throttle body and the IAC port the MAP sensor and vacuum line connections Possible leaking injector and 'flooding"? Have you tried crank on Wide Open Throttle to initiate the 'flood' start in ECU?? Yeah these no cranks can be PITA, my recent experience paralled could hear fuel pump run, but NO pressure at rail. its going now though. Sure, checked all the above. I checked the fuel pressure at 30+. It may be a little low. I don't know when it's low enough to be an issue.
89 MJ Posted January 20, 2025 Posted January 20, 2025 1 minute ago, NC Tom said: Ok, I'll check the NSS. I have not, intentionally, adjusted idle screw. I do not know idle numbers. BTW, I just looked through your videos and such. I gotta say, I am truly jealous of your mechanical talents. And that Eagle is sweeeeet! I'm 58 and I remember when they first came out. I've always really liked the SX4! If I were to guess, your idle speed should be somewhere around 900 rpm. I’d also recommend cleaning up the throttle body. Best part about cleaning up the TB will be bringing it inside since it’s cold out haha. Here’s a thread on cleaning it and the IAC. Thank you for the kind words! If you think my Eagle is cool, you should check out Eagle_SX4’s car. 11 minutes ago, llhat said: think the red herring here is the 'rolling' and then firing... IMHO, probably not NSS Stalling... Idle air controller, cleaning Throttle body and the IAC port the MAP sensor and vacuum line connections Possible leaking injector and 'flooding"? Have you tried crank on Wide Open Throttle to initiate the 'flood' start in ECU?? I’m thinking the rolling could just be it getting jostled to where there is contact at the NSS. Good thinking on the vac lines and TB stuff. If I recall correctly, we didn’t think it was flooding because it would seem like the issue would be worse after the engine was just run. The no start condition seems to happen when it’s sat overnight.
NC Tom Posted January 20, 2025 Author Posted January 20, 2025 6 minutes ago, 89 MJ said: If I recall correctly, we didn’t think it was flooding because it would seem like the issue would be worse after the engine was just run. The no start condition seems to happen when it’s sat overnight. What's really interesting is that it seems like if I do not start her every day, this happens. Miss one day and all bets are off. It is cold! Especially for NC! I really need to invest in a garage. I don't mind the work, just not so much when there is snow on the ground.
89 MJ Posted January 20, 2025 Posted January 20, 2025 4 minutes ago, NC Tom said: What's really interesting is that it seems like if I do not start her every day, this happens. Miss one day and all bets are off. It is cold! Especially for NC! I really need to invest in a garage. I don't mind the work, just not so much when there is snow on the ground. That is super weird. I can’t say that I blame you there, I don’t care for the cold weather at all.
llhat Posted January 20, 2025 Posted January 20, 2025 i just do not see the correlation between the NSS and the vehicle running. The circuits on the wiring diagram just do not seem to go to the ECU..controlling the spark and the fuel. but it does control the starting circuit, the reverse lights, and the transmission controls. If you unplug the NSS at the connector under the hood, the starter would not engage, but I'd think if you unplugged with the engine running, it would continue to do so, but the transmission would only shift with the manual lever. temp 'could' have an effect on connections, as well as the CPS response and its output, and "maybe" circuits in the ignition module, etc cold here in the piedmont too.....
pizzaman09 Posted January 20, 2025 Posted January 20, 2025 I feel like this is a just a random connection issue, some connector or solder joint somewhere in the vehicle is not always making contact. Aided or hurt by gravity or thermal expansion/contraction. It wiggle harness and just start systematically cleaning and tightening connections. Use Oxgard where applicable on connections per Cruisers tips.
gogmorgo Posted January 21, 2025 Posted January 21, 2025 Bad NSS is a no-crank situation so it’s not that. Intermittent issues are difficult. And there isn’t much that letting the vehicle roll will do that cranking the engine over won’t also do, other than giving it time to clear out a flood, let a hot component cool down, or let a weakening battery recover a little. If it acts up again, try cracking the throttle a little while cranking, then roll in and out of WOT for clear flood mode. It would also be good to check for spark at the distributor, pull the wire off the middle button and check against ground, just don’t hang onto it yourself. You can also shoot a little starting fluid down the intake to see what happens. Just to confirm you’ve got spark all the way to the plugs. I’ve had three issues on my ‘91 lead to similar results, occasional stalling and no-starts where I’d come back a few minutes later and it would start. The first was the bellhousing bolts were loose, which meant the flywheel and CPS weren’t properly aligned. The second was a worn out distributor that wasn’t moving spark through it. The third was a broken flex plate, likely the result of the loose bellhousing bolts, but leading to similar misalignment problems.
NC Tom Posted January 25, 2025 Author Posted January 25, 2025 Thanks for all the replies. I have not touched the thing in almost a week. Too cold!!!! Warmed up to 40+ today. Plugged in a batt charger and have been letting that sit all day. Tried to start and got turnovers only. Cycled the ignition 3 times and still no start. Let her sit 10-12 minutes and she started! Let her idle for a while I read about Cruiser's posts about the distributor and other mentions here too. I really have not spent any time on that.
NC Tom Posted January 25, 2025 Author Posted January 25, 2025 On 1/20/2025 at 2:31 PM, pizzaman09 said: I feel like this is a just a random connection issue, some connector or solder joint somewhere in the vehicle is not always making contact. Aided or hurt by gravity or thermal expansion/contraction. It wiggle harness and just start systematically cleaning and tightening connections. Use Oxgard where applicable on connections per Cruisers tips. @pizzaman09 You get the award for, "The One Answer I Really Didn't Want to Hear!" Usually, I am a big fan of "random." Not in this case! Ugh!
NC Tom Posted January 25, 2025 Author Posted January 25, 2025 On 1/20/2025 at 1:37 PM, llhat said: i just do not see the correlation between the NSS and the vehicle running. The circuits on the wiring diagram just do not seem to go to the ECU..controlling the spark and the fuel. but it does control the starting circuit, the reverse lights, and the transmission controls. If you unplug the NSS at the connector under the hood, the starter would not engage, but I'd think if you unplugged with the engine running, it would continue to do so, but the transmission would only shift with the manual lever. temp 'could' have an effect on connections, as well as the CPS response and its output, and "maybe" circuits in the ignition module, etc cold here in the piedmont too..... Where abouts in the Piedmont?
89 MJ Posted January 25, 2025 Posted January 25, 2025 Out of curiosity, why did you throw the battery charger on it? It should be able to sit for weeks without needing a charge and it will still start.
NC Tom Posted January 25, 2025 Author Posted January 25, 2025 24 minutes ago, 89 MJ said: Out of curiosity, why did you throw the battery charger on it? It should be able to sit for weeks without needing a charge and it will still start. It's sluggish when so cold. So I figured I would top it off, so to speak.
llhat Posted January 26, 2025 Posted January 26, 2025 2 hours ago, NC Tom said: Where abouts in the Piedmont? just south of greensboro, almost center of the state.
89 MJ Posted January 26, 2025 Posted January 26, 2025 1 hour ago, NC Tom said: It's sluggish when so cold. So I figured I would top it off, so to speak. I can’t remember if you got the battery tested or not, but that points me to believe that your battery is either going bad or doesn’t have enough cranking amps. My truck sat through two, potentially three, winters (November-March) with the battery hooked up and no charger on it and it would start fine in the spring. I’ve since started remembering to unhook the battery, but the battery has been in there since 2019 and hasn’t needed charged. My battery is also an AC Delco and I think all parts store batteries are junk. In terms of the starting issue, I’m thinking pizzaman might be correct being that it sometimes will start after rolling the truck forward. Maybe start with cruiser’s tips and go from there.
NC Tom Posted January 26, 2025 Author Posted January 26, 2025 20 hours ago, llhat said: just south of greensboro, almost center of the state. Ahh. I was born and raised in Raleigh. Worked in Durham, Hillsborough and Mebane. Moved to Deep Gap in 2012.
NC Tom Posted January 26, 2025 Author Posted January 26, 2025 20 hours ago, 89 MJ said: I can’t remember if you got the battery tested or not, but that points me to believe that your battery is either going bad or doesn’t have enough cranking amps. My truck sat through two, potentially three, winters (November-March) with the battery hooked up and no charger on it and it would start fine in the spring. I’ve since started remembering to unhook the battery, but the battery has been in there since 2019 and hasn’t needed charged. My battery is also an AC Delco and I think all parts store batteries are junk. In terms of the starting issue, I’m thinking pizzaman might be correct being that it sometimes will start after rolling the truck forward. Maybe start with cruiser’s tips and go from there. Yeah, battery tested ok. It's a Traveller brand. It's rated well, for what it's worth. Certainly, there is something that is not behaving correctly. Started today without issue. The only thing that has been consistent is a crank/no start when it's well below freezing. Also, I've done many of Crusier's ground checks and refurbishing. But not all.
89 MJ Posted January 26, 2025 Posted January 26, 2025 12 minutes ago, NC Tom said: Yeah, battery tested ok. It's a Traveller brand. It's rated well, for what it's worth. Certainly, there is something that is not behaving correctly. Started today without issue. The only thing that has been consistent is a crank/no start when it's well below freezing. Also, I've done many of Crusier's ground checks and refurbishing. But not all. Ok. Did they load test it or just hook up a regular tester? I'd hate to say that there must be a draw somewhere in the system causing this issue and it turn out to be the battery. I think its worth going through and finishing up Cruiser's tips (maybe once it warms up a little). If this issue is only when its cold, maybe it is the MAT or CTS like eaglescout526 suggested in this thread:
NC Tom Posted February 2, 2025 Author Posted February 2, 2025 On 1/26/2025 at 4:55 PM, 89 MJ said: Ok. Did they load test it or just hook up a regular tester? I'd hate to say that there must be a draw somewhere in the system causing this issue and it turn out to be the battery. I think its worth going through and finishing up Cruiser's tips (maybe once it warms up a little). If this issue is only when its cold, maybe it is the MAT or CTS like eaglescout526 suggested in this thread: It was under load as well. Since it has warmed up a bit, it's been starting fine. Does idle a little rough though. As far as Cruiser's tips, what I have found is that these trucks are essentially hobbies. If you don't like getting your hands dirty, or if you don't have the time or resources, you may experience Comanche Derangement Syndrome or "CDS". I have one foot in the "don't have time or resources" group. So, yeah, I have a little "CDS" going on!
89 MJ Posted February 2, 2025 Posted February 2, 2025 32 minutes ago, NC Tom said: It was under load as well. Since it has warmed up a bit, it's been starting fine. Does idle a little rough though. As far as Cruiser's tips, what I have found is that these trucks are essentially hobbies. If you don't like getting your hands dirty, or if you don't have the time or resources, you may experience Comanche Derangement Syndrome or "CDS". I have one foot in the "don't have time or resources" group. So, yeah, I have a little "CDS" going on! Ok, I suspect that the rough idle would be an IAC or TB needing cleaning or the TPS needing adjusting. These trucks definitely are a hobby. They can be very reliable, but it usually takes a while to get them sorted out completely. And just about everyone on here has something they want to fix, update, or change on their truck, even if it appears to be done.
